Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jul 2, 2017 at 7:58 AM
    #681
    texasyeti
    texasyeti Member
    Just installed a set of 6112/5160's yesterday on my 2015 non-TRD 4X4 DCSB. Took about 6 hours from start to finish. 6112's are set on the 3rd notch. Did not swap out UCA's.
    Before > after measurements (fender lip to center of hubcap):
    Driver front: 20.0 > 22 5/8
    Passenger front: 19 7/8 > 22 5/8
    Driver rear: 22 1/16 > 22 1/4
    Passenger rear: 21 3/4 > 22 1/4
    I'm hoping it will settle a bit over time and will update with new measurements after driving it a bit.
    Also added some 235/85/16 Cooper ST Maxx Tires
    Here's where we started. Not the best shot but I was pretty focused on getting it done:
    Here's where we ended:
  2. Jul 3, 2017 at 9:43 PM
    #682
    PreTaco170
    PreTaco170 Well-Known Member
    Russ
    San Diego County
    2009 PreRunner DCSB TRD OR
    Bilstein 6112/5160, Dakars, JBA UCAs, FN f(x) Pro 17x8, 285/70R17(C) BFG KO2, Wheeler's Off-Road Bumpstops/U-bolt flip kit, CMC, Marlin Crawler HD LCA Frame Brace Kit, TRD CAI, Flowmaster exhaust, Alpine iLX-007 CarPlay receiver
    I don't know if it matters since you're a 3rd Gen and I'm a 2nd Gen, but my 5160s came with a spacer and a small relocation bracket with the left shock so that the brake lines can be slightly relocated for more slack. I didn't need extended lines and I had the full Dakar leaf pack in. I have removed the 3rd leaf since that time to slightly soften up the ride since my bed is empty most of the time (and to lower it a bit). But either way, the full pack gave me 2.75-3" of lift and my lines were fine. Hope that helps.
  3. Jul 3, 2017 at 10:08 PM
    #683
    PreTaco170
    Russ
    San Diego County
    How do you like your 255/75 ST Maxx tires? I installed 285/70R17 ST Maxx about 6000 miles ago and I am trying to figure out if the reason my suspension feels a little harsh is due to the 60 pound beefy tires or because I need to lower my clip position from 4th to 3rd, or both. I will probably take out the top overload on my Dakars as well to keep it level. It sits perfectly level (maybe 1/4-1/2" rake) with the 3rd leaf removed and the 6112s on the 4th position. I'm only a PreRunner btw.
    Just wondering if a 31.77" ST Maxx feels a little better than a 32.99" as far as suspension movement. I'm sure it does and I knew the tires were gonna be heavy. Just rethinking my decision but I just spent A LOT of money on these tires. The 255/75 is the only C load ST Maxx that I can find on their website. Also, do you feel that size fills out the wheel well nicely? Thanks for any input!
  4. Jul 10, 2017 at 7:19 PM
    #684
    The Boat Oar
    The Boat Oar Well-Known Member
    2014 Blacked Out TRD Off-Road
  5. Jul 10, 2017 at 7:26 PM
    #685
    texasyeti
    texasyeti Member
    It wasn't too bad for me. Have not installed the add-a-leaf yet but that seems to be the easiest part of the install. I disconnected the steering linkage with a puller. Had the truck pretty high up on stands which made it easier to get the coilovers out. Hardest part was getting the driver's side coilover in. Had to work the lower control arm pretty hard. Took if for an alignment and everything was actually in the green according to their system. Asked for 0 toe, 0 camber and the most caster they could give me. Ended up with about 2.0 degrees caster on both sides.
    My shocks were set up on the third notch and this has worked out well for my 235/85-16 tires on stock wheels. Plenty of clearance and absolutely no rubbing. Did not install upper control arms and, after putting about 250 miles on the truck, it has settled nicely. Front axkes are pretty much in a straight line with no crazy CV angles.
    Rear shocks went in no problem.
    Oh, it was well worth the extra charge to have the coilovers assembled by Headstrong.
    DrFunker likes this.
  6. Jul 10, 2017 at 7:39 PM
    #686
    The Boat Oar
    Thanks for the info. Do you really have 235/85-16 tires or is that a typo? I have just never heard of anyone using a tire that skinny
  7. Jul 11, 2017 at 3:32 AM
    #687
    DrFunker
    DrFunker is Funkified!
    Didums
    May be the next size I go with, if they will fit my wheels. :rolleyes:
    What brand do you have?
