Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jun 21, 2018 at 10:16 AM
    #1321
    KugelBlitz
    KugelBlitz Well-Known Member
    Warren
    Middle-GA
    2015 4WD, 6MT, TRD Sport Access Cab
    Bilstein 61112/5160, Dakar EL096R, 285/70-R17 C BFG K02, Level 8 Mk6 wheels, Bestop Softop US. OffRoad Hidden Winch Bumper, ComeUp DV-9s winch, SOS Concepts Sliders and IFS Skid plate, VIAIR 400P Auto compressor mounted in a Expedition Essentials bedside mount, TRD Quick Shifter, TRD Cat-Back exhaust, ,75WX ST CB, Pioneer AVH-X4800BS, and various other mods and things...
    If they are it's a closely guarded secret.
  2. Jun 21, 2018 at 10:18 AM
    #1322
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I was on a couple of different lists at a bunch of different places since February. They are sparsely coming in to different vendors due to the ongoing high demand of them. Bilstein is having a very difficult time trying to keep up with production due to this demand. I had went with the 6112’s recognizing their warranty, how well they work compared to other high-end shocks, the overall price of the shocks, and my overall budget. Fox, ADS, and King all make extremely good shocks but for the quality, warranty, and keeping a budget in mind, I would still recommend the 6112’s even though you might have to wait for them. Contact Marie, @HeadStrong Off-Road , and you might be able to get on the list and get lucky.
    HeadStrong Off-Road likes this.
  3. Jun 21, 2018 at 11:13 AM
    #1323
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I waiting for them to be in stock so I can place an order.
  4. Jun 21, 2018 at 11:20 AM
    #1324
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    I'm waiting as well....
    Just wondering since I have mobtown sliders and an aluminum bumper with Baja design fogs and 30" S8 led bar in the bumper along with metal grill with another 30" S8 light in the grill I'm guessing 60 to 70 extra pounds up front. Can I run the 6112's on the 6th notch with out too much problem...? Or should I go with a 650 lb. spring...?
    Would like to achieve 2 1/2" of lift after settling....and still have a decent ride and performance...
  5. Jun 21, 2018 at 5:58 PM
    #1325
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    I think you'll be ok. The winch was the big factor on my front end. I have a steel semi hidden bumper, aluminum skids, and sliders as well. The ride is great with the weight on front.
  6. Jun 21, 2018 at 8:31 PM
    #1326
    slomoe
    slomoe Well-Known Member
    Stuart,Fl
    2011 Tacoma DCLB TRD Sport 4x4
    Wet Okole, Maxxis Razor (285x70x17), Bilstein 6112, RXT's Fn 5star
    I hear ya on the budget. I can swing the ADS coilovers, but if I could get the 6112's and save the additional $700 it would cost for the ADS. Hell, it's like getting a leaf pack or numerous other parts for free. Looks like some phone calls are in order.
  7. Jun 22, 2018 at 9:20 AM
    #1327
    fxrman
    palm springs
    So stick with the 6112 stock springs..?
    Will the 6th notch be ok..?
    Again would like 2 1/2" up front and 2" out back after settling.
    Roaming__Taco likes this.
  8. Jun 22, 2018 at 12:04 PM
    #1328
    VKP. WA
    VKP. WA Well-Known Member
    Seattle WA
    2012 Tacoma
    got some
    Do you guys know if ICON coils will fit on 6112 shocks?
    Thanks
  9. Jun 22, 2018 at 4:03 PM
    #1329
    slomoe
    Stuart,Fl
    I cant say with certainty but I would think so depending on the coil length.
    Both are 2.5'' shock bodies. The Icons I had on my first gen Tundra had a 13'' spring/ length and an ID of 3''. Although I ended up putting on a 14'' coil 700 lb from King.
    VKP. WA[QUOTED] likes this.
  10. Jun 22, 2018 at 4:09 PM
    #1330
    slomoe
    Stuart,Fl
    Talked with I think Steven at Wheelers little bit earlier about 6112's being available. He said they had received stock for Tundras, fifth gen 4 Runner's, I think first gen Tacomas but no 2nd gen yet. Expecting first of to the middle of July for the 2nd gen's.
  11. Jun 22, 2018 at 6:40 PM
    #1331
    Harvo
    So withthe 6112s at the 6th notch you will get the maximum available out of this front suspension. No matter what springs you put on there it won't get any taller... just stiffer. If you will be adding weight, expect some sag. It's not much, but I notice it. The ride is still amazing.
    If you put stiffer springs on them and don't put weight on the front, your ride will not be amazing. Maybe not even nice.
  12. Jun 27, 2018 at 2:12 PM
    #1332
    Nick_Taco
    Nick_Taco Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    Do these get super stiff like the 5100's as you go up the notch settings? Obviously they will get stiffer the more preload you add but I'm wondering if it's a bit better ride with these.
  13. Jun 27, 2018 at 2:23 PM
    #1333
    fxrman
    palm springs
    I'm told it's a linear spring so it's not supposed to be as bad but I've been asking the same question.
  14. Jun 27, 2018 at 5:40 PM
    #1334
    Harvo
    The spring is made for the shock so even at the max setting it's not too much for the shock to handle. Mine are max and after a few weeks of settling in they ride wonderfully.
    lynyrd3 likes this.
  15. Jun 27, 2018 at 10:27 PM
    #1335
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Correct the 6112 comes with the linear spring not a progressive spring, so the spring rate stays the same. Factory Springs are progressive So they will get stiffer as they are compressed. My brother has 5100s on his forerunner, and they ride wonderful at the Max 2.5 inch setting. Apparently the Tacoma at Max setting gives a harse ride maybe do from the weight difference or valving
  16. Jun 28, 2018 at 6:18 AM
    #1336
    fxrman
    palm springs
    I thought the 5100's were used with longer springs at zero setting as to not make the ride too stiff...?
    So how can they be at the max setting and ride good..?
    Did he put linear spring on them..?
    Just curious as the reason for not going 5100 was to get a better controlled ride with 6112/5160 combo without the harshness...
    Edit: you said the weight difference so that makes sense...
  17. Jun 28, 2018 at 6:51 AM
    #1337
    Clay7160
    You can either preload the factory coil springs using the 5100 clip system, Or use longer Springs like 0ME
  18. Jul 2, 2018 at 5:23 AM
    #1338
    KugelBlitz
    Warren
    Middle-GA
    Looks like these may be starting to be available again. Found some on eBay with a response from the vender (wUnderCarParts) that says they are in stock and ready to ship.
    AWD_Jeff, toucan and Lucario Runner like this.
  19. Jul 6, 2018 at 3:17 PM
    #1339
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    I would just go to 650
    01x4[QUOTED] likes this.
  20. Jul 6, 2018 at 3:17 PM
    #1340
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Agree
    01x4 likes this.
