Bird Chirping Sound
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Commocean, Jun 2, 2021.
  1. Jun 2, 2021 at 9:20 AM
    Commocean
    Commocean [OP] Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    I've got an odd sound coming from my '17 SR DCSB 2WD. It only seems to make the noise after a long drive, so replicating at the dealer doesn't seem to be possible. I'm wondering if anyone else may have experienced this, and what the issue was.
    I took a 2.5 hour drive on the freeway, exited the freeway, and came to a stop at a light. When I went to accelerate, I heard this whistling/bird chirping kind of sound that goes away in a few seconds. It sounds to me like it's coming from something spinning perhaps, but I'm not sure. I do know 100% that it's not the undercarriage holes, as it only does it accelerating from a stop, not at higher speeds. This is the second time it's happened after a long drive. It doesn't seem to do it just driving around town.
    Anyone experience such a phenomenon?
    ****EDIT - I should have clarified, this is the 2.7L engine. I think the serpentine belt TCB is only for the V6 right?
  2. Jun 2, 2021 at 9:28 AM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    its probably the belt. I believe there is a TSB about this
    hwd and pochoboy like this.
  3. Jun 2, 2021 at 9:38 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Does the sound go away when you reach a certain speed? I had a similar issue; heard a chirping noise that got more frequent with speed but after 30 mph it drowned out.
    also had some jerking while going into drive and reverse.
    it turned out to be a bad u joint in the driveshaft.
  4. Jun 2, 2021 at 9:48 AM
    Commocean
    St. Petersburg, FL
    I haven't tied the sound to speed yet. Seems to go away after a few seconds, and there's no jerking. It might be coming from the drivers side, as I can hear it reflecting off the car to the left of me when I put my window down. It's loud enough that you can clearly hear it in the cabin.
  5. Jun 2, 2021 at 3:02 PM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    High-pressure fuel pump.
    Lt. Dangle likes this.
  6. Jun 2, 2021 at 3:03 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Idk if the 2.7's have that?
    OP, could be belt or even an idler bearing?
  7. Jun 2, 2021 at 3:04 PM
    CTF
    2017 TRD OR
    Mine was replaced under warranty at about 45k. Sounded like a bird chirping. Especially when next to a structure. Like in a drive-thru after the engine was warmed up.
  8. Jun 2, 2021 at 3:08 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Does the AC being on or off have any effect?
  9. Jun 2, 2021 at 5:47 PM
    FishTaco805
    FishTaco805 Active Member
    P
    2020 Tacoma TRD Offroad 4x4
    My money on dry belt or belt tensioner not keeping proper tension anymore. Do the belt first.
  10. Jun 3, 2021 at 7:10 AM
    Commocean
    St. Petersburg, FL
    Looking at the TSB's (HPFP and belt), they all seem to be limited to the 3.5L V6. I can't find anything related to the 2.7L.
  11. Jun 3, 2021 at 8:01 AM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I had to get the TSB for the V-pattern fan belt. Seemed to fix it.
  12. Jun 3, 2021 at 9:46 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    As mentioned above, it could be a u-joint making the noise. I went through something similar many years ago on a Gen 1 tacoma. Cheap to just hit every zerk fitting in your drive train with some grease and see if that helps.
  13. Sep 28, 2024 at 3:58 PM
    Lemmehearyeryee
    Lemmehearyeryee Well-Known Member
    Luna
    Pensacola
    2008 Tacoma TRD Sport
    Beginner setup. Bilstein 5100s, black rhino wheels
    I don’t know if you’ve figured it out, but the multiple time I’ve had chirping it’s the wheel bearing. Easy fix.
