Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Apr 12, 2018 at 2:49 PM
    #1241
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    Are 8112's even available yet?
  2. Apr 12, 2018 at 3:07 PM
    #1242
    tow-coma
    tow-coma Well-Known Member
    In limited quantities. Rogue had a few sets but they were already paid for
    ajpagosa[QUOTED] likes this.
  3. Apr 12, 2018 at 3:52 PM
    #1243
    ajpagosa
    SW Colorado
    They'd need to be pretty amazing to be worth roughly 3 x cost of a set of the 6112's. Have to see what true street price is after they are up to full production though.
  4. Apr 13, 2018 at 12:36 PM
    #1244
    schmidt4brains
    schmidt4brains Highway Warrior
    Texas
    2016 TRD Sport. DCSB. MGM. 2WD.
    255/75R17 Michelin L/T Defender Speaker upgrades: Front JBL GT7-96, Subaru H631SFJ01 Tweeters, Rear JBL GT7-6 Auxbeam FS-16 low beam LED bulbs AC drain extension Removed front bumper air dam Eibach Pro Lift kit Headstrong 3Leaf AAL (left in overload)
    New Bump Stops Needed? Recommended?
    Just curious for those that have upgraded to 6112/5160 and Dakars, was there a need (or even a "highly recommend") to change out the bump stops to a larger size? Are the stock bump stops sufficient when adding 2" in lift?
  5. Apr 13, 2018 at 4:01 PM
    #1245
    tow-coma
    They have a bottoming cone and that's pretty much it for the front. The rears are a lot more performance for the same price
  6. Apr 13, 2018 at 4:02 PM
    #1246
    tow-coma
    The stock bump stop is rock hard. Best to replace them with something that can absorb a bottoming.
    If you don't want to replace, to need to make sure your new shock has enough travel for those extra 2 inches. If not, you'll need a taller bump stop
  7. Apr 13, 2018 at 4:04 PM
    #1247
    mbcnya
    mbcnya Well-Known Member
    San Diego, CA
    TRD Sport Package TRD Pro Grill Front Window Tint 35% Rear Window Tint 20% OEM Kicker Tweeters Kicker Front 6x9 3-Way Speakers and Kicker Rear 6.5" 2-Way Speakers Bilstein 5100 Front and Rear Shocks with 1.1” lift and with 1/4" ORW Spacer on Drivers Side Pro Comp Rockwell Series 34 Wheels with Black Lug Nuts Tacoma Lower Black Valance Predator Tube Steps Falken Wildpeak A/T3W 265/70/17 at 6,000 Miles TRD Shift Knob OVTune 1.03 Valve Stems Black Aluminum TRD Cat Back Exhaust DCSB Plastidip Badges Black Toyota Tacoma OEM All-Weather Floor Mats DDM Tuning HID Low Beam Kit 5500K Supernova V.3 LED High Beams TRD Pro Hood Bulge with Plastidip Scoop Plastidip Fender Flares Black MESO Ultimate LED Mirror Signals Rugged Premium Hard Fold Tonneau Cover Blacked Out Headlights Mod Toyota Bed Extender Diode Dynamics Reading and Dome Light LED’s Tailgate Pop n Lock MESO Gasshole Morimoto XD LED Fog Lights LED Bed Lights OEM Mud Flaps
    Damn, thanks for the info @tow-coma . I think I'm going to move onto the Fox 2.0's. Anyone have experience with them?
  8. Apr 14, 2018 at 11:22 AM
    #1248
    tow-coma
    There is a huge difference between the performance you'll get from the 8112 and any 2 inch shock. I wouldn't look that far away.
    Go to Filthy Motorsports and see what a set of custom Kings would run you. It will be less than you think
    oscolivar1 likes this.
  9. Apr 14, 2018 at 11:33 AM
    #1249
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    I wouldn't even bother with a 2.0s fox honestly. I would just go with Bilstein 5100 instead of that. Obviously if 8112 are better but my 6112 does the job just fine.
  10. Apr 14, 2018 at 11:37 AM
    #1250
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
  11. Apr 19, 2018 at 6:11 PM
    #1251
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Unfortunately I don't. I heard some scuttlebutt about it being as late as July but with Bilstein you never know for sure.
  12. May 1, 2018 at 12:28 PM
    #1252
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    For those with 6112 with different 650lb or 700lb. Can you recommend me which brand/mode of coil to get? Currently I’m on max 6th notch my 3rd gen 6112 and the coil it came with (600lb?) but after 9 months...I’m interested in little more lift. Maybe reach 3” lift front and drop thr notch to 5th maybe...
    For rear, I have HS AAL + Overload leaf left in there which spec says 2” lift in rear. I do like the about 1” factory rake this gives me. I would like to maintain this so would i uograde to a Dakar Medium leaf pack?
    Thank you.
  13. May 1, 2018 at 1:11 PM
    #1253
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    The only coils that fit this is the eibach 650/700 which are 14" long just like the 600lb that came with the 6112. king, fox, icon can fit but they just more expensive with the same specs, which are most likely unbranded eibachs. OME coils do not fit our application.
    Don't expect switching to this coil will give you a 3" lift. If anything you'll gain maybe .25-.5" but will settle down a bit.
    I switched to 650lb spring with No complaints cuz I added a front bumper. Good luck
    Sna and Tibetan Nomad[QUOTED] like this.
  14. May 1, 2018 at 1:18 PM
    #1254
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    Thank you Sir! so the link you provided is also for 2016 3rd gen Tacoma?
    And with what you said, i may just go that route and not mess with the current AAL+Overload leaf that i have.
    Hmmmm the 700lb is tempting...i wouldnt mind a lil firmer suspension if it means i have somewhat “future proof” if i want to add some weight down the road but i dont have plan to do so but i do want little more lift.
    Sna likes this.
  15. May 1, 2018 at 1:26 PM
    #1255
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I wouldn't buy them for lift, I would buy them if your planning on a bumper, 2nd battery, compressors etc. 700 on a stock truck will be a stiff ride. 650 would be fine I would think.
    Up to you though. If you want more lift switch out the setup for coilovers.
    Sna likes this.
  16. May 1, 2018 at 1:28 PM
    #1256
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Looks like if you wanted to sell the 6112's and go with a better match for a 3" lift, it would't be very hard....
  17. May 1, 2018 at 1:44 PM
    #1257
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    Due to 6112 stocks being on backorder i keep reading..?
  18. May 1, 2018 at 1:48 PM
    #1258
    Voltron4x4
    Denver, Colorado
    This and that...
    Yep, so easy sell to someone wanting the 6112's and then use that money for a suspension better suited for 3 inches.
  19. May 2, 2018 at 11:34 AM
    #1259
    PFD FIRE
    PFD FIRE Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    Since we're talking about 6112 Bilstein shocks which I currently have on my Tacoma. Im thinking of switching my 265\75\16 all terrains to 285's. Im I going to have any problems with the bigger tire fitting properly with the 6112 shocks?
  20. May 9, 2018 at 9:37 AM
    #1260
    VKP. WA
    VKP. WA Well-Known Member
    Seattle WA
    2012 Tacoma
    got some
    I have that same set up and I did not have any problems with the 285/75/16s driving freeways and city roads. if u want to go off-roading, u r going to have to do a cab-mount chop. Once that's done you are good to go...
    PFD FIRE[QUOTED] likes this.
