Bilstien 5100 @1.75 with vibes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdawg, May 25, 2011.
  1. May 25, 2011 at 4:45 PM
    cdawg
    cdawg [OP] Member
    Hello anyone. I just installed bilstien 5100's @ 1.75 and have a vibration, do you know what it may be and what I can do to fix it? 2006 quad cab with tsb. Any help would be appreciated.
    Craig
  2. May 25, 2011 at 4:56 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Has it been aligned ? Mine are at 1.75 with the TSB and a Toytec 1 1/2 AAL . 265/ 75 16s . no vibes. Just a little squirrly if you catch a rut in the road the wrong way !
    2008 access cab 4x4
  3. May 25, 2011 at 4:59 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    ive got 5100's @1.75 and a 1.5" aal and no vibes... when do you get the vibes, and see if it goes away if you switch to 4x4.
  4. May 25, 2011 at 5:14 PM
    cdawg
    cdawg [OP] Member
    Yes alligned, that's not the problem. it is a whrr....whrr....whrrr vibration that i feel in my foot and can hear. no other changes.
  5. May 25, 2011 at 5:16 PM
    cdawg
    cdawg [OP] Member
    I get the sound and vibes to 60kmh and I haven't tried 4x4 yet, but this is definately from the new 5100's
    cg
  6. May 25, 2011 at 5:21 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    some have an issue with a bad bearing on the axle.. and u don't hear it until it gets lifted (puts an angle on the axle) if it goes away when u go into 4x4 thats your issue.
    If your vib is only up to 60kmh then i dont think that is you issue. Maybe try double checking that you have everything tight? if everything checks out its probably just your alignment
  7. May 25, 2011 at 5:21 PM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    there are several threads on this...... I am having the same issue at 2.5 and with an 1.5 aal check out toytec for some axle shims and a driveshaft carrier bearing drop these might help and make sure your u joints are torqued to 75# i believe :D
  8. May 25, 2011 at 5:23 PM
    stevenstaco
    steven
    sacramento ca
    just caise it goes away when you put it in 4wd doesnt mean its your bearing for sure
  9. May 25, 2011 at 9:35 PM
    ShaneHD
    ShaneHD Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
  10. May 25, 2011 at 11:36 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    slam em all you want but after i lifted my truck 1.75 with 5100's and had the vibe i got a diff drop kit and it went away
  11. May 26, 2011 at 4:04 PM
    cdawg
    cdawg [OP] Member
    Could you send me the link of the diff drop kit you went with? it would be much appreciated, how hard is it to put on?
    Cdawg
  12. May 26, 2011 at 4:06 PM
    cdawg
    cdawg [OP] Member
    You might be on to something, it does seem to go away in 4x4, but I need to do a more thorough check.
  13. May 26, 2011 at 9:36 PM
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    Hmm sounds like a spacer lift is better :/ jk
  14. May 26, 2011 at 9:47 PM
    Man of War
    Man of War Well-Known Member
    So Cal
    What... it's a Tacoma
    "Winner... Dah"
    I have the same setup.
    Billys @1.75" stock springs and Wheelers 3 leaf progressive AAL, with Light Racing UCA's, and 265-75-16 Falkin Wild Peaks,
    This is an awesome setup,
    ZERO vibrations, Alignment is spot on, No rub with stock rims (32" tires), wheels off-road great, rolls the freeway without wondering, 30K miles a year on truck.
    I would like to move the front suspension to 2.5 " but it's runs so great now I wouldn't want to screw it up.
  15. May 29, 2011 at 7:37 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
  16. May 29, 2011 at 7:59 AM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
  17. Oct 27, 2014 at 8:41 AM
    ogrady67
    ogrady67 New Member
    shawn
    akron,oh
    06 crewcab trd
    Ya me to! got aligned.rotated tires. still there
  18. Oct 27, 2014 at 11:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    nice thread dig!!!!
    find the East Coast Gear Supply bushing thread.... get the 60 dollar bushing problem solved.
  19. Oct 27, 2014 at 11:43 AM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    Pinion angle? Had this on my 05 double cab. You may need shims to offset the lift
  20. Oct 27, 2014 at 11:43 AM
    DylansBase
    Dylan
    Murfreesboro TN
    Have you lifted the rear at all?
