Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Oct 27, 2018 at 8:12 PM
    #1641
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Eventually? How so?
    Tacohumper13[QUOTED] likes this.
  2. Oct 27, 2018 at 10:43 PM
    #1642
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    Premature tire wear and rubbing on UCAs
  3. Oct 28, 2018 at 4:32 AM
    #1643
    DrFunker
    DrFunker Well-Known Member
    I have Dakars with the top OL taken out. No real issues with them.
    ejewels[QUOTED] likes this.
  4. Oct 28, 2018 at 5:16 AM
    #1644
    ejewels
    CT
    I was thinking about just getting some JBAs and installing while I do everything else. At 1 or 1.5” though I’m thinking I’m fine without them. I just think about the TRD PRO that’s lifted 1” and I think uses the same UCAs as our ORs. And if Toyota didn’t find them necessary...
    DrFunker likes this.
  5. Oct 28, 2018 at 5:18 AM
    #1645
    ejewels
    CT
    Thanks man. I think you actually know the guys that are going to (hopefully) be installing my stuff in Florence, MA.
    DrFunker[QUOTED] likes this.
  6. Oct 28, 2018 at 5:30 AM
    #1646
    DrFunker
    :thumbsup:
    Yes, I do. :D Levi apparently has the only shop press capable to take care of 6112s. :laugh:
    :cheers:
  7. Oct 28, 2018 at 5:32 AM
    #1647
    DrFunker
    We put JBA UCAs on a year after my lift went in. If I could have, I would have done it all at the same time. So much easier to get in there.
    If you can swing the $, do it once and be done.
    Yes, the stock UCAs will probably be okay, but the JBAs are so much better and will give you exactly what a lifted truck will need.
    Once you see the JBAs next to OEM you will know why it is a good idea. :D
    Odi412 and ejewels[QUOTED] like this.
  8. Oct 28, 2018 at 6:01 AM
    #1648
    ejewels
    CT
    Does he have a spring compressor in case I wanted to switch notches? Also.. out of curiosity is it ok to run JBAs if I only level or go 1.5”? Can you run them stock suspension as well?
  9. Oct 28, 2018 at 7:12 AM
    #1649
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I believe that he does, the tough thing is that it is going to take about a week for the springs to settle to their normal riding height. The 4/5 notch will give you 2.15" after settling, the 3/5 notch will give you about 1.85" after settling. The JBA's can be run stock suspension or aftermarket lift. It gives you more articulation overall and a 3° caster.
  10. Oct 28, 2018 at 7:50 AM
    #1650
    ejewels
    CT
    Thanks Jared. I think you’re right on the second gen trucks/6112s but in the third gens 4/5th notch gives 1.5”.
  11. Oct 28, 2018 at 7:50 AM
    #1651
    crashngiggles
    Jared
    you are correct sir
  12. Oct 28, 2018 at 8:39 AM
    #1652
    ejewels
    CT
    Has anyone kept the rear stock and just leveled the front a bit for a little more tire clearance and a nice suspension upgrade with 6112/5160? Would love to see pics if someone has. I think it would be the 1/2 or 2/3 notch
  13. Oct 28, 2018 at 9:34 AM
    #1653
    Tacohumper13
    Menifee
    Toyota didn’t find it necessary to redo the needle bearing and look how that worked out.
  14. Oct 28, 2018 at 10:28 AM
    #1654
    ejewels
    CT
    Do the pros suffer from needle bearing issues? Stock, of course...
  15. Oct 28, 2018 at 10:32 AM
    #1655
    DrFunker
    He does. And he knows how to use it. :wink:
  16. Oct 28, 2018 at 10:54 AM
    #1656
    Tacohumper13
    Menifee
    Yes to include 4Runners
  17. Oct 28, 2018 at 10:57 AM
    #1657
    ejewels
    CT
    Hopefully you and @crashngiggles can give him the heads up I’ll be needing his services soon! Just say I’ll bring beer and cash and looking to learn/help!
  18. Oct 28, 2018 at 11:08 AM
    #1658
    DrFunker
    Have you been in touch with @tacobell007 ?
  19. Oct 28, 2018 at 11:32 AM
    #1659
    ejewels
    CT
    A little bit. Him and Levi do the lifts correct?
  20. Oct 28, 2018 at 12:10 PM
    #1660
    DrFunker
    Yes.
