Bilsteins 5100 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sblspawn, Dec 12, 2018.
  1. Dec 12, 2018 at 12:45 PM
    sblspawn
    sblspawn [OP] Well-Known Member
    Hollywood, Florida
    2015 Toyota Tacoma Prerunner V6
    MaxTrax Spindles, Bilstein 5100, OME 883, JBA UCAs, HS 3 leaf progressive AAL with Overlord, Bilstein 5125 rear shocks, 2 inch MaxTrax block, Spidertrax Wheel spacer in the rear, Ironman 285/75r16
    Guys, I just ordered the adjustable 5100 and they should be here in 2 or 3 weeks. But once again I need some advices from the smart people of Tacomaworld. I have a question; What is the best way to get 1 inch or 1.5 inch of lift from the 5100 without sacrifice to much ride confort? I don't want them to be too stiff!
    Biscuits likes this.
  2. Dec 12, 2018 at 12:53 PM
    07sr5
    07sr5 Well-Known Member
    2007 4x4 Double Cab
    88DBB232-0EFA-4A82-B802-7D7B8CA2F64E.jpg I would set them at 1.75 and call it done. Mine are set at 1.75 with 1/4” top plate spacers on both sides to bump it up a little past 2” of lift and in my opinion the truck rides very comparable to stock.
    sblspawn[OP] likes this.
  3. Dec 12, 2018 at 1:13 PM
    sblspawn
    Hollywood, Florida
    My truck is lifted 4 inches with Maxtrac. I'm just looking for 1 or 2 inches more, but I'm afraid that setting the 5100 to 1.75 will stiff the suspension too much. I've seen some people saying that around here, I don't know, I never had Bilsteins before. How do you feel the suspension when going over a bump?
  4. Dec 12, 2018 at 1:31 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    2013 Super White Tacoma DCLB TRD SPORT
    Sport or Off-road model?
  5. Dec 12, 2018 at 1:31 PM
    devkurf
    devkurf Member at Large
    midwest
    I dont know anything about Maxtrac lifts, but mine rides great at 1.75" with a 2" single AAL in the rear. I cant compare to stock, cause by the time I got the truck, the stockers were shot. In my experience the best thing I did as far as ride quality was to go from load range D to SL tires as far as soaking up the bumps.
  6. Dec 12, 2018 at 1:32 PM
    devkurf
    midwest
    Good point, mine is a SR5, so I think my spings are softer than a TRD.
  7. Dec 12, 2018 at 1:34 PM
    TegoTaco
    Ontario, Canada
    On my Sport, have my 5100’s set at 2.5” and the ride isn’t harsh at all, even on my e-rated tires. :) Coming from a former Acura TL owner lol.
  8. Dec 12, 2018 at 1:36 PM
    sblspawn
    Hollywood, Florida
    Prerunner Sr5
  9. Dec 12, 2018 at 1:38 PM
    sblspawn
    Hollywood, Florida
    Wow! That's good to know, man!
    cleats50 likes this.
  10. Dec 12, 2018 at 1:39 PM
    sblspawn
    Hollywood, Florida
    Awesome! You are the second person recommending the 1.75 set. My tires load is E.
  11. Dec 12, 2018 at 1:45 PM
    07sr5
    2007 4x4 Double Cab
    It rides great in my opinion and is not stiff at all. A bump is still a bump, but what else can you expect with a budget suspension lift. Gotta pay to play man
  12. Dec 12, 2018 at 1:50 PM
    sblspawn
    Hollywood, Florida
    Maybe I can set the bilsteins to 0 and find some OME coils. But I don't know wish one could give me the lift that I want.
  13. Dec 12, 2018 at 1:54 PM
    07sr5
    2007 4x4 Double Cab
    I’d assume the 883s would be what you want, but i have no experience with ome so don’t quote me
    sblspawn[QUOTED][OP] likes this.
  14. Dec 12, 2018 at 2:16 PM
    sblspawn
    Hollywood, Florida
    Nice! Thanks a lot, man! So, the OME 883 with the 5100 set to 0 should be a better choice than the bilsteins set to 1.75, theoretically!
  15. Dec 12, 2018 at 2:43 PM
    devkurf
    midwest
    The OME shocks would be better with the OME coils if you arent going to use the 5100's to gain lift from what I've read here, there's really no advantage to having them.
  16. Dec 12, 2018 at 2:48 PM
    devkurf
    midwest
  17. Dec 12, 2018 at 3:02 PM
    sblspawn
    Hollywood, Florida
    The OME 883 with bilstein set to 0 will lift the front between 1.25 and 1.5 inch.
  18. Dec 12, 2018 at 5:48 PM
    devkurf
    midwest
    I believe the OME shocks are better valved for the OME spring rates I could be wrong. With the 5100 set at 0 is still a good shock, but there is no need for an adjustable shock if you are going to leave it on the bottom setting other than having the option of being able to move it up later.
  19. Dec 12, 2018 at 6:02 PM
    sblspawn
    Hollywood, Florida
    The price was good! :) $160 the pair brand new! That's why I bought them! That and the option to use them to gain a little bit more of lift. But I want the front suspension to be in the softer side! This is why I asked for the best way to gain a little bit of lift avoiding excessive stiffness.
  20. Dec 13, 2018 at 12:57 AM
    TT-Tacoma
    TT-Tacoma Member
    Taylor
    2006 Tacoma TRD OR DCSB
    Bilstein 5100's, Wheelers AAL, 285/75/17's
    2006 TRD OR DCSB 4x4. I have 5100's front and rear. Fronts are set at max 2.25" with stock coils, rears are standard length with wheelers 1.5 progressive AAL.
    I started at 1.5" in the front and tsb rears. Then moved the front down to .85" after the springs sagged. Was like that for about a year and then moved it back to 1.5" when I got bigger tires and rear air bags. Was like that for a few months and then got bigger tires in load range E and moved the front to 2.25". I didn't like using my air bags for the extra lift so added the AAL. I thought the front was maybe a little stiff but after I think it's perfect. The 5100's are great shocks
