bjmoose installs full OME kit & rear brake lines with pics
Discussion in 'Suspension' started by bjmoose, Sep 28, 2010.
  1. Jan 12, 2013 at 11:08 AM
    #101
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    I was thinking about that. But wheelers 1.5" packs are $100 more expensive and I dont know where else to look for leafs. All I've seen is the dakars, and i need something that will be close to the OME front end. Err on the side of bro lean rather than rake.
  2. Jan 12, 2013 at 11:46 AM
    #102
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I agree with oz. check out the ironman leaf pack for 2" of lift. In sure you could remove both leafs from the dakars if you really want
    Whoops thought you were second gen nevermind :facepalm: i gatta stop doing that
  3. Jan 12, 2013 at 11:57 AM
    #103
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Still debating. Because I have seen a few trucks on here with the OME setup and dakars where the front end is higher, and I have seen some with dakars where the rear is higher. Not sure what to go with
  4. Jan 12, 2013 at 11:58 AM
    #104
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    By the time you add bushings and U bolts to the Dakar price there is an approx $50 difference
    Maybe you should just get an AAL
  5. Jan 12, 2013 at 12:00 PM
    #105
    OZ-T
    Peter North
    British Columbia
    Who
  6. Jan 12, 2013 at 12:00 PM
    #106
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    But I would still have to get extended u-bolts and new bushings for the wheelers pack too... AAL wont work because the pack on my '00 is frowning
  7. Jan 12, 2013 at 12:01 PM
    #107
    OZ-T
    Peter North
    British Columbia
    Stop the presses
    I never saw that you were a first gen before
  8. Jan 12, 2013 at 12:05 PM
    #108
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Yup 1st gen. So I need new leafs. "travis9287" is my favorite 1st gen with OME, slightly higher in the front.
  9. Jan 12, 2013 at 12:08 PM
    #109
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    OME gallery, last post also looks like its slightly higher in the front. Black 2nd gen
  10. Jan 12, 2013 at 12:09 PM
    #110
    OZ-T
    Peter North
    British Columbia
    Looks level to me
    but in all honesty , I don't know much about the 1st Gen OME set ups
  11. Jan 12, 2013 at 12:11 PM
    #111
    OZ-T
    Peter North
    British Columbia
    He's parked uphill , looks nose high in the stock pic too , no ?
  12. Jan 12, 2013 at 12:13 PM
    #112
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Remove a leaf from the dakar pack i guess
  13. Jan 12, 2013 at 12:14 PM
    #113
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Could be. Worst comes to worst I just remove the leaf and get some 10mm top plate spacers for the front
  14. Jan 12, 2013 at 12:20 PM
    #114
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    There are two ways to buy the Dakars. Either stock or with an added leaf.
    The stock Dakar pack will likely be fine with the OME's up front. If you want help, I'd call Wheeler's. I cannot say enough good things about their help. It's great!
  15. Jan 15, 2013 at 8:39 PM
    #115
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    moose said something about clamping the brake line to prevent air getting to master cylinder...
    I thought it was a simple remove/replace for the lines and the only way you'd get air in the master cylinder was if you let it go dry. So as long as the reservoir doesn't go empty while replacing the lines, things are fine even without clamping, right? Isn't a gravity bleed the same thing as having an open line?
    Also, what size are the threads on the lines? There are caps/plugs available so you don't have to clamp. http://www.rockauto.com/catalog/x,extras,1,subgroup,Fitting+-+Plug,parttype,267
  16. Jan 30, 2013 at 11:22 AM
    #116
    Hippynotions
    Hippynotions Active Member
    Awesome post man! Super in depth and just what i needed to instal my lift me and my dad will be doing it together hes a Heavy Duty Mechanic so it should be a breeze with these instructions. I am just wondering if you installed new UCA's or if your stock ones were fine and they aligned back to stock? Did you go with the 2" or 3" lift and did your stock driveline length change dramatically or was it all good?
  17. Jan 30, 2013 at 3:36 PM
    #117
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    My alignment after was about roughly 0 degrees of caster. So after driving "twitchy" for about a year, I finally changed to the Light Racing UCAs.
    Didn't change anything at all on the driveline length.
  18. Jan 30, 2013 at 8:01 PM
    #118
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I loosened the mounting bolts for the center bearing on the driveshaft and the bracket moved back maybe 1/8-1/4 inch on my access cab. Moose's regular cab is 1pc driveshaft so maybe it didn't matter much there. My access cab is 2pc.
    My caster is almost 0 on stock UCAs. Noticably twitchy steering but drivable. I'm getting new UCA soon.
    Noticed that it took about 1000 miles to break in the 885 front springs. They seemed too stiff at first but are better now.
  19. Jan 31, 2013 at 7:33 PM
    #119
    Hippynotions
    so the new UCA's would compensate the twitchy steering? and bring it back to stock handling are both of your lifts 2"
  20. Jan 31, 2013 at 7:34 PM
    #120
    OZ-T
    Peter North
    British Columbia
    Yes
    They allow for caster to be adjusted correctly
