bjmoose installs full OME kit & rear brake lines with pics
Discussion in 'Suspension' started by bjmoose, Sep 28, 2010.
  1. Jun 14, 2013 at 6:48 AM
    #141
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    It's a similar argument with the diff drop, being that the change is so minor what's the point?
    When you get an alignment after installing the lift get the tires balanced and rotated. I think a lot of guys are getting small vibes and thinking its from the lift.
  2. Jun 14, 2013 at 7:14 AM
    #142
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Narrow forward
    Did you get centre pin collars ?
  3. Jun 14, 2013 at 7:21 AM
    #143
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    CentER pin collars are in the mail, yes. :p I saw that in one of these threads and made sure I ordered them.
  4. Jun 14, 2013 at 7:28 AM
    #144
    YOTA LOVER
    NH
    OZ, Airman Boucher is very thorough... He could give Airman Jamie a run for his money :D
  5. Jun 14, 2013 at 7:43 AM
    #145
    OZ-T
    Peter North
    British Columbia
    You may or may not need the centre pins depending on the style of the shims
  6. Jun 14, 2013 at 7:49 AM
    #146
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Probably won't need centre pins. Center pins will likely be needed though. :stirthepot:
  7. Jun 14, 2013 at 8:10 AM
    #147
    YOTA LOVER
    NH
    :rofl:
    OZ speaks the Queens English, not 'Merican. :boink:
  8. Jun 14, 2013 at 10:13 AM
    #148
    OZ-T
    Peter North
    British Columbia
    I speak English
    Y'all grunt hillbilly
    EMS911 likes this.
  9. Jun 14, 2013 at 10:17 AM
    #149
    YOTA LOVER
    NH
    Indeed good Sir, your words have merit.
  10. Jun 14, 2013 at 10:23 AM
    #150
    Pugga
    Massachusetts
  11. Jun 23, 2013 at 2:04 PM
    #151
    bjboucher
    Brad
    San Antonio, Texas
    Got my kit installed today. Replacing UCAs at the same time made getting the new struts in super easy. Just need a little light pressure with our hands. Also didn't need to mess with using a jack to get the Dakars to line up.....they popped right in.
    Hardest part of getting the UCA bolts out and back in! Took about 7 hours of actual work today to do everything except the extended brake lines. Saving those for another day.
    This write-up definitely helped! Thanks moose!
  12. Jul 13, 2013 at 4:27 PM
    #152
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Installed SAWs up front today. For getting the LCA down, don't pry. Use the factory bottle jack, upside down, pushing the UCA down (which pushes the LCA down). A little bit at a time gets things lined up and in place. No need for brute force, no broken alignment tabs. I used that trick on my 1st gen 8 years ago, and it works on the 2nd gens too.
    Now to go install my trans4mer, let crap settle, adjust the SAWs one last time and go have it aligned.
  13. Jul 13, 2013 at 5:50 PM
    #153
    YOTA LOVER
    NH
    I just hit the lower ball joint with the impact gun (remove the two bolts) and the lower A-Arm moves freely. Use a floor jack to lift it back into place and retorque the two bolts.
  14. Jul 13, 2013 at 5:55 PM
    #154
    bjboucher
    Brad
    San Antonio, Texas
    I found separating the UCA ball joint from the lower assembly worked out really well too. Was very easy to get the new coil over in there. Didn't need to mess with a jack, just very list pressure with my hands.
  15. Jul 14, 2013 at 12:50 PM
    #155
    YOTA LOVER
    NH
    Fixed!
  16. Jul 14, 2013 at 1:04 PM
    #156
    bjboucher
    Brad
    San Antonio, Texas
    Maybe i didnt mean ball joint, but I was talking about the UCA. Once I separated it there was plenty of play to get the new shock in there.
  17. Jul 14, 2013 at 1:53 PM
    #157
    YOTA LOVER
    NH
    Forgot you did those at the same time. My method is easier than replacing the UCAs :thumbsup:
  18. Jul 14, 2013 at 2:02 PM
    #158
    bjboucher
    Brad
    San Antonio, Texas
    Even if I didn't replace them though, disconnecting the UCAs from the rest was really easy. Take one nut off and then a couple taps with a hammer. Seems like a pretty easy alternative to make room for the new shock.
  19. Jul 17, 2013 at 9:27 AM
    #159
    YOTA LOVER
    NH
    My way is better. Before this your idea of a strut was a structural support member on a plane :D
  20. Jul 17, 2013 at 6:15 PM
    #160
    bjboucher
    Brad
    San Antonio, Texas
    I think my way is better, private! :D And you've probably been in or around more Air Force planes than I have! lol
