Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jan 26, 2025 at 1:48 PM
    #6701
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    Reaf the post above yours for my experience.
  2. Jan 27, 2025 at 7:58 AM
    #6702
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    We've built bunches of these for the Tacoma, and find the Bilstein build guide to be pretty accurate for the most part. 7/9 will yield you approx 1.4" over stock whereas 10/8 will land you around 1.7" over stock. This is assuming you have no additional weight up front. The additional weight of the long bed is negligible in terms of front lift yield.
    Also, if you haven't hitched your wagon to the SS folks, we've got what you're looking for on the shelf over here at Hotshot Offroad. :wave: We've built dozens for TW folks, and would be happy to help!
    https://hotshotoffroad.com/products/6112-5160-0-2-lift-kit-16-tacoma?variant=43849341501659
    Klinc207[QUOTED] likes this.
  3. Jan 27, 2025 at 9:24 AM
    #6703
    Klinc207
    Klinc207 Well-Known Member
    Already ordered! Should have shopped around a bit. I do have the always on fog light kit in the way! :bananadance:
    memario1214 likes this.
  4. Jan 27, 2025 at 9:40 AM
    #6704
    memario1214
    Colton
    Missoula, MT
    No sweat. If you need us for anything in the future we'll be around!
  5. Feb 17, 2025 at 9:43 AM
    #6705
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    So when I installed my 6112's up front I was replacing my worn out TRD Baja Bilstein Suspension. According to Toyota, the Baja/Pro suspensions on 2nd gens gave ~1.75" of lift. I took measurements from hub to fender before hand as a reference. I wanted roughly the same total lift up front to go with the rear lift achieved from my OME leaf springs.
    I set my 6112's at 1.8" of lift, so notches 9/7 for a DCSB, with new KYB upper mounts. When I put these on the truck and lowered it back down with the wheels/tires back on it was nose high. Way taller than it was before. Not sure why based on the height chart. Unless it's something with the KYB upper mounts?
    Ended up having to move the perches down to 7/5 for 1.2" to come in hub to fender to where I was before. Netted an extra 1/2"-1/4" of height compensating for the lower shock bushing and upper mount sag from the old Baja shocks.
  6. Feb 17, 2025 at 11:05 AM
    #6706
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Drive it before measuring. It will drop about 1" after lifting the front w stands.
  7. Feb 17, 2025 at 1:20 PM
    #6707
    ThatguyJZ
    Jim
    TRIAD, NC
    I took that into account, but still...
    After setting them at 7/5, my measurements are still spot on and it's been over a month
    BattleKat likes this.
  8. Feb 18, 2025 at 8:28 AM
    #6708
    spankye
    spankye Member
    New to Tacoma's as of this week and the truck I bought came with a NIB Trail Pro lift from Wheelers...6112's with 600# springs, 5160's in back, and the All Pro standard leaf pack (3"). Current set up is 5100's that are 10 years old with original leafs, i'm sure all of it is tired.
    A normal person would just install all this and be happy but i'm having a hard time. The fronts are set at the highest lift, 2.5", which I don't really need or want and I suppose after the rear leafs settle in it should be somewhat level. I could just move the front clips to what I want but then i need a new leaf pack which means I have to try and sell this one, etc, etc. Also, if I install i'm not buying new UCA's until I know these won't work and I'm worried about harshness on the highest clips.
    So, should I quit whining and just install everything or go a different route?
  9. Feb 18, 2025 at 3:20 PM
    #6709
    BattleKat
    San Diego
    Me confused. You start off saying the truck came with "NIB Trail Pro lift from Wheelers...6112's with 600# springs, 5160's in back, and the All Pro standard leaf pack (3")", but then in the very next sentence you seem to contradict this and say "Current set up is 5100's that are 10 years old with original leafs, i'm sure all of it is tired."
    I am unclear as to the question.
    Note I can only speak for myself on the leaf spring topic, but I got the Icon RXT leaf pack and did setting 2 2.5 years ago. It has not settled at all.
  10. Feb 18, 2025 at 5:11 PM
    #6710
    spankye
    spankye Member
    Sorry about that, i'll clarify. I bought my Tacoma this past weekend. 2011 OR DCSB. The previous owner installed the 5100's about 10 years ago. Current leafs are original and need to be replaced.
