Bilsteins 1.75 damage front suspension?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Feb 1, 2012.
  1. Feb 1, 2012 at 7:29 AM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Do bilsteins set at 1.75 in the front cause damage to the front suspension? I have heared of it causing bearing damage and front differential damage.
  2. Feb 1, 2012 at 7:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It causes the CV joints to operate at a different angle and could potentially cause them to wear out quicker. With that small of a lift, you shouldn't run into any real issues but the risk is always there whenever you modify your stock suspension.
  3. Feb 1, 2012 at 8:00 AM
    Scubasteve4533
    Scubasteve4533 Well-Known Member
    Ohio
    11 TRD OR
    5100 @ 1.75, tsb rear springs with 5100. anytime fogs, rear diff breather, 50 cal ammo boxes on bed rails
    You will also probably fatigue the hell out of your springs alot faster... I've been looking into a set up eibach springs b/c my OR progessive springs ride like junk set at 1.75
