Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Nov 12, 2018 at 12:06 AM
    #1721
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    I just installed the 6112's on the front. My truck was originally a New Jersey Truck with winter salt and summer beach use. The rust on the bolts made it way harder and the sway bar links were rusted to the point that I had to cut them off (ordered new ones).
    If I had to do it again, I would have ordered the oem top shock mounts and not reused the old ones.
    Just a heads up if you have rusty bolts and want an easier install.
    On a positive note, it rides a lot better.
    slomoe and Coolerman like this.
  2. Nov 20, 2018 at 6:39 PM
    #1722
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Anybody running 700lb springs? If so, what notch are you set at for 3" and how much weight have you added.
    Adding a hidden winch mount, 10k winch, and full steel skids soon
  3. Nov 21, 2018 at 6:33 AM
    #1723
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    @roguegs
    NCtaco914[QUOTED] likes this.
  4. Nov 21, 2018 at 9:01 AM
    #1724
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    I don't think I am sitting at 3" up front but I am clip 4/3 I believe with 700lb springs.
  5. Nov 21, 2018 at 9:04 AM
    #1725
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Winch, bumper, skids?
  6. Nov 21, 2018 at 9:05 AM
    #1726
    roguegs
    Angelo
    V8 T4R
    Dual batteries on driver's side, steel skids from Mobtown, sliders
  7. Nov 21, 2018 at 9:09 AM
    #1727
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Any regrets vs 650lb?
  8. Nov 21, 2018 at 9:10 AM
    #1728
    roguegs
    Angelo
    V8 T4R
    I made the jump right from 600 to 700 but to be completely honest I can barely tell a difference but that might just be me. At the same time I also took the front sway bar off so the 700s helped with that.
  9. Nov 21, 2018 at 9:23 AM
    #1729
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Good to hear, I've been running the 600's with no sway bar from the start. Thanks for the feedback :thumbsup:
  10. Nov 23, 2018 at 10:07 AM
    #1730
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    About 3/4th of the way done reading through all the pages.
    (3rd gen) Got 6112s, 5160s, and Icon AAL on the way. Will be setting at 6/5. I’d prefer for it to be a bit stiffer. I’m undecided about leaving overload in or taking it out. I keep my RTT on 24/7 but other than that no weight besides gear when I go camping. The last thing I want is bro lean. Most likely will leave it in to maintain rake. 265/75/16 wildpeaks going on today!
  11. Nov 23, 2018 at 10:14 AM
    #1731
    roguegs
    Angelo
    V8 T4R
    Leave the overload in If the tent stays on indefinitely. I had the progressive leafs from Icon as well without the overload and I sagged hard after a few months.
    oscolivar1 likes this.
  12. Nov 23, 2018 at 10:25 AM
    #1732
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Please keep the overload! I made that mistake...now I have a full leaf pack.
  13. Nov 23, 2018 at 10:33 AM
    #1733
    barretta
    barretta -
    San Clemente, CA
    Copy that! Overload will stay in. Thanks guys. I will post my results when I have it installed!
  14. Nov 24, 2018 at 6:57 AM
    #1734
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Just to pile on, I’ve done the same as you....6112 at 5/6, 5160s, icon aal, falken 32’s. I have the bro lean with the overload out, even with my winch weighing my front down 1/2”. I’m considering either going Dakar, putting the overload back in, or dropping the front to 4/5. The pic was right after the lift, was hoping the front would settle, but the rear ended up settling more so it’s worse than the pic now. Decisions decisions
    barretta and oscolivar1 like this.
  15. Nov 24, 2018 at 7:01 AM
    #1735
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Put the over load back in first....then buy the dakars if you don't like it....imho
    Turd Hawg, oscolivar1 and ejewels like this.
  16. Nov 24, 2018 at 7:24 AM
    #1736
    CaTaco101
    CaTaco101 Well-Known Member
    California
    '13 TRD Off-Road PreRunner
    Planning on getting 6112/5160 paired with Dakar medium leafs. Will be installing on a 2013 TRD OR prerunner.
    2 part question:
    - Which setting to keep near factory rake paired with Dakar’s?
    - Which setting to keep the lift at or under 2”?
    Keep in mind I have a pre-runner and only a snugtop rebel for mods/extras. Thanks
  17. Nov 24, 2018 at 7:36 AM
    #1737
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Overload should give you almost .5” of lift or so. What happened with me and had my overload leaf out and sagged considerably. I’m now on RXT leaf pack. Expensive decision but worth it.
  18. Nov 24, 2018 at 8:04 AM
    #1738
    barretta
    barretta -
    San Clemente, CA
    Looks great in the front. Can’t wait. How much lift did you get in the front on 6/5 with that winch weighing you Down?
  19. Nov 24, 2018 at 8:33 AM
    #1739
    Turd Hawg
    Yep, I think you're right. I also have archive hangers coming that will add ~3/8", I think that combo will put me where I need to be. After poking around about using an overload and an aal, I'm going to cut the overload back to just shy of the smallest aal.
    Added exactly 2"
    barretta[QUOTED] likes this.
  20. Nov 24, 2018 at 8:36 AM
    #1740
    barretta
    barretta -
    San Clemente, CA
    How nose high are you? Making me concerned that I’ll be nose high at 6/5 even with the overload since I don’t have a winch...
