bjmoose mounts NATO jerry gas cans
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Mar 5, 2011.
  1. Mar 5, 2011 at 10:28 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    My 94 F150 held nearly 36 gallons of gas with no extra gas cans. The Tacoma holds a paltry 21 gallons of gas. So I decided to add 3 cans. I wanted NATO cans. They've gotten hard to get as more states have adopted the CARB restrictions. But they're possible to find.
    Mounting rubber feet on both sides of the center can so they won't rattle together.
    Lots of guys are running elaborate steel cages, but I want to keep it simple and also be able to use the bed for other purposes if I remove the cans. So I'm going to mount them at the front of the bed using these eye-bolts and parts:
    The steel strips will become backing plates, and are used as a template to drill holes in the front of the bed for the eyebolts:
    and
    Not shown - the nuts are welded onto the backing plates.
    There's not much space for fingers between the cab and the front of the bed. We use some threaded rod (NOT a bolt with a head!) to fish the backing plates into position from inside the bed:
    and
    and
    Temporarily put a nut snugly on one of the threaded rods to hold the backing plate in position, while the other threaded rod is removed and the eyebolt is threaded and tightented into position.
    Repeat for the other eyebolt, and then the other backing plate.
    Now ordinary rope will hold the gas cans tightly in position. These bad boys aren't going anywhere. Use a lot of tension on the rope and then a trucker's hitch to finish tensioning the tie.
    EDIT: See update below. I ended up switching to ratchet straps as the rope didn't hold the full cans in place for multiple days of off-roading.
    UglyBetty and Jimmyh like this.
  2. Mar 5, 2011 at 10:38 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Nice work as usual Bullwinkle
    :thumbsup:
  3. Mar 5, 2011 at 10:39 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    Nice setup, like that you can easily remove them if space is needed.
  4. Mar 6, 2011 at 1:36 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Hey I just saw this thread after reading another thread about installing a secondary gas tank in the bed.
    Did you happen to ground the tanks? I read that static can build up and potentially cause a spark....
  5. Mar 6, 2011 at 1:41 PM
    Sprink669
    Sprink669 Well-Known Member
    Nice! do they allow the bed cover to sit flat?
  6. Mar 6, 2011 at 2:04 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Why are your sliders angled down?
  7. Mar 6, 2011 at 2:57 PM
    mandzach
    mandzach Well-Known Member
    Hope he didnt weld them on.
    OP nice mod, thanks for sharing
  8. Mar 6, 2011 at 3:01 PM
    OZ-T
    Peter North
    British Columbia
    Put on the wrong side possibly ?
  9. Mar 6, 2011 at 3:50 PM
    Reepur
    Brevard, NC
    LOL get that a lot. I angled em down because..
    1. dont foresee high centering my truck where I go.
    2. Comes out a little farther to protect against door dings.
    3. Use em as a step and at this angle, gives me plenty of room
    for my steel toe boots to fit on them.
    4. More room for my hi lift to clear the side of the truck.
    and they don't sit down any lower than the cross member.
  10. Mar 6, 2011 at 5:15 PM
    Papa Tac
    Papa Tac Adjunct Anarchist
    Papa Tac
    Codroy Valley, Newfoundland
    '10 Ned Ludd Edition
    Pupped my ride - Dog bench, Black stock rims, Tail Gate antitheft mod, Bed storage and sleeping platform, Action Cap w/Yakima rack and Rola basket, Seatbelt chime off, Tentasaurus
    I like your idea of drilling the bed for mounting points!
    How strong is this method? How much force can they take?
    I'd like to try this for a bike mount idea I'm cooking.
    :cheers:
  11. Mar 6, 2011 at 5:17 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    nice work man
  12. Mar 6, 2011 at 6:24 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You'd want to ground any permanently attached tank. These are just gas cans. Never heard of anyone grounding temporary use gas cans.
  13. Mar 6, 2011 at 6:28 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yes.
  14. Mar 6, 2011 at 6:31 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Thanks for all the compliments.
  15. Mar 7, 2011 at 9:37 PM
    YayAreaTaco0311
    YayAreaTaco0311 Motivator
    California
    '09 TRD 4x4 O/R Supercharged
    OEM TRD supercharger, OEM wheels painted black by me, yellow sidemarkers, arb bumper, LED interiors, roll-n-lock, 5% rear windows, mudflaps removed, protector alarm, mobile trace, blacked out front Toyota emblem, debadged, & tree air freshener.
    BJmoose,
    You're such an intelligent person! Very nice, keep up the good work! Ever since we went to Hollister, I've had your Taco stuck in my head!
  16. Mar 7, 2011 at 9:39 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    whoa cool!
  17. Mar 8, 2011 at 11:57 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    and
    Thanks for the compliments. :)
  18. Apr 25, 2011 at 8:37 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    UPDATE: So after a few days of continuous off-roading, it turned out that a single piece of rope with a truckers hitch can't be cinched tight enough to hold the full gas cans and keep them completely in place.
    I ended up switching to using two ratchet straps, with the top one led through a piece of plastic hose to prevent it from chafing on the inside edge of the handles.
    The rubber feet that I put on the center can came off pretty quickly too, as the rubber grips the adjacent can about as well as the adhesive. So I've switched the rubber feet out for some felt squares to prevent that "paint removing" friction.
  19. May 14, 2012 at 8:19 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Hey Steve what are you using to pour? Do you have the specific spout or just a funnel?
  20. May 14, 2012 at 8:34 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, there's a spout designed exactly to work with these cans and I keep it zip tied to the cans.
    Make sure it's seated tightly when you pour or it may disconnect unexpectedly while you pour. :eek:
