bjmoose installs full OME kit & rear brake lines with pics
Discussion in 'Suspension' started by bjmoose, Sep 28, 2010.
  1. Jan 21, 2014 at 8:06 AM
    #201
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    So do you really need to do brake lines with this kit? I am not going to be rock crawling this rig.
    What other things where needed that did not come with the kit? So far I see it is sway bar lowering brackets and U-bolts for leaf springs. Anything else?
  2. Jan 21, 2014 at 8:28 AM
    #202
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Get extended lines. You never know when you'll extend the front or rear and damage the oem stuff.
    Sway bar is over-rated. Delete.
    My kit came with u-bolts.
  3. Jan 21, 2014 at 10:06 AM
    #203
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    My sway bar was fine. After about a year I completely removed the sway bar and I think it rides smoother now. Think about how far the axle might droop if a tire shop lifts truck by frame rather than axle. I checked it. Stock rear brake lines pull rather tight. Some bridge transitions and other hwy bumps can cause a lot of extension. I thought it was a risk not worth taking so got rear lines. My leafs from Toytec had ubolts included.
  4. Jan 28, 2014 at 10:09 AM
    #204
    DESTROYERRACER
    DESTROYERRACER Well-Known Member
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    It's new......mods starting soon. Removed step bars so far. lol
    so regular cab 2nd gen guys.....how are the OME front coils holding up over time?I have the wheelers HD leaf packs out back with billy shocks....did that first due to breaking a rear leaf spring awhile back.have stupid rake right now but knew id be upgrading front eventually which is coming up soon now.i was thinking of 884s with top plate to keep some down travel instead of 885s as I wont see armor for quite awhile but want to lift and bring her close to or level in the front.thoughts?!I did remove the overload spring from the leafs and am still netting about 3 inches higher in the rear.dont want a super stiff front though or bro lean but also dont want the front to sag or settle too much over time
  5. Feb 3, 2014 at 9:25 PM
    #205
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I don't know of anyone who has measured, but it seems like if you also replace the UCA, then you'll get a bit more droop with 884s and a small top plate.
    The most uncomfortable aspect of my 885 reg cab lift is on pavement going over expansion joints, speed bumps, etc - anything where the suspension tops out and the truck ends up dropping off the small bump.
    And that's after adding quite a bit of weight in tools, winch mount, skids, etc...
  6. Feb 3, 2014 at 9:27 PM
    #206
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Agree
  7. Feb 4, 2014 at 5:38 AM
    #207
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I've had 885 on my access cab for 14 months. Same complaint about exp joints and speed bumps. I will say that since removing the sway bar maybe 2 months ago, the ride has smoothed out a lot more. Also, hit bumps at an angle so both fronts don't slam down at the same time.
  8. Mar 13, 2014 at 1:36 PM
    #208
    buzhazzard
    buzhazzard Dad
    Houston
    2009 Magnetic Grey DC 4X4
    Wet Okole seat covers, Weathertech floor mats, blacked out tail lights, leer cap, OME 885s in front and leaf pack in rear with AAL, bhlm, all pro sliders, Pioneer head unit, rear plate bumper, US Off Road hidden winch mount, 10k lb winch, On-board water
    ordering soon. sub'd for reference.
    great write-up!
  9. Mar 16, 2014 at 7:40 PM
    #209
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I've installed 2 sets of Dakars now and as long as you have buddy there to help, you should be able to get the bolts in without using the bottle jack method mentioned. Both times we were able to maneuver them into place and get all the bolts in without too much effort. It's definitely a 2 man job though to get them in there without a lot of difficulty.
  10. May 9, 2014 at 5:12 PM
    #210
    Teagan141
    Teagan141 Well-Known Member
    Teagan
    Llewellyn,PA
    10 TRD Sport
    plasti derp rims, BHLM, emblems, (homertaco)raptor style grill, bilistein 5100 set at 2.5 with stock coil, 2 inch custom alcan 8 leaf pack, with icon 2.0 extended travel rear shocks with resies, front and rear spider trax wheel spacers, rigid dully spots mount on the hood with CBI brackets
    finally found someone that did a write up on brake lines thank you i found this very difficult to search for:D
  11. Jul 1, 2014 at 7:57 PM
    #211
    Gadget
    Gadget Member
    12 DC TRD
    I apologize in advance if this is a stupid question, but how long were your replacement brake lines?
  12. Jul 10, 2014 at 5:46 PM
    #212
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Thanks Steve, Ive read your detailed write up a number of times. Well done.
    Apparently I had a brain fart each time I read the above quote from your OP.
    Now that I'm researching Brake Line replacement, it's pretty glaring.
    Was it the metal brake line you clamped?
    If so, what was the resolution to the destruction?
    Have you realized a non-destructive technique? Threaded plug, cap, etc.?
    Thanks again for making us non-mechanics' lives a little easier.
    CC
  13. Jul 25, 2014 at 4:52 PM
    #213
    Cape Codder
    Jack
    Nevermind.......................
    S.U.R. & R FLS330 Fluid Line Stopper
    +/- Thirty Bucks, Shipped.......... HERE
    Eastwood has them too, for more moola.
    I'll let ya know how the work in a month or two
    Thanks again for the write-up.
    CC
  14. Jul 25, 2014 at 5:28 PM
    #214
    bjboucher
    Brad
    San Antonio, Texas
    I just let mine drip. Didn't lose that much fluid and was better than clamping brake lines in my opinion.
  15. Jul 25, 2014 at 7:56 PM
    #215
    bjboucher
    Brad
    San Antonio, Texas
    Yeah, I was going pretty slow and just made sure the reservoir stayed full. Was pretty messy but no damage done. Just kept my oil catch pan underneath while I was working. If you get OCTaco lines it should go quicker and be less messy. I had to grind the opening for one side of the lines using Wheeler's lines which slowed things down.
  16. Jul 25, 2014 at 8:38 PM
    #216
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Looks like you've solved it - but I clamped the original factory soft lines, since I was going to discard them anyway. No, don't destructively clamp the hard lines. That would be bad. :eek: :D
  17. Jul 26, 2014 at 7:06 AM
    #217
    Cape Codder
    Jack
    Thanks. I had surmised that after posting, then thinking about it.
    The equated the term destructive with permanent.
    Figured if you'd clamped the metal lines, you'd have posted the fix.
    Didn't think of the soft lines, figuring I'd keep 'em.
    CC
  18. Jul 31, 2014 at 3:08 AM
    #218
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Anybody whose installed the D29xl AAL, where did you sandwich that leaf? The leaf is the exact same length as, if my memory serves me correctly, the 4th leaf down. Now I've already assembled my leaf packs with one on top of and the other pack below. I couldn't sit around and not do anything while I waited for the rest of the kit to arrive. The way I saw it at the time is it's easier to fix one pack than to fix two. Any insight on this matter out does it not matter because the leaves are the same length?
    -J
  19. Jul 31, 2014 at 8:33 AM
    #219
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Cool beans. Basically what I took away from that is it does not matter since the 3rd leaf down in the Dakar leaf pack is the same length as the d29xl AAL option as received. Therefore, by definition, it doesn't matter where the d29xl is positioned, either above the 3rd leaf or below. Pretty sure I scoured this thread, must've missed that post and I'm only like 30 or so pages into the OME mega Q&A thread. Thanks.
    -J
  20. Aug 22, 2014 at 1:39 AM
    #220
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Subsubsub- I'll need to find this later!
