Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jan 23, 2019 at 11:22 AM
    #1941
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    If you can afford them, get them. If not, don't sweat it at that setting. I was able to get ~2.3* Caster out of my stock UCA's at #3.
    The biggest problem is that the stock UCA's will limit your down travel. So there's more than just alignment benefits to upgrading. I'll be upgrading mine this year hopefully.
  2. Jan 23, 2019 at 11:34 AM
    #1942
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Your Off-roading and worried about alignment....means you get UCAs. Save the extra 400+
    iK0NiK likes this.
  3. Jan 23, 2019 at 11:38 AM
    #1943
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    2016 Tacoma TRD OR 4x4 DCSB
    I can afford it, but it will put a different mod on hold. However, I would rather do this all at once, so if people are recommending them for function I will probably add them in. What UCAs are you looking into? I haven't done my research on what type I should go with yet. I know there are different types of joints and some that are more adjustable.
  4. Jan 23, 2019 at 11:47 AM
    #1944
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Get either JBA or SPC
    oscolivar1 likes this.
  5. Jan 23, 2019 at 11:49 AM
    #1945
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
  6. Jan 23, 2019 at 11:50 AM
    #1946
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    Thanks! Looking into those.
  7. Jan 23, 2019 at 11:50 AM
    #1947
    iK0NiK
    West
    Columbus, GA
    I'll be going with JBA, personally.
  8. Jan 23, 2019 at 12:13 PM
    #1948
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    Looks like main differences are:
    JBA allows a bit more down travel (10 degrees more)
    SPC has more adjustability for camber/caster
    My truck went out of alignment in stock configuration which makes me lean towards SPC, but more travel is always nice.
    maui3rdgentaco and oscolivar1 like this.
  9. Jan 23, 2019 at 12:23 PM
    #1949
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Just make sure you find a shop that knows how to adjust SPC UCAs. That’s the biggest con of them. Some alignment shops have no clue. Just a heads up, otherwise they’re a good UCA.
    I have JBAs
    BFT18[QUOTED] likes this.
  10. Jan 23, 2019 at 12:41 PM
    #1950
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    :cheers:
    Casper66[QUOTED] likes this.
  11. Jan 23, 2019 at 12:42 PM
    #1951
    boostedka
    James
    NM
    That's pretty much it. What's also different about the newer SPC's is they are a fully forged unit now. As @oscolivar1 said, make sure you have a shop that knows how to align with those arms though if you go with SPC. Many people go with the JBA's since they have a set amount of caster and camber making them less likely for the alignment tech's to eff it up. Either way they are both proven arms that you'll be happy with.
    BFT18[QUOTED] and oscolivar1 like this.
  12. Jan 23, 2019 at 12:43 PM
    #1952
    beers@1600
    Have you ever had issues getting the JBA's aligned?
  13. Jan 23, 2019 at 1:04 PM
    #1953
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
  14. Jan 23, 2019 at 2:08 PM
    #1954
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Very cool! I know I'll never be able to remember where this post was but I will remember when I order the 6112's to call wheeler's. Thank you sir! I have had great luck with my 5100's with Eibachs may as well keep the trend going. Getting ready to revamp the rear suspension and Im just starting to get my info together for the front perhaps later this year. This was just what I needed :hattip:
    beers@1600[QUOTED] likes this.
  15. Jan 24, 2019 at 1:45 PM
    #1955
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    Does anyone know who has the 6112's in stock for 3rd gens?
    bunz559 likes this.
  16. Jan 24, 2019 at 1:51 PM
    #1956
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    I've called most of the larger and more popular retailers and had no luck. I finally got a hold of Mike ORW on Facebook this past Tuesday and he had 1 set left which was a display. So I picked them up. His distributors are out unfortunately. Unless there's a shop that doesn't advertise through social media much or through the forums, chances are they've been contacted and have sold out. But I'd say stay percipient on contacting them. There are sooo many folks always asking and if you're late to their supply, you'll be waiting again.
  17. Jan 24, 2019 at 3:31 PM
    #1957
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    I just lucked out and found a pair (last one) in Washington.
    I forget where I was reading about driver side spacers, but can anyone confirm the size I should be looking for to compensate for lean on 3rd gen DCOR 4x4? I believe I was seeing 3/8" ?
    bunz559[QUOTED] likes this.
  18. Jan 24, 2019 at 3:34 PM
    #1958
    bunz559
    Fresno, CA
    I thought I've seen folks talk about the 1/4 spacer. But do you not want to stagger the 6112's? Cause you can do that to compensate for the lean.
    boostedka likes this.
  19. Jan 24, 2019 at 3:40 PM
    #1959
    boostedka
    James
    NM
    That's what I did on my 2nd gen and it's within 1/8" from left to right.
  20. Jan 24, 2019 at 3:58 PM
    #1960
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Try eBay
