Bilstein 6112s with 700lb Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotatotaco77, Mar 4, 2019.
  1. Mar 4, 2019 at 10:22 AM
    yotatotaco77
    yotatotaco77 [OP] Well-Known Member
    Southern Oregon Coast
    2011 Tacoma TRD off-road extended cab
    Bilstien 6112s with 700# springs ARB Deluxe Bull Bar 9k winch Bilstien 5160s Icon progressive 3 leaf AAL
    Hey guys, just like the title says, I'm running the Bilstien 6112s up front with the 700# 14" springs. I have the the 6112s set at the 5th notch, as suggested by the retailer where I bought them. Which gives me about 5.5 inches of lift. To much lift. Im wanting about 3" or 3.5". Anybody running this same setup? And if so what notch are you at? Did you set the driver side 1 notch higher than the passenger to counter the taco lean? The 6112s come with 600# 13" springs but I upgraded to counter the wieght of my ARB bumper and winch. The lift has been on for almost 6 months now, so any "settling" should be done. Any info you guys have would be great. Thanks
    Update: Just to save you time if your interested in running this same combination. Don't. If your needing some higher spring rate springs, go with the Bilstein 650# springs. Part number 53-291387. Hope this saves you some time instead of reading this whole thread.
  2. Mar 4, 2019 at 10:50 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    I'm looking at the same question, my 6112's are on the forth notch and have sagged a little, hoping a 14 king springs could be used at lower perch and stay at @3 inch lift (600-650) range no heavy bumpers in near future.
  3. Mar 4, 2019 at 1:23 PM
    Taco-Obsessed
    5.5 inches? That doesn't sound right.
    @roguegs
    jp59inh, lynyrd3 and Stryker420 like this.
  4. Mar 4, 2019 at 2:02 PM
    yotatotaco77
    Yeah, it's about 5.5" right now, stock height before the lift, from bottom of fender flare to hub center was 20 1/4" DS, Currently roughly 25 1/4" DS, give or take from the way its sitting now. When I first installed the 6112s it gave my truck a massive bro lean, even though the rear already had 2" of racke stock. So I just want to know which clip setting to go to to get the 3" 3.5" range. I'm taking it to a shop to get done, so I'm hoping for a one and done fix. I don't want to take it in 2 or 3 times to get it right, I'd rather take it in once and be done. So I don't have to pay for it 2 or 3 times and set up multiple appointments yadda yadda yadda....
  5. Mar 4, 2019 at 2:23 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you have ANY droop at all? 5.5in of lift is WAY too much, your poor CV's if you are 4x4 are not gonna live long. 600# to 700# springs that are an inch longer.... those 6112's are not going to be valved properly for that much spring. Id say go back to 600# springs so you get the standard lift amounts per clip.
    lynyrd3 likes this.
  6. Mar 4, 2019 at 2:45 PM
    yotatotaco77
    According to Wheeler offroad, the 6112s should be fine with 700# springs, its just they are set at way to much preload on the 5th clip, and yes there is a a lot of angle on my CVs hence why I want to lower it back down a bit and on my UCAs well, at full droop they contact the spring, so I just want an educated guess on what clip setting to set them at, so I don't have to remove them and do it again.
  7. Mar 4, 2019 at 2:46 PM
    Tomshouse516
    Tomshouse516 Well-Known Member
    Thomas
    Doylestown, PA
    11 DCSB TXtrd
    33's and some stuff
    It seems to be loosely 1" of lift per 1/2" of adjustment to shock length. So if you want to go down 2" you want the clip roughly 1" lower on the shock.
    This is assuming your shock is not currently topped out at ride height by using a longer and higher rate spring. you might want to error on the side of caution and lower the adjuster 1.25"-1.5".
    An alignment will be needed and at 3" of lift if you have original upper control arms you will not be able to get your alignment back into stock spec
    twblanset likes this.
  8. Mar 4, 2019 at 2:49 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
  9. Mar 4, 2019 at 2:55 PM
    yotatotaco77
    Ok, that makes sense, being i am running the longer 700# springs. Maybe drop down to the 1st or 2nd clip setting. But oddly enough I just had it aligned and everything went right back to spec, according to the tech at the dealership. He just warned me that I may have premature wear on my CVs at the height.