    Included in the sale was the brand new Trail Pro kit, he just never got around to installing it so it came with me. I really want to put the kit on, if for nothing else the new shocks. The leaf pack in the kit is a 3" lift and I'm confused because the 6112's max at 2.5. I assume the rear will settle some, and with a fiberglass cap installed it shoudl aid in leveling the truck...I just don't really want a maxed out front lift with a ton of rake which is why i considered selling the leaf pack and getting an Icon, etc.
    I think at this point I'm just going to install it all, and if the rear pack isn't to my liking i'll replace it with something else and adjust the front accordingly.
  11. Feb 19, 2025 at 3:29 PM
    #6711
    BattleKat
    San Diego
    I can tell you I got less than advertised with my 6112's up front on the 9/7 setting and went up to 650# springs to compensate. No excess weight.
    Icon's in rear on option 2 I got MORE than advertised with a shell and no settling after 2 years.
    Neighbor kids, I asked opinion, they said it looked like a stink bug before I went to the 650# springs. Now I have about 1" of rake which is what I wanted so it leveled out when camping!
  12. Feb 21, 2025 at 9:51 PM
    #6712
    OPTIMUM
    OPTIMUM YotaWerx Authorized Retailer OptimumTuning.com
    Grand Rapids, Michigan
    I need help deciding whether to put 650# or 700# coil springs on my 6112s. I'll be installing an SSO slimline bumper and Badland Apex 12k in a month. I currently have an Uptop Overland roof rack and RCI sliders. I'd like to maintain a 2" lift in the front if possible. If anyone has a similar setup and can chime in, that would be appreciated.
  13. Feb 22, 2025 at 6:37 AM
    #6713
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    According to Bilstein (and my own personal experience) the 700# springs are too much spring for the 6112 shocks. Bilstein has a great podcast explaining the engineering behind this - came out a couple of years ago.
    I put on 700# springs when I installed my Pelfrybilt steel bumper and Warn 10K winch (and removed my sway bar.) The truck cornered fine, but did not have a lot of movement in the front suspension. After a year or so, I changed to the 650# springs - night and day difference. Yes, the front end sits a little lower (which provides more droop travel), the ride is smoother, and off-road I can really feel the suspension working. Yes, there is a little more body roll on the street, but it's no big deal.
    OPTIMUM[QUOTED] likes this.
  14. Feb 22, 2025 at 6:40 AM
    #6714
    OPTIMUM
    Thanks! How much lift are you getting?
  15. Feb 22, 2025 at 6:54 AM
    #6715
    Scott B.
    Scott
    Georgia
    2 - 3", running at the top clip setting.
  16. Feb 22, 2025 at 7:01 AM
    #6716
    OPTIMUM
    Oh nice! I know the 2nd Gen weighs a little less than the 3rd gen but I'm hoping I can still get 2" on max clip on 650#. 2" would be preferred but I'll be happy with 1.5". Most of my driving is city and forest road. There's not many obstacle in Michigan that a stock Tacoma couldn't go anyways.
  17. Feb 22, 2025 at 7:44 AM
    #6717
    Scott B.
    Scott
    Georgia
    I don't think there is that much difference in weight, and my bumper is probably a little heavier than yours, so it probably evens out. :p
    I'm pretty sure you will get the lift you are after.
  18. Feb 22, 2025 at 12:36 PM
    #6718
    OPTIMUM
    I sure hope so. I'll report back in two months. Still waiting for the C4 bumper reinforcement bracket (8 weeks) before I can install the bumper and lift. Considering they don't even powder coat their product, I'd expect a little quicker processing time.
  19. Feb 22, 2025 at 1:00 PM
    #6719
    Scott B.
    Scott
    Georgia
    Can't you install your bumper without the C4 bracket, and install the bracket later?
    I have C4 reinforcement brackets, and put them on after my bumper install. To be safe, I did not use my winch until I put the brackets on.
  20. Feb 22, 2025 at 1:08 PM
    #6720
    OPTIMUM
    I probably could but I would still need to grind out the two welded bolt on each side of the mounting plate. I don’t want to be out in the cold right now. Last year it was 50-70 degree by now in Michigan. I’m happy for all the snow lover but I’m done with the snow and cold this year lol
