Bilsteins in the front to improve ride?
Discussion in 'Suspension' started by Zanone_taco, Oct 21, 2016.
  1. Oct 21, 2016 at 3:17 PM
    Zanone_taco
    Zanone_taco [OP] Tacoma bruhhh
    Blane
    Humboldt county
    2010 white access cab Trd off-road
    Need more...
    Hey guys I've got a 2010 trd off road package tacoma, and i want to give my front end a lift of about 2 inches, but also want the ride of my truck improved. Im wondering if i can just get a pair of the bilstein 5100 front shocks with adjustable height and it will improve my trucks ride? or do i also need to get the back, right now i have the stock bilstein Toyota series shocks, any help will be greatly appreciated!
    ChadsPride likes this.
  2. Oct 24, 2016 at 8:19 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Hey man. You could just buy new coils and install them on the front struts to get the lift, and leave the rear alone. We sell 2" comfort ride coils that will fit the OE struts. They're a better spring rate than stock, but will also provide lift, and give a great ride.
    Of course you can buy new struts too, just depends if you really need them yet.
  3. Oct 24, 2016 at 9:20 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    It will come down to how the truck is being used and how much you are looking to spend.
    Like @Dobinsons Mike mentioned, you can get some 2" coils and pair it with your stock struts.
    A lot of guys have gone the 5100 route and pair it with a OME 88* coil.
    If you want to go all out, you can get a set of King Coilovers!
    For you, I believe the Spring swap or 5100 w/ a Spring Swap will get you taken care of!
    Talk to @Dobinsons Mike or Marie @HeadStrong Off-Road
    If you want some King Coilovers, I can get you taken care of! :thumbsup:
  4. Oct 24, 2016 at 9:29 AM
    Zanone_taco
    Blane
    Humboldt county
    Need more...
    Sweet thank you guys, that's the most straight forward answer I've gotten on here!
  5. Oct 24, 2016 at 9:32 AM
    Zanone_taco
    Blane
    Humboldt county
    Need more...
    Thank you to ill make sure to look into that route also, If i were to buy the 2 inch coils would I eventually be able to pair those with a pair of 5100 bilsteins?
  6. Oct 24, 2016 at 9:35 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    I put 5100s paired with OME 884 coils on my 2009 over two years and the ride has been great. It was definitely an immediate improvement over my stock Off Road coilovers.
  7. Oct 27, 2016 at 10:41 PM
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    I took off my TRD sport shocks on my new truck at 750 miles. Replaced them with Bilsteins 5100's and 884's and I have 8000 miles on my truck. Made a big difference. You can really tell the difference if you do it when the truck is brand new.
  8. Oct 27, 2016 at 10:52 PM
    eon_blue
    eon_blue Most Improved Member
    As a general rule, if you rely on pre-loading (adjusting) your shocks to give you lift then your ride quality will suffer. Buy the right coils for your lift and you'll be much happier with the ride. OME makes several different coils of different lengths and spring rates, shop around for the ones that best suit your needs. 5100s set to 0" (or the equivalent in OME shocks) and the right set of OME coils for lift will give you a great ride. I have OME 881s and 5100s set to .85" and the ride is a tad stiff (because I pre-loaded the shocks) but I like it. When I had the 5100s set to 0, the ride was just as comfy as stock, if not better. I adjusted them because I needed a tad more lift up front to help match the rear.
    HeadStrong Off-Road likes this.
  9. Oct 28, 2016 at 6:55 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    We were closed for awhile so I hadn't seen these tags until now. if you still have some questions just let me know and I will do what I can help you out.
