Bilstein.....
Discussion in 'Suspension' started by Tacoma414, May 28, 2011.
  1. May 28, 2011 at 3:23 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    i need help with what to do for better suspension, i have an $800 price range,
    1. Bilstein coil overs in the front and stock back
    2. IDK
    3. IDK
    any other options?
    long travel is a possibility but it couldnt be over $800
    thanks guys i appreciate it
  2. May 28, 2011 at 3:28 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    "long travel is a possibility but it couldn't be over $800"
  3. May 28, 2011 at 3:46 PM
    Tacoma414
    Cody
    Agua Dulce
    couldnt be over? or under?
    and also its an everyday drive with once in a while off roading
  4. May 28, 2011 at 3:47 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    it'll be more than $800 for long travel, much more.
  5. May 28, 2011 at 3:56 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    OME, you may also need UCAs
  6. May 28, 2011 at 4:23 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Not tryin to be an ass but lt would be in the 100 dollar range. Oh wait add two 0's to the end of that....
    My suggestions would be a complete old man emu set up. Do a quick search and you'll find what you need. If you have any questions about that set up in particular ask back here and we'll be sure to answer your questions.
  7. May 28, 2011 at 5:42 PM
    Tacoma414
    Cody
    Agua Dulce
    Well it's an everyday drive with my truck, I mean long travel is so sick with flarred fenders but what do you guys think about the bilstein 5100 coil overs in the front set at 2.5 and stock bilstein in rear, cause people Reccomend those for what I'm doing, I'm just done with my 2" spacer lift in the front
  8. May 28, 2011 at 6:24 PM
    Tacoma414
    Cody
    Agua Dulce
    Not even close to a bro! Hahaha but I think the bro lean looks good on access cabs, and do you Elbach coils?
  9. May 28, 2011 at 8:08 PM
    Tacoma414
    Cody
    Agua Dulce
    So it's worth the little extra money for the elbachs, and yeah I dont want to deal with those problems either, and keep the back stock? Or do something there to
  10. May 28, 2011 at 8:10 PM
    Tacoma414
    Cody
    Agua Dulce
    And what's the .5 your talking about?
  11. May 29, 2011 at 9:16 AM
    Tacoma414
    Cody
    Agua Dulce
    Oh I'm running 33" yokohoma geolanders, so that would be my .5 of the lift?
  12. May 29, 2011 at 10:51 AM
    Tacoma414
    Cody
    Agua Dulce
    so eibach makes coil over kits for tacomas? or do you have the springs
  13. May 29, 2011 at 10:56 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I've seen Eibach Adjustable C/Os with Bilstein Shocks.
    And Wolfpack has just the Springs
  14. May 29, 2011 at 10:58 AM
    ColtsTRD
    Scott
    AZ
    FWIW, I'm running OME 885s with 5100s all around, a 2" Toytec AAL and Light Racing UCAs. You'd need new UCAs for this lift which would put you in a over 800 bucks
  15. May 29, 2011 at 11:13 AM
    Tacoma414
    Cody
    Agua Dulce
    do you like how it rides on and off road? cause im thinking about that set up, except the AAL in the rear, and will i need the UCAs if i dont go to 3?
  16. May 29, 2011 at 1:25 PM
    ColtsTRD
    Scott
    AZ
    I love the ride on and off road! And your gonna be WAAAY high up front if you don't do something with the rear. You only need aftermarket UCAs if you go higher than 2.5"
  17. May 29, 2011 at 2:08 PM
    Tacoma414
    Cody
    Agua Dulce
    No I'm going to 2.5 so I don't need UCAs
  18. May 29, 2011 at 2:13 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Some do, some don't @2.5"
  19. May 29, 2011 at 2:16 PM
    jcremeans11
    jcremeans11 Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    If you like the look of the long travel's fenders, then just get the fenders and a $400 lift, and wheels with a negative offset to give you that wider stance. I mean its a little gay to have long travel fenders without long travel, but if you like that look, it's your truck, go for it
  20. May 29, 2011 at 2:20 PM
    ColtsTRD
    Scott
    AZ
    thats true, some guys get lucky... ;)
