Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Nov 2, 2018 at 2:58 AM
    #1681
    WV Outdoorsman
    WV Outdoorsman Well-Known Member
    Lewis
    2017 Tacoma sport
    5/5 setting with spacer. Quite a bit of lift in the rear as well maybe a slight rake now. I need to measure it when I get a chance. Think it may have been an 1/8” or so lower in the back or dead even with the cap pre lift. Almost went with UCA’s but didn’t. He said alignment was perfect so the cost of UCA’s covered the install, alignment and tire rotation. I researched the heck out of this and couldn’t be happier.
  2. Nov 2, 2018 at 5:01 AM
    #1682
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Sounds great. Any reason you did the 5/5 with spacer instead of 5/6? I guess it really makes no difference so wondering why people choose one from the other. Do you have any lean?
    Weejub likes this.
  3. Nov 2, 2018 at 7:00 AM
    #1683
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Must be running 2nd gen 6112?
  4. Nov 2, 2018 at 12:40 PM
    #1684
    WV Outdoorsman
    Lewis
    2017 Tacoma sport
    No these were 3rd gens and I didn’t want to top them out on the sixth notch. I would rather kept them at 4 but with the Dakar’s I thought it would have been to much rake. Very happy with 5/5
  5. Nov 2, 2018 at 12:48 PM
    #1685
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    So you topped them out on the passenger side but didn’t want to do the driver side? So confused...:help: An extra notch on the driver to compensate for lean.
    6 settings on the driver and 5 on the passenager....
    Tacohumper13 and roguegs like this.
  6. Nov 2, 2018 at 1:00 PM
    #1686
    ejewels
    CT
    No I think he did 5/5 with a spacer.
    A note on topping out. I'm actually still going back and forth with 4/5 or 5/6. 5/6 I think is a must with Dakars or 2" of lift but I'm still going back and forth between keeping my AAL or going Dakar. What I don't get... is if Bilstein made these and also made the notch settings... no matter what notch you're on it still should be OK. So many people advise against the top setting... but if it were bad or not a good ride why would Bilstein even make that setting? Its not like its a aftermarket hack-job like mixing OME springs with 5100s.
    Just an observation I made from all of the threads no one seems to consider. Unless of course, Bilstein themselves say the higher you go, the more harsh the ride will be.
  7. Nov 2, 2018 at 1:32 PM
    #1687
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Where are the reports you're reading of people advising against the top setting? Most everything I've read people say the ride is just fine. There's no questioning the higher you go, the stiffer the ride is. It's just all about what you'd fine acceptable.
    Tacohumper13 and oscolivar1 like this.
  8. Nov 2, 2018 at 1:33 PM
    #1688
    ejewels
    CT
    Just reading around here.. and even Marie from HS. Said she got a lot of reports that at the highest settings... it can be harsher. But then said ride quality is all subjective which I agree.
  9. Nov 2, 2018 at 1:39 PM
    #1689
    iK0NiK
    West
    Columbus, GA
    Gotcha. Yeah the higher you go, the stiffer it'll be, there's no question. My 6112's on #3 absolutely ride stiffer going down an imperfect city street than my Wife's Escape or my buddy's Tahoe. BUT I can run a washboard road going 40MPH plus while they're rattling their teeth out at 30. You'll sacrifice some day-to-day OTR driving comfort, but the overall offroad performance should remain the same.
    Weejub and oscolivar1 like this.
  10. Nov 2, 2018 at 3:08 PM
    #1690
    WV Outdoorsman
    Lewis
    2017 Tacoma sport
    5/5 with spacer on drivers side.
  11. Nov 2, 2018 at 3:23 PM
    #1691
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    o_O Your the first that I know of that’s done this....
  12. Nov 2, 2018 at 3:55 PM
    #1692
    WV Outdoorsman
    Lewis
    2017 Tacoma sport
    Lol!!! I didn’t want one side maxed out. I’m sure it would be ok or Bilstein wouldn’t have designed it that way. I figured it would ride a bit better that way. I don’t have any complaints so far.
    Pretty sure I’ve read others that’s done the same.
  13. Nov 2, 2018 at 4:09 PM
    #1693
    ejewels
    CT
    Bilstein recommends to do the 5/6 thing. If they say it’s ok I’m assuming it is...
    However from a OCD perspective, I get it
  14. Nov 2, 2018 at 4:11 PM
    #1694
    WV Outdoorsman
    Lewis
    2017 Tacoma sport
    Yup I’m sure it’s fine. I went back in this tread and found at least two others who used the spacer as well. So I’m not that special:D
  15. Nov 2, 2018 at 4:15 PM
    #1695
    ejewels
    CT
    You’re right, I thought about it as well but when I saw that Bilstein recommends staggering it, I said screw it and just doing what they say. People say you can’t tell the difference
  16. Nov 2, 2018 at 4:24 PM
    #1696
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    I forgot where I was reading it or who told it to me but I heard that adding a spacer will effect the up travel/down travel (can't remember which one it is). @foxrcing07 was it you?
  17. Nov 2, 2018 at 4:39 PM
    #1697
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    It just can make a normal shock act in some ways like an extended travel shock in the down travel because you're extending the overall length so it increases the need for UCA's
    oscolivar1 and roguegs[QUOTED] like this.
  18. Nov 2, 2018 at 4:40 PM
    #1698
    roguegs
    Angelo
    V8 T4R
    That makes sense to me now.
  19. Nov 2, 2018 at 4:45 PM
    #1699
    ejewels
    CT
    Don’t a lot of people use spacers tho?
  20. Nov 2, 2018 at 4:47 PM
    #1700
    roguegs
    Angelo
    V8 T4R
    Personally, I feel like if the (updated) 6112s were designed to be used with a spacer then they would have recommended that instead of saying do 1 clip higher for the driver's side. However, since the spacer is only so big I don't think it would make THAT much of a difference but you never know.
