Bilsteins and Rough Country Suspension
Discussion in 'Suspension' started by mdub, Nov 5, 2009.
  1. Nov 5, 2009 at 10:21 AM
    mdub
    mdub [OP] Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    Need your help please.
    I have the Rough Country 2.5" suspension lift on my truck right now. http://www.roughcountry.com/toyota_95-04_tacoma_2.html
    I am going to need new shocks soon and I want to go with the Bilstein 5100's on all 4 corners http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html
    So, Here are the questions.
    1. If I get the adjustable 5100's in the front, do I just remove the 2.5" Easy Lift strut extension that came with the Rough Country and then just set the lift of the Bilsteins to the equivelant of the 2.5" strut extension and pull out the strut extender? (stock springs on there as far as I know)
    2. For the rear, since there is a 1.5" shackle lift is there going to be any issue with bolting on the Bilsteins out of the box?
    Any issues you forsee? I'll do all the work myself, except compress the springs. I'll pay a shop to put them in a wall press and put the new shocks in.
    Thanks!
    M
  2. Nov 5, 2009 at 10:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    :thumbsup:
  3. Nov 6, 2009 at 8:27 AM
    mdub
    Missouri
    ARE CX
    So, I'm wondering, about the 5100's and setting it to 2.5 inches of lift. What does that do to the spring? And what does that do to the performance of the shock itself?
    Do I need to get a new spring than the stock that is on there?
  4. Nov 6, 2009 at 8:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It pre loads the spring to get lift. OEM spring should be fine, unless its worn out. If its worn out, you can replace them with an OME spring (880, 881, or 882 for heavy duty apps).
  5. Nov 6, 2009 at 8:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Chris, is he going to need an extension for the rears because of the shackle lift?
  6. Nov 6, 2009 at 9:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I belive so.
  7. Nov 6, 2009 at 9:03 AM
    mdub
    Missouri
    ARE CX
    What and where for the extension for the back?
  8. Nov 6, 2009 at 9:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's what I was thinking.
  9. Nov 6, 2009 at 9:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, the rear shock. They look like this
    I just did a Google search for Billstein Shock extension.
  10. Nov 6, 2009 at 9:32 AM
    mdub
    Missouri
    ARE CX
    Not trying to be an idiot here.... but that extension. Where does in mount? To the shock? Or does it mount to the frame where the current shock is mounted?
    Thanks!
  11. Nov 6, 2009 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    HAha, disregard. They would screw onto the end of the shock shaft, but I forgot that first gens have a different style. You won't need that type of extension. You may want to just give downsouth a call and see what they say.
  12. Nov 6, 2009 at 9:43 AM
    mdub
    Missouri
    ARE CX
    Cool! Thanks!
