bjmoose installs full OME kit & rear brake lines with pics
Discussion in 'Suspension' started by bjmoose, Sep 28, 2010.
  1. May 30, 2011 at 12:55 PM
    #61
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Steve , did your Dakars develop the squeaky creaks ?
  2. May 30, 2011 at 12:57 PM
    #62
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Not yet :p
  3. May 30, 2011 at 12:58 PM
    #63
    OZ-T
    Peter North
    British Columbia
    Lucky you
  4. Sep 27, 2011 at 11:26 AM
    #64
    record catfish
    record catfish Shaka Bro
    Chuck
    NC
    09 DCLB 4x4 SR5 TRD Sport
    None yet. Finally joined to read and respond to the "how to" forums :D
    nicely done man. sick write up!
  5. Sep 30, 2011 at 1:30 PM
    #65
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    Why isn't this a sticky? Moose Thanks for this write up I don't have the OME suspension except the Dakars but have used this with my coilover setup as well with the Allpro tech section and this is one of the most informative write ups i've seen.
  6. Nov 19, 2011 at 2:53 PM
    #66
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Did anyone on here torque the bolts that they loosened or took off? If you did, how much did you torque it too?
  7. Nov 19, 2011 at 9:03 PM
    #67
    OZ-T
    Peter North
    British Columbia
    Which bolts ?
  8. Nov 20, 2011 at 8:17 PM
    #68
    Drunknsloth
    Retribution
    South West
    Like the lower shock mount bolt, the upper shock mount bolts, the sway bar bolts, the lower control arm bolts, and anything else that was unbolted during the install?
  9. Nov 21, 2011 at 8:12 AM
    #69
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    IIRC, I torqued, some of them and did some "by feel" which usually means I overtighten a bit.
    At the time, I only had a 3/8" torque wrench calibrated in inch/lbs. Since then, I've bought a 1/2" torque wrench.
    Anyhow, if people want, I could go back and edit the original post with torque specs. But if you're doing the job soon, just look em up from Haynes/Chiltons, or the norcal TTORA fsm links.
    PintSize likes this.
  10. Nov 21, 2011 at 1:20 PM
    #70
    Drunknsloth
    Retribution
    South West
    It would help me immensely if you could post the torque specs. I'm waiting for my buddy to get back from Training to give me a hand
  11. Nov 26, 2011 at 9:54 PM
    #71
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Torque numbers and brake-bleeding instructions added.
  12. Nov 27, 2011 at 2:20 PM
    #72
    Drunknsloth
    Retribution
    South West
    Thanks man, this is going to help a lot
  13. Mar 14, 2012 at 12:40 PM
    #73
    covefrog08
    covefrog08 swollen member
    Vancouver Island- Canada
    08 w/west coast pin-striping
    devil horns, weather tech floor mats, Camo seat cover, window visors, premier deck w/ 6 speakers and sub, checker plate tool box, diff breather relocate, Mag light & Fire Extinguisher behind seat
    Great write up moose! Will definitely come in handy when I instal my ome kit. I was wondering though what size tires your running and what gears?
  14. Mar 15, 2012 at 8:45 PM
    #74
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    285/70R17 on 17x8 w 4.5" backspacing, 0mm offset.
    I ran for a year on factory 4.10 ratio (4 cyl 5 sp) then regeared 4.88 last November.
  15. Mar 19, 2012 at 4:06 PM
    #75
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    subbing for later
  16. Jul 3, 2012 at 5:53 PM
    #76
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    A saint! That's what you are Mr. Moose. I will be referencing this bad mamma jamma when I install the OME kit on my 2012 4x4 DCSB.
  17. Aug 23, 2012 at 5:45 PM
    #77
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Came to this for the brake line info. Good info about the bracket needing mods.
    I wonder if it's worth trying to find one, modify it then go forward?
  18. Aug 23, 2012 at 7:19 PM
    #78
    Couchpotato
    Couchpotato Well-Known Member
    Wes
    Redding, CA
    If I were a woman sex and a sammich would be in order for the information you provided. But alas I am not a woman...so if we meet up a sammich will be in order. Thank you my man.
    DJ KRAZY K likes this.
  19. Oct 4, 2012 at 9:57 AM
    #79
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    very nice write up. lots of usefull info in here. thank you sir
  20. Oct 22, 2012 at 11:09 PM
    #80
    HERMS671
    HERMS671 Hey there! I'm using Tacoma World
    Guam, USA
    2008 Tacoma DCLB TRD Sport 4x4
    BHLM and HID Retrofit/Upgraded Sound System
    Great write up. Did you have to replace the front brake lines as well?
