Black Rock Yuma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SR5W, Dec 16, 2015.
  1. Dec 16, 2015 at 4:25 AM
    SR5W
    SR5W [OP] Member
    2016 Tacoma SR 5 speed in white
    I am looking to upgrade my stock SR wheel. I really like the Black Rock Yuma and would like to know if I have chosen the correct specs?
    Size 16x8
    Bolt pattern 6x5.5
    Offset 0 deg (only choice) Will this negativley effect handling?
    Rear spacing 4 1/2"
    Center bore 3.075 or 4.25 (Which one is correct for my SR 4x4)
    This is my first Tacoma...my local garage does not carry aftermarket rims...AND my salesman told me he cannot recommend after market porducts...so any help would be much appreciated!
  2. Dec 16, 2015 at 8:13 AM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    There is a rim thread on the main page here that has a ton of info, and many other posts. Quickly looking you should be ok but make sure it's hubcentric. I was in a thread where we did the math on back spacing and how to calculate so you can see how much further it would stick out, which with yours should be slight.
  3. Dec 16, 2015 at 10:45 AM
    SR5W
    SR5W [OP] Member
    Thank you for the response...I read that thread but found no information on the 3rd gen...I might be better off ordering the black rims that were offered as a upgrade for the SR...
  4. Dec 16, 2015 at 2:10 PM
    Wraith600
  5. Dec 17, 2015 at 4:57 AM
    SR5W
    SR5W [OP] Member
    Thanks for the link...I read the 33 page thread about wheels. When you mentioned hub centric, I was told that most aftermarket rims are lug centric...Do you think this a problem if I use hub centric rings?
  6. Dec 17, 2015 at 6:41 PM
    Wraith600
    I know most rims to be hub centric when and I have used a ring before with no issues. Check tire rack for example and you will see what gets listed then look into the bore.
