Bilstine 5100 only no other mods. Will I have problems
Discussion in 'Suspension' started by Tacomaratt, Feb 19, 2018.
  1. Feb 19, 2018 at 4:51 PM
    Tacomaratt
    Tacomaratt [OP] Member
    Brandon
    2013 sr 5 v6 4wd 4dr
    5100 bilstines in the mail. 30 inch led bar in lower grill
    i have read and searched a lot and there appears to be a lot of people getting vibrations with the bilstins set at 1,75. And a lot with out. I have a 13 double cab sr5 v6 and was wondering what everyone though should I try the 1.75. Or is the risk to high and I should just go .85. Truck is a daily driver. Tow my side x side on a trailer almost every weekend in the summer and sees some light off road at camp. Thank you all in advance
  2. Feb 19, 2018 at 4:53 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    They get vibrations because the needle bearing in the front diff is not designed for the axle angle change from lifting. When I did 1.75 about 2 months later the vibe started. So when I went to the 3 inch lift I had it changed at the same time.
  3. Feb 19, 2018 at 5:02 PM
    Tacomaratt
    Brandon
    So at 1.75 I will most likely have a problem? What about .85. Truck has 81k on it
  4. Feb 19, 2018 at 5:04 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hard to say all trucks are different, but most likely yes as the OEM bushing is not designed to handle the change.
  5. Feb 19, 2018 at 5:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    All trucks are different, just like some trucks don't need new UCA's with a 3 inch lift. And some do.
  6. Feb 19, 2018 at 6:18 PM
    Tacomaratt
    Brandon
    So from the sounds of it I should either run them on clip one for no problems or just return them when they land ?
  7. Feb 20, 2018 at 8:58 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I had vibration within the first 200 feet on my test drive after I installed 5100's at 1.75. Even after alignment there was no improvement at all. Engaging four wheel drive eliminated the vibration. This was on a Sunday.The next day I lowered to zero lift and the problem disappeared entirely. At 1.75 I also had a noticeable lean to the rear, negative rake you might say, I didn't like that look at all. Some people have no problems, some just live with it but drive line vibration cannot be good long term. I have to think that Toyota designed that needle bearing play in for some reason as they have not corrected it yet to my knowledge.
    They are aware of it now I'm would think.
  8. Feb 20, 2018 at 2:35 PM
    Tacomaratt
    Brandon
    So what' everyone' thought will have problems at .85. Or should I just send them back.
  9. Mar 8, 2018 at 7:35 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2023 F150 2.7 Ecoboost , 2018 4Runner
    I have Billies at 1.75 with stock coils and 5100s in the rear. Have had them on for almost 5 years. I don’t think the ride is stiff at all. The truck squats when I hook the boat up so I will be getting dakars, but overall I’m happy with the ride at 1.75
  10. Mar 10, 2018 at 3:42 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Is there any way to tell what level the 5100s are set at? I just realized the other day that I had them on the front. I know that they aren't set at the bottom two settings, I can see that. But don't know if they are set at 1.75 or 2.50.
    BTW, I have vibration in my front and got about 98% of it gone with a road force balance. There is still some at certain speeds, but I still think it is the tires vs stuff we are talking about here. But I don't know for sure.
  11. Mar 10, 2018 at 4:18 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    Lexus LX 470
    They just told you every truck is different.
  12. Mar 10, 2018 at 4:26 AM
    tacosaregood
    tacosaregood New Member
    San Diego, CA
    I have 5100s front and rear set at .85 up front. No issues so far and big improvement over factory shocks.
