Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Mar 18, 2024 at 5:22 PM
    #6641
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Well, on the surface, looks like I'll be okay.
    Couple things...
    How's this working out for ya?
    And which 5160s do you have on the rear?
    @memario1214 guess it's going to come down front coil choice, and if the 5160s I have on the shelf are compatible.
    AllTacosFloat likes this.
  2. Mar 18, 2024 at 5:29 PM
    #6642
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If you're okay with possibly not getting QUITE 2" of front lift then I can say that you'll be perfectly okay with 650s.
  3. Mar 18, 2024 at 5:48 PM
    #6643
    Maxx
    Maxx Well-Known Member
    5100’s are valved for stock coil springs and 6112’s are not valved for anything over 650# springs.
    Using anything heavier is going to ride like shit. Just facts.
  4. Mar 18, 2024 at 5:58 PM
    #6644
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    Rides well, wheels great...not sure which 5160s I have, whatever Wheelers pairs with All pro expo leafs?
  5. Mar 18, 2024 at 6:01 PM
    #6645
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Same 5160s you have on the shelf. I bought the same kit from wheelers.
    Looks like we’re getting closer:thumbsup:
    Chasespeed[QUOTED] and 530Taco like this.
  6. Mar 18, 2024 at 6:23 PM
    #6646
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    My 5100s have had 650s since new. Was great until the truck started to get fat.
    Not disputing, just statement. I will agree better to be valved appropriately.
    Thank you.
    Yessir.
    So, it seems if I stay 650s, makes no sense to make a change?
    AllTacosFloat[QUOTED] likes this.
  7. Mar 18, 2024 at 6:37 PM
    #6647
    AllTacosFloat
    Boston ish
    Mine rode well with 650 coils and full armor and winch. 700 would be overkill I think. Also not recommended to go heavier than 650 with the 6112s
    Chasespeed[QUOTED] likes this.
  8. Mar 19, 2024 at 4:06 AM
    #6648
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    I have about the same weight as you on my truck minus the rear bumper and my skids are steel instead of aluminum. I went 650s on my 6112s and they are perfect. they have held the weight just fine and squish pretty nicely. Wheelers told me if you go full plate bumper in the front (with the rest of the armor) thats when 700s shine but if you are on a winch bumper 650s are the suggested route.
  9. Mar 31, 2024 at 7:54 PM
    #6649
    tacoma1311
    tacoma1311 Well-Known Member
    How are the 5160s doing for those with 2in of rear lift. On Blisteins website they are rated for only up to 1.5. I’m interested in either Dobinsons IMS or the 6112/5160 set up but want to run 2in at the rear.
    slossboss likes this.
  10. Apr 21, 2024 at 10:54 AM
    #6650
    det_414
    det_414 Member
    2020 Tacoma TRD OR 6MT
    Figured I’d ask here…
    On Friday I installed the 6112/5160 setup with icon rxt stage 1 on my 2020 Tacoma. 10/8 clip setting up front. Torqued everything back down to spec. Made sure to mark and even took pictures of my Lca cam bolts to put them back where they were when I went to torque them down. Install went smooth and everything looks (mostly) great. Truck is much more level than expecting. Was assuming I’d keep the factory rake by moving the front and rear up roughly 1.8”. But it being level is fine too. Guess I didn’t account for a bed mat and tonneau cover, plus some tools in the bed.
    Didn’t take stock height measurements but post lift I’m at
    DF: 23 1/4 PF: 23 1/2
    DR: 23 1/4 PR: 24
    Anyways. Took it in for an alignment on Saturday and the tech said everything looks great alignment wise. Only thing he did was adjust the steering wheel to make it straight.
    Noticed the truck seems to wander a fair amount. Nothing crazy, but definitely doesn’t feel right and the front end feels pretty light and not grounded, if that makes any sense. I’ve rechecked the torque on everything and can’t find anything loose.
    Do these alignment specs look good? Anything I should have the shop adjust?
