bjmoose installs full OME kit & rear brake lines with pics
Discussion in 'Suspension' started by bjmoose, Sep 28, 2010.
  1. Jul 17, 2013 at 6:28 PM
    #161
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I did it this way also, very easy. And now that just one nut is attaching the balljoint to the UCAs with the LR UCAs i will probably do it the same way next time.
  2. Jul 17, 2013 at 6:36 PM
    #162
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Sub for later
  3. Jul 17, 2013 at 7:11 PM
    #163
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Thanks for confirming my way is better! :D
  4. Jul 17, 2013 at 7:14 PM
    #164
    evanmb31
    evan
    connecticut
    09 trd off road
    :laughing: when installing new UCAs yes definitely better, i have never done it the other way. But just to piss chris off ya, this way is better, doing it the other way is stupid :cool:
  5. Jul 18, 2013 at 3:12 AM
    #165
    bjboucher
    Brad
    San Antonio, Texas
    Hehe! :stirthepot:
  6. Jul 18, 2013 at 4:31 AM
    #166
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Dickless bastards, the both of you :D
  7. Jul 18, 2013 at 4:54 AM
    #167
    Large
    Large Red
    If you have stock UCAs it would be easier to remove the UCA from the spindle, if you are using aftermarket UCAs there is plenty of room so you don't have to remove it. I've redone my suspension 4 times so I am basing my claim off experience.
  8. Jul 24, 2013 at 3:08 PM
    #168
    YOTA LOVER
    NH
    It's much easier to remove the two bolts holding the lower ball joint assembly on the spindle than it is to break free the tapered shaft (from the upper ball joint) that is normally jammed and rusted into place on top of the spindle, even with the right tools.
    With all of the work I have done on my old 95 and now a Gen 2 I can tell you I have tried every approach to save time, money, and destruction. I've had the Gen 1 torn apart so many times I've lost count.
    You tell me what makes sense: messing with a tapered shaft or simply putting an air gun on two bolts and watching it all fall apart easily. :notsure:
  9. Jul 24, 2013 at 5:03 PM
    #169
    evanmb31
    evan
    connecticut
    09 trd off road
    Light racing UCAs i just have to take one bolt off :p
  10. Jul 25, 2013 at 12:55 PM
    #170
    YOTA LOVER
    NH
    Yes, there's that. Some of us are still running OEM :p
  11. Sep 15, 2013 at 5:44 AM
    #171
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
  12. Oct 5, 2013 at 9:19 PM
    #172
    tim2010
    tim2010 if you ain't first, you're last!
    TimO
    Medina, OH
    '11 MGM access cab 4x4
    OEM Fog Lights (wiring not OEM), Westin brush guard
    I'm with Chris... and the LCA
    I got myself way pissed off trying to take the driver side coil-over assembly out by way of the UCA. A puzzle I couldn't solve. Plus I had the rotor assembly wanting to flop all over the place with brake lines and wheel sensors(?) in harms way. Ended up also releasing the LCA from the LBJ and it came right out. Plus made the install and bolting the bottom of the coil-over assembly go much easier... started with the LCA first and literally cut the passenger side down to a fraction of the time. Just left the rotor assembly hanging/stabilized from UCA (but also supported by milk crate) while I popped coil-cover out... swapped the shock and threw it back in before I was finished with my dr. pepper.
    now unfortunately I mangled my stabilizer linkage. (2010, and they were pretty gnarly) poor design. my brother is a mechanic and stopped by to check on me... I was bumming thinking that I did something wrong tying to remove them... he informed me that they usually have to be replaced. no great way to take them out when that nut and bolt are rusted up. The allen key to hold in place while you wrench on them? no good! (allen key hole was rounded out in 3 attempts.) look like a pair of them will run me about $100 at the local carquest... also the place I rented the spring compressor.
    Anyways... this thread was a great help... even all the conversation that came afterwards. Thanks to All!
    in all,
    i changed out my stock front shocks for a buddy's TRD billies. (only had about 8k on them) I also added 2.5in Daystar lift. Next I have Ruff Country 3in AAL for the back end. I have a feeling that will be a little easier.
  13. Oct 24, 2013 at 6:28 PM
    #173
    lightinglark956
    lightinglark956 Well-Known Member
    pat
    springfield il
    2012 tacoma trd offroad
    k&n cai ,flowmaster series 40 single in dual out with custom dual exhaust out the back with 4 in ss cans ,backflip vp tonneau Blackhorse stainless bulbar ,35% tint front and rear,rainguards ,glovebox console organizer,ome 887's ,Dakar rear leaf package ,ome nitro charger schocks ,lr uca's ,diaz devil horn emblem,goodrich ext brake lines
    has anyone done a complete ome lift and had it add to the tacolean ? I did 887's with ome shocks ,lr ucas and a Dakar leaf pak with ome rear shocks .didn't have but 1/4 lean before ended up with 5/8 front and 7/8 rear wth ??? oh ya and I did do 5 mm trim packer on driver strut .if you did what size top plate spacer did you use to correct it ??
  14. Oct 24, 2013 at 6:55 PM
    #174
    bjboucher
    Brad
    San Antonio, Texas
    Do your Dakars have a + and - on them? If so, is the + on the driver's side?
  15. Oct 25, 2013 at 7:05 AM
    #175
    Matlax
    Matlax New Member
    I used this to install on my '13 DCSB and it was invaluable...THANKS MOOSE! I thought I was going to lose my mind putting those leaf springs on...dang!
    Separately, for the UCAs, I didn't end up cutting the factory bolt. I'm certainly not a fan of hurting my baby but the amount of bending required to get it out then reinstall it was pretty minimal of anyone is wondering
    Thanks again for taking the time to do this write up!
  16. Oct 25, 2013 at 7:14 AM
    #176
    lightinglark956
    pat
    springfield il
    mine have a O and a - and the O is on the drivers side
  17. Oct 25, 2013 at 9:59 AM
    #177
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That's correct
  18. Oct 25, 2013 at 8:41 PM
    #178
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    Same here.
    No spacer used, and no lean measured nor perceived.
  19. Oct 26, 2013 at 4:36 AM
    #179
    bjboucher
    Brad
    San Antonio, Texas
    Are you sure you put the shocks on the right side up front? Maybe the trim packer is on the passenger side by mistake? If not, must be the 887s.
  20. Oct 26, 2013 at 6:10 AM
    #180
    evanmb31
    evan
    connecticut
    09 trd off road
