Bilsten 6112 Install Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SeniorSpan, Apr 5, 2023.
  1. Apr 5, 2023 at 8:31 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    G'day all,
    Is it advisable/prudent to install sway bar spacers/relocation brackets, vs removing sway bar, when installing Bilstein 6112's or any other larger diameter than stock coil overs to eliminate any chance of coil over spring and sway bar contact or am I over thing the process?
  2. Apr 5, 2023 at 8:37 AM
    mhemberg
    mhemberg Well-Known Member
    2021 Tacoma TRD OR
    No need they clear fine
    na8rboy likes this.
  3. Apr 5, 2023 at 8:43 AM
    eurowner
    eurowner Duke Sky
    Scoty
  4. Apr 5, 2023 at 8:46 AM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    I'm running 6112's on the highest setting and I have not run into any issues with the Sway bar touching the springs at all.
  5. Apr 5, 2023 at 10:05 AM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Thank you for the replies, especially the TW link. Will read thru the 322 pages. I should've done better research.
    Cheers
