bilstien 5100
Discussion in '1st Gen. Tacomas (1995-2004)' started by firstyota, Nov 2, 2013.
  1. Nov 2, 2013 at 8:16 AM
    firstyota
    firstyota [OP] Member
    ken
    oregon
    03 Tacoma SR5
    Deck plate mod
    does any one know if i can run the bilstien 5100 adjustable shocks with the spring spacers i already have installed. and if so will it give me 2 more inches of lift.
  2. Nov 2, 2013 at 8:25 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    I wouldn't. Bilstein specifically says NOT to do that lol. Your ball joints will explode!
  3. Nov 2, 2013 at 11:09 PM
    firstyota
    ken
    oregon
    03 Tacoma SR5
    Deck plate mod
    hey zachary i am gunna go with the blistein 5100 and eibach springs. Would that set up give me more of a lift up front then the spring spacers that i have now??
  4. Nov 2, 2013 at 11:10 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Anyone else smell troll? This is the third thread this guy has started in like 10 minutes.
  5. Nov 2, 2013 at 11:14 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I don't think he's a troll yet... To answer this question OP, DONT STACK LIFTS! Either set the billies using the stock coils or if using the eibachs or OME coils I wouldn't go over .85.
  6. Nov 2, 2013 at 11:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    5100s with Toytec/Eibach coils should be set on the lowest seting.
    The is no .85" setting on 1st gen 5100s
    Are you a 4x4 or a prerunner. Cant tell from the stats you have listed for your truck. Also, you have not said how big a spacer you are currently running. In any case, using the spacer with the Eibach/5100s would be foolish.
  7. Nov 2, 2013 at 11:37 PM
    firstyota
    ken
    oregon
    03 Tacoma SR5
    Deck plate mod
    Hey im not trolling just have alot of questions about my truck i just bought it a few days ago and im new to the site an not sure how to find the threads im looking for. Having said that my truck is not 4X4. I havent listed the spacer size becuase im not sure what it is seems how i didn't install it myself. The reason i am asking about the lift i will get out of the 5100's is because the truck has AAL's and i dont want to get the springs and shocks just to find out the front will be lower than the rear. I apologize for all the threads i Have started. I appreciate the help guys!
  8. Nov 2, 2013 at 11:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You can pretty much guarantee that if you have a question about your truck, so have many others and the question has been asked before. Sometimes many times before. The 2 questions you have posted tonight are very common questions on here.
    Here is a thread that contains every question that has ever come up regarding 5100
    http://www.tacomaworld.com/forum/1st-gen-tacomas/176037-bilstein-5100-eibach-gallery.html
  9. Nov 3, 2013 at 8:40 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x2!
    Congrats on your Tacoma purchase, OP! If you haven't already done so, recommend you spend some time in the Suspension forum. Pay special attention to the Tacoma Lift FAQ/Guide and Suspension Lift Info threads.
  10. Nov 3, 2013 at 10:43 PM
    firstyota
    ken
    oregon
    03 Tacoma SR5
    Deck plate mod
    Thanks man i just found that part of the site and i have learned a lot already.
  11. Nov 4, 2013 at 5:33 AM
    zacharypaul89
    Zach
    Georgia
    If you're getting Bilstein's and Eibach's, you have to leave the shock set at 0". Now, if you use your stock springs with the Bilstein's, you can set the shock to 2.5", but I like the ride better with the Eibach's....plus, with the stock spring, it's really stressed at 2.5''.
