Bird shit paint damage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acmair, Jun 21, 2012.
  1. Jun 21, 2012 at 8:27 PM
    acmair
    acmair [OP] Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    I discovered this matte part of the clear on my truck today after washing. I remember this particular bird shit, because it looks horrible and I kind of let it stay long lol. I washed it off a month ago, and when I washed my car again today, I realized it left a mark. Is there anything I can do to get rid of this? Looks horrible on a black truck, and especially since it has bird shit shape.
    Couldn't manage to rotate image 90 degrees.
  2. Jun 21, 2012 at 8:29 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Nope. It's on there for good. Bird stuff eats through clear coat. :(
  3. Jun 21, 2012 at 8:34 PM
    acmair
    Andrew
    There's no way to buff it out? :eek:
  4. Jun 21, 2012 at 8:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The bad news is that the paint is actually damaged.
    The good news is it's repairable.
    You just have to get some rubbing compound, some polish, read the directions, take your time, and use some elbow grease.
    If you use an electric buffer with rubbing compound, be sure not to overdo it and either "burn" the paint or simply remove too much of it.
  5. Jun 21, 2012 at 8:41 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    File a lawsuit against the birds? :notsure:
  6. Jun 21, 2012 at 8:43 PM
    acmair
    Andrew
    sadly i did. I knew i should have washed it off, but I just winged it and well that didn't work out well. Learned my lesson tho, hard way :(
  7. Jun 21, 2012 at 8:43 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    If you wanted to get real brave you could repaint your fender flare... It's not that hard if you halfway know what you're doing.
  8. Jun 21, 2012 at 8:44 PM
    acmair
    Andrew
    Thanks! I tried to buff out a few scratches, and it worked but it left the finish not as shiny as before, a bit scuffed up and matte. That's why I'm a bit hesitant to do it myself. Could it be the compound I was using? I used Turtle Wax Polish on the scratch, which made it less shiny than the rest of the car
  9. Jun 21, 2012 at 8:45 PM
    acmair
    Andrew
    Oh damn now it makes sense. I forgot it was on the fender flare. Doesn't Toyota put less clear on the flares? They never look as shiny as the rest of the car. Maybe that's why it ate away so fast?
  10. Jun 21, 2012 at 8:47 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's probably just your technique. You have to buf enthusiastically with a dry rag toward the end to bring it back to a high gloss. Then use wax to keep it shiney.
  11. Jun 21, 2012 at 8:47 PM
    babytruck
    NorCal
    My thinking is that buffing it out would leave a larger dull spot because what you are essentially doing is buffing away the clear coat to blend it?
  12. Jun 21, 2012 at 8:53 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    My advice would be just the wax the shit out of it (literally). Sort of "spot wax" it. When you see "progress" find something even less abrasive and use it.
    (I'm working on a bumper for a friends 540i right now)
    To get it completely fixed you're going to have to put some clear on it.. and some fresh paint. Most auto body/paint shops can mix up an aerosol can of paint that matches the color code for your vehicle, and they can hook you up with some good quality clear coat as well.. I would suggest removing the flare if it's not too big of a pain in the ass, rubbing it down with some 400 or higher grit sandpaper mainly around the damaged area. Hit it with the paint, then clear. You're golden.
  13. Jun 21, 2012 at 8:54 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    I would think they look that way because they're plastic instead of sheetmetal. Therefore the raw surface isn't quite as smooth.
  14. Jun 21, 2012 at 9:00 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you can't get it shiny, go see a detailer. He's got the expertise to polish it out for you.
    Do NOT attempt to spray on more paint.
    Let me put it this way:
    The secret to good polishing is good technique.
    The secret to good paintmatching is good technique.
    paintmathing is *harder* than polishing.
  15. Jun 21, 2012 at 9:02 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    ^^Yea, you shouldn't do that yourself...
    (except for teh polishing. because YOU know how YOU like it. :jerkoff: )
  16. Jun 22, 2012 at 5:04 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    :eek:
    brb going outside to check for bird :crapstorm:
  17. Jun 22, 2012 at 7:43 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
  18. Jun 23, 2012 at 12:10 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    That should come out. Ditch the Turtle wax. I would recommend looking at autogeek or Adams polish website. Adams has a really good step by step on how to detail a car. I have used both Mirror Glaze and Adams Polish products with pretty good success. A porter cable or flex will cut down on your paint correction time.
