bilstien 5100s
Discussion in '5 Lug' started by Tour991, May 30, 2015.
  1. May 30, 2015 at 11:51 AM
    Tour991
    Tour991 [OP] Supplier of used parts
    James
    Zephyr Cove NV Lake Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited
    Hey guys I have a set of 5100s I was going to use on the rear my 97 5lug. They would work great for a 2nd gen. I took a picture of them next to my 4x4 rear 5100. You can see they are about 2.5 inches shorter witch is ideal for lenth for a 2wd. I'm asking $100 for them.
    y6piEV3XKnBofTElFwefzpCYGTcKDvP7wJpFOptL_1eb6847181bebfd70b3a5829337cb6a2d061ca3e.jpg
  2. Jul 28, 2015 at 6:31 PM
    Tour991
    James
    Bump!
  3. Aug 4, 2015 at 1:44 PM
    Rockreef
    Rockreef Well-Known Member
    San Diego
    A-Cab MT 4x4
    BUMP for a good guy. Very honest seller I will vouch for.
  4. Jan 19, 2016 at 8:30 AM
    Tour991
    James
  5. Feb 23, 2016 at 11:19 AM
    Tour991
    James
  6. Mar 1, 2016 at 3:07 PM
    Mexican5Lug
    Mexican5Lug Member
    99 Tacoma 2.4 L manual
    3" Fabtech lift spindles 2" lift schackles
    I don't think the 5100's fit 5 lug 1st gens. If you go on their website and enter that truck, it only gives the 4600.
  7. Mar 1, 2016 at 6:18 PM
    Bristow.907
    Bristow.907 Well-Known Member
    Onterrible
    07 AC sr5
    How much shipped to Ontario, Canada?
  8. Mar 1, 2016 at 6:42 PM
    Tour991
    James
    Can I get an address?
  9. Mar 26, 2016 at 6:25 PM
    Tour991
    James
    Bump! Still available
  10. Apr 1, 2016 at 4:24 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Op, 5100 makes to different rear shocks, is this for the 0-1" lift or the 3-4" lift? Can you post the part number?
  11. Apr 1, 2016 at 5:26 PM
    Tour991
    James
    Here is Bilstein Part Number: BE5-6582-H5 (24-185745) they are for older toyota trucks. But they fit perfictly on second generation 2wds with 1 to 3 inches of lift. as you can see in the picture they are side by side next to my 5100s on my 4x4
  12. Jun 28, 2016 at 1:02 PM
    5lugturtle
    5lugturtle Well-Known Member
    Conner
    San Diego
    2012 Silver Tacoma 5 lug regular cab 2x4
    Lift,31s
    Would it fit a readylift 2 gen 2012?
  13. Jun 28, 2016 at 1:22 PM
    Tour991
    James
    In the rear end yes
  14. Jun 28, 2016 at 1:28 PM
    5lugturtle
    Conner
    San Diego
    Lift,31s
    I am really noob at this stuff, but I am intrested as I am looking to upgrade the rear and the front. I have zero idea on how to even put them on and do it right. How new are they and would I need anything to replace them, tools,other parts, and is there anything else I should know?
  15. Jun 29, 2016 at 8:50 PM
    Tour991
    James
    Well for the rear they should be bolt on factory replacement. They are longer than stock so should accommodate your lift well.
  16. Jun 29, 2016 at 11:33 PM
    Blanco
    Blanco Active Member
    Anthony
    2007 5 Lug
    MB TKO Wheels, Pathfinder Sport SAT Tires, Kenmore Bluetooth Radio, Fat Bobs 2.75 Spacer, Rear AAL, Monroe Rear Shocks
    Would they fit on a fat bob 2.75 lift?
  17. Jun 30, 2016 at 10:36 AM
    Tour991
    James
    From all the research i'v done yes they will fit the fatbobs lift in the rear.
    Here are the lengths, if it the measurement fall in between it should work good.
    • Collapsed Length: 11.67" (296.50mm)
    • Extended Length: 17.95" (456.00mm)
  18. Jul 1, 2016 at 2:16 AM
    Blanco
    Anthony
    2007 5 Lug
    and those are the 5100s?
  19. Jul 1, 2016 at 2:16 AM
    Blanco
    Anthony
    2007 5 Lug
    or the 4600's
  20. Jul 1, 2016 at 10:53 AM
    Tour991
    James
    They are 5100, 4600s are yellow