  11. Apr 30, 2024 at 3:23 PM
    #6651
    23trdsportpali
    23trdsportpali Member
    2023 Tacoma TRD SPORT ACLB Lunar Rock
    Bilstein 6112 5160s, Icon Rxts, 265/70/17 Wildpeak At4w
    Hey guys,
    I recently had my 6112s and 5160s installed with icon rxts at option 1. 6112s were set to 8/6. I did not have the taco lean before, and now I feel as if my truck is overcompensated for it with the driver side being a full inch higher in the front and rear than the passenger side. Should I just expect to get more of a lean as I put more miles on this new setup and itll even out or should I try to switch the 6112s to 7/6 or 6/6?
  12. Apr 30, 2024 at 8:43 PM
    #6652
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    How new is the installation will take some time for it to settle
  13. May 1, 2024 at 5:02 AM
    #6653
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Expect some settling all around. give it a few weeks then re-measure. you can always adjust down to 7/6 using the weight of the truck to loosen the top hat, bring the ring down one slot, and re tighten.
  14. May 12, 2024 at 2:54 PM
    #6654
    BloodRunner
    BloodRunner Active Member
    2021 AG Tacoma OR
    Not sure if you already got everything done, but I figured I'd put in my 2 cents. I also have an sso front bumper with a winch. I have the 6112's with 650s. I've found that the 650s will lift the front half an inch over what the settings says it will for the 6112's, but with the winch and bumper it brings it back down about half an inch. I agree with what everyone else is saying and think the 650s will be just fine. I would only go with the 700s if you want more lift and don't mind a rough ride.
  15. May 12, 2024 at 3:50 PM
    #6655
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    The low caster angle will owe to lack of tracking and light steering (on top of your trucks already light steering) wheel feel on center. You will have to look and see where the adjusters are set to to know of there's adjustments left. This is one of the things that aftermarket UCAs correct for (as the suspension moved down in travel it looses caster and camber angle)
    Before going and buying new UCAs, you could try adding in a tiny bit more total toe. I would try going up to at least 0.13 total. The extra toe will help make it feel less wandery going straight and in turns.
  16. May 12, 2024 at 5:27 PM
    #6656
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Thanks. I was planning on the 650s. Haven't placed my order yet though.
  17. May 16, 2024 at 8:45 AM
    #6657
    opihiman
    opihiman Active Member
    San Jose, CA
    2006 PreRunner SR5 TRD OR/ 2023 TRD OR 4x4 Long Bed
    Bilsteins 6112/5160 OME leafs
    I,m ready to install 6112's/5160's 600# spring set at 10/8 Icon AAL on a 23 TRD OR DCLB i have sway bar relocation kit just in case
    would i need a diff drop or would the axle angle be minimal with the 1.7" front lift
    is there any difference in rear ride quality with or without the factory overload leaf spring when adding AAL
    thanks in advance
  18. May 16, 2024 at 7:40 PM
    #6658
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    I love reading the 6112 threads because there is a middle 650# option that people try, rather than for example, 5100 options of raised stock coils, long 586/590#, or long 700# coilsprings.
    Some rave about one thing or the other, but there is no middle rate alternarnative to evaluate.
  19. May 20, 2024 at 5:01 AM
    #6659
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    You shouldn't need the diff drop unless you are going 3"+, 1.7 is plenty fine to not use a diff drop. I would suggest using the sway bar relocate though for any lift if you plan on keeping the sway bar. I kept mine on because its a daily driver and the relocate drops it about an inch and moves it just slightly forward (I think its forward).
    opihiman[QUOTED] likes this.
  20. May 26, 2024 at 9:43 AM
    #6660
    Akguy
    Akguy Well-Known Member
    way up north
    23' Silver OR DCSB
    I've been waiting for a month now for my 6112s to be shipped and now they aren't even expected to be made til sometime next month. Does anyone know of a shop that has them in a kit,6112/5160 in stock for a gen3?