  10. Mar 4, 2019 at 3:03 PM
    Tomshouse516
    Thomas
    Doylestown, PA
    11 DCSB TXtrd
    33's and some stuff
    I would just measure from where the clip is now down 1"-1.5" and move the clip to the closest notch to that.
    It is not guaranteed to be exactly where you want it but should get your close.
    At the amount of lift you have your CV's and upper ball joints are not happy.
  11. Mar 4, 2019 at 4:02 PM
    Taco-Obsessed
    Wheelers off road site says they give .5-2.5" of lift
    I don't think 5" is possible with these
    I'd love to see a photo.
    I'm looking into getting these so I'm interested overall.
    Stryker420 likes this.
  12. Mar 4, 2019 at 4:12 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    5 inches....don’t see your boots surviving long
    Photos would be nice
  13. Mar 4, 2019 at 9:05 PM
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Southwest Montana
    20 TRD Offroad, 19 4Runner Premium SR5
    Heated seats, It's Montana
    6112's #5 notch @600#, front plate bumper, w/winch on a 2.7 4x4. I feel I'm still slightly high by about .75" in the front. Also running a/p expo leaf pack in the rear with 5125's.
    The 600# are enough for what I use my truck for. I may drop down to the 4/3 setting.
    I was using before the current change 5100 eibach 521-600 5th notch w/.375 top spacer which was sitting even lower with spring sag
  14. Mar 4, 2019 at 10:08 PM
    yotatotaco77
    The height quote for these on the wheelers off road site is for the standard 600# springs. I have the 700# springs, so it's not going to be the same. The only reason I went with the 700# springs was because I emailed and spoke to many different online retailers including Headstrong off road, and wheelers off road and a few others. They all had the same thing to say, because I have an ARB front bumper and winch I should consider upgrading to a higher spring rate spring. And since I'm no expert, and since I consulted said "experts" I went with their advice and upgraded
  15. Mar 4, 2019 at 10:11 PM
    yotatotaco77
    Yeah, I was originally going to just buy the stock 6112s, with the 600# springs, but multiple online retailers advised I upgrade to higher spring rate springs, to achieve the 3" lift I wanted with my bumper and winch.
  16. Mar 4, 2019 at 10:16 PM
    yotatotaco77
    Yeah, sorry, I'll get some pics in the morning. And no, my CVs wont be lasting very long at all. When I took my truck in to get an alignment, the tech called me back and warned me that at that high of lift, it's going to be putting a lot of strain on my CVs. He advised I either lower it down or get a diff drop kit. I have heard that the diff drops aren't really worth it so I'm going to have the 6112s adjusted instead.
  17. Mar 4, 2019 at 10:28 PM
    ruffridha9
    ruffridha9 Well-Known Member
    Jesse
    West Coast
    2012 Tacoma base
    stock ish
    I’d like to see 5.5 inch lift on these if you have a pic handy.
    I have the second gen version of these topped out at the highest setting and I’m at just over 2” - But standard 600 lbs.
    Edit- ahh nevermind
  18. Mar 4, 2019 at 10:34 PM
    Taco-Obsessed
    Good luck OP. Keep us posted. Looking forward to pics. Have you reached back out to the dealers you spoke too and told them how much damn lift you got?
    I'm no expert either, but if you got that much with the combo and you go to a lower notch.. it would lower but I'm curious about ride quality? As cush as it should be? How is it now? Seems you don't have enough weight which seems off with an ARB bumper.
    There are other 6112 threads that you would get more responses from people with them and most likely with 700 coils too. If you can't find them let me know.
    Aww screw it @la0d0g seems to be a go to guy on this stuff. What ya think?
    la0d0g likes this.
  19. Mar 4, 2019 at 11:02 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    I've got 6112 with 700 lb springs that are getting installed next weekend I'm doing lowest setting so I'm don't have a preload on the shocks also running maxtrac spindles I'm trying to stay under 4"
  20. Mar 4, 2019 at 11:49 PM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    I'm at about 3.5" and its not all its cracked up to be.
    oh. doh....i'm sorry...wrong topic.
