Bilstein Coils
Discussion in 'HeadStrong Off-Road' started by 2k4Taco, Nov 14, 2017.
  1. Nov 14, 2017 at 1:42 PM
    2k4Taco
    2k4Taco [OP] IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Just curious if the coils in the
    Performance Bilstein Kit (HS16BK-2) will hold the weight of a front bumper?
  2. Nov 14, 2017 at 1:44 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Bilstein.. Stupid auto correct...
  3. Nov 14, 2017 at 1:46 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  4. Nov 14, 2017 at 2:00 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Figured out how to edit the title.. haha.
    HeadStrong Off-Road likes this.
  5. Nov 14, 2017 at 2:04 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Now all springs, whether it is a coil spring in the front or leaf spring in the back are directly affected by weight. So it all comes down to how much weight is being added. The lift spec'd out for the different notch settings are based on the that trim of truck with stock weight so you will see less lift from the 6112's then what they spec out at if you add in front weight.
    Since the 6112’s are a strut and lift coil combination with a coil supplied from Bilstein, coil changes are harder with this type of suspension. The shocks themselves are not fully adjustable so it would be hard to say how much lift each notch setting would provide, how stiff the ride would be with the coil change on the various notch settings, how the coil change would affect the cycling of the shock and/or if you would run into any potential coil bind issues. Since these are variable that we cannot account for and have not tested for we do not recommend coil changes with the 6112’s.
    Please let me know if there is anything else that I can assist you with.
    Thank you so much.
    Bravisimo likes this.
  6. Nov 14, 2017 at 2:11 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Thanks Marie!! It looks like I'll end up with the ARB nitros. They offer more of an option with coil selection for the added weight.
  7. Nov 14, 2017 at 2:18 PM
    HeadStrong Off-Road
    Sounds good. If you need anything else let me know :)