  8. Jul 11, 2017 at 6:03 AM
    #688
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    235/85 isn't that uncommon for a large, but skinny, tire. It's a typical width for something like a Chevy Blazer or Ford Ranger
  9. Jul 11, 2017 at 2:46 PM
    #689
    texasyeti
    texasyeti Member
    Yessir. Was thinking 255/85-17's initially but the 235/85-16 is a tire that will be easier to get if I need one on the road. The 235's also do not require a regear.
    I am running Cooper ST Maxx tires. Had their 255/85-17 on my 80 series land cruiser and they did really well. They lasted awhile and were good in the wet and snow - when we get snow in Fort Worth. I hunted down a set of stock steel wheels just to make sure I was GTG on backspacing and the width was right for the tires.
  10. Jul 12, 2017 at 8:42 PM
    #690
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb 4.56 gears w/Harrop e-lockers
    Because it was posted in another thread....not the best pics but they'll do to show the difference.
    Before
    After- 6112s with 650# springs on the 2nd notch with Dakars and d29xl all in the rear on B110 shocks. Bumpers, winch, sliders and skids next month.
    Jared8907, PreTaco170, Ewadh and 3 others like this.
  11. Jul 13, 2017 at 2:54 AM
    #691
    DrFunker
    Didums
    :woot:There it is!
    Jared8907 and Sna like this.
  12. Jul 19, 2017 at 1:13 PM
    #692
    schmidt4brains
    schmidt4brains Highway Warrior
    Texas
    2016 TRD Sport. DCSB. MGM. 2WD.
    255/75R17 Michelin L/T Defender Speaker upgrades: Front JBL GT7-96, Subaru H631SFJ01 Tweeters, Rear JBL GT7-6 Auxbeam FS-16 low beam LED bulbs AC drain extension Removed front bumper air dam
    This is the perfect set-up! Really nice truck!
    What settings on your coil overs? I'm considering #3/#4, but I like whatever you have.
    Also, did you need to change out UCAs?
  13. Jul 19, 2017 at 5:07 PM
    #693
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
  14. Jul 19, 2017 at 7:13 PM
    #694
    GECKO 01
    GECKO 01 Active Member
    Jeremy
    Arizona
    2017 TRDOR DCSB
    Bilstein 6112 and 5160 BFG 265/75/16 KO2 ECGS
    I went with 5/4 and am running factory control arms. The alignment came out fine with no issues. I removed the overload leaf in the rear and gained about 1.5" all the way around keeping the factory rake.
    MikeR585, PreTaco170 and nibrwr like this.
  15. Jul 20, 2017 at 11:03 PM
    #695
    MikeR585
    MikeR585 Well-Known Member
    Vancouver Island, BC
    2017 MGM Tacoma TRDOR
    I agree with the above - Love how this turned out, thank you for posting!
    PreTaco170 likes this.
  16. Jul 21, 2017 at 1:44 AM
    #696
    MikeR585
    Bumping this back up to the surface, as the final question is a good one.
  17. Jul 21, 2017 at 5:18 AM
    #697
    GECKO 01
    Jeremy
    Arizona
    2017 TRDOR DCSB
    I feel like I have the vertical clearance to run 285's without a problem. I think the real key to not having to do a CMC is the offset of the wheel you choose to run. It seems that the people with the most success are running a 0 offset.
    BCbuggy likes this.
  18. Jul 21, 2017 at 8:36 AM
    #698
    MikeR585
    Thank you sir :thumbsup:
  19. Jul 21, 2017 at 9:14 PM
    #699
    Boris20
    Boris20 Well-Known Member
    Jordan
    Oklahoma
    17 Tacoma TRD OR Quicksand
    any 3rd gen TRD OR or sport guys running these on top notch settings have any feed back?
    Weighing my options on a 2" lift, I feel maxing them out wouldnt be a great idea for a smooth daily driver.
  20. Jul 22, 2017 at 3:23 AM
    #700
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    @Humboldt_Homie has them on double cab long bed on the top notch and I believe the ride for him is OK , @ClydeFrog has them on access cab and if I remember correctly they are a little stiff for him . Dealing with cars for 28 years one thing I know is that ride is subjective each person may have a slightly different opinion even on the same setup. I plan on running them at max on a 3rd gen double cab long bed. The long bed and the double cab would probably also help soften the ride because of the extra added weight
    Tacos2016 and Boris20 like this.
