Bilstein lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by zshred199, Jul 19, 2011.
  1. Jul 19, 2011 at 9:58 AM
    zshred199
    zshred199 [OP] Member
    Zach
    Santa Rosa California
    2002 Toyota tacoma Prerunner 4cyl
    Can I run bilstein 5100's with 3" setup with rear add a leafs and then run a body lift to get a total of 5.5-6" inches?
  2. Jul 19, 2011 at 10:20 AM
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
    if 5100's are at 0" lift...then probably...but avoid the body lift and spacer idea and do it right.
  3. Jul 19, 2011 at 1:39 PM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    body lifts are for noobs...
  4. Jul 19, 2011 at 2:17 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Wrong. 5100's CAN be used for 0" and up to 2.5" of lift. There's a little clip that moves up and down the shock body to preload the factory spring and set ride height.
    You can also get eibach springs and set the 5100's at 0 and obtain 3" of lift. Its a very economical setup and performs great and by no means a "wrong" lift.
    You are right about the body lift part though.
  5. Jul 19, 2011 at 8:42 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    does a 1'' body lift be as bad just to get tire clearance?
