Black indoor door panel scratches / scuffs
Discussion in 'Detailing' started by TacoRancher, Jul 5, 2022.
  1. Nov 10, 2022 at 5:52 AM
    davbri59
    davbri59 Member
    David
    2021 Tacoma TRD Sport
    I applied to just where the scratches were. That color matched very well.
    Brex69[QUOTED] likes this.
  2. Nov 10, 2022 at 5:53 AM
    davbri59
    davbri59 Member
    David
    Magic erasers abrade the surface, they will lighten all the areas around the scratch.
  3. Nov 10, 2022 at 3:01 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Plastic has color all the way through. If the eraser remove to much the plastic will still have color.
    With anything, Common sense will prevail. Even polish may work.
  4. Nov 10, 2022 at 6:27 PM
    davbri59
    davbri59 Member
    David
    I do business with a factory that makes door panels for many. The injected molded plastic is very close to the actual color they are wanting. However plastic when being injected into a door panel can have slightly different hues. They paint them prior to assembly so they look the best. I was as surprised as anyone when I saw this being done.
  5. Nov 11, 2022 at 4:05 AM
    Venom
    Kevin
    Massachusetts
    When I worked at a Toyota dealership. They told that the manufacturer doesn't paint the plastic interior panels. Customers will used cleaners, brushes, protectants on plastic that will remove the paint or dye over time. If heat doesn't take care of it, They will use the plastic panel as parts. Places will buy them slightly defective.
  6. Nov 11, 2022 at 4:28 AM
    Firn
    Firn Well-Known Member
    White OR
    By abrading the surface the magic eraser adds small scratches. These scratches will lighten the appearance of the surface regardless of the color being embedded in the plastic
    whatstcp likes this.
  7. Nov 11, 2022 at 4:38 AM
    Venom
    Kevin
    Massachusetts
    Why detailers use eraser on leather?
  8. Nov 11, 2022 at 11:11 AM
    Firn
    White OR
    Leather isn't plastic
  9. Nov 11, 2022 at 2:27 PM
    Venom
    Kevin
    Massachusetts
    Leather is a lot more delicate than plastic.
  10. Nov 11, 2022 at 2:43 PM
    General Chaos
    General Chaos I like pie.
    Joe
    NC
    2022 MGM Tacoma OR TRD 6MT
  11. Nov 11, 2022 at 4:13 PM
    davbri59
    davbri59 Member
    David
    Erasers remove a very small amount of surface. It is made of melamine foam and a detergent. They abrade and what ever surface is the softest is what it will attack. Regardless the shoe cream worked great!
  12. Nov 11, 2022 at 4:21 PM
    Firn
    White OR
    It isn't as simple as that, NOWHERE near as simple as that.
    Thats like saying strength, hardness, and toughness are the same thing.
  13. Nov 12, 2022 at 2:51 AM
    Venom
    Kevin
    Massachusetts
    The shoe cream is a cover up. It will wear off eventually.
    Interior's plastic is dull from the manufacturer. When the eraser abrade the plastic surface it does remove minor surface scratches. I seen detailers from dealership do it all the time. The plastic will look dull but with protectant added, It'll bring back the shine or sheen.
    With all thing common sense plays a big role, plus knowing when to stop.
