black "Shank" style lugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ronin16, Jul 14, 2008.
  1. Jul 14, 2008 at 5:35 PM
    ronin16
    ronin16 [OP] Active Member
    SF Bay Area,CA
    09 Black 4x4 TRD Off Road
    Finally got my TRD Trail Teams Wheels!!!!!!!
    I m new here so please excuse this thread if it has already been addresed. I m looking to purchase the black baja alloy wheels but can't seem to find black lugs. I talked to every tire dealer in the Bay Area and they said talk to factory. Parts stated no black factory lugs. Correct me if I m wrong, the OEM wheels have to have the shank style lugs right? who has upgraded their originals to the alloys and what have they done to get the "Shank" style lugs in BLACK ?
  2. Jul 14, 2008 at 5:37 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    check wheelersoffroad.com and see if they have what u want. i got black lugs from them for my stock sport 17's and they work fine.
  3. Jul 14, 2008 at 7:35 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Over the years, Toyota alloys have used both tapered seat and shank style. Go to one of the online dealers selling these wheels and down at the bottom is listed the toyota part number for the lugs. There are plenty of sources for black tapered seat lugs, as Toyota used them in the 80's thru the late 90's, but for shank style I would look at McGard and Gorilla to see if the offer black shank style.
  4. Jul 14, 2008 at 7:38 PM
    The_Hodge
    SC
    here's a pic of the ones i got from wheelers. i put them on and havent had any trouble w/ em
  5. Jul 14, 2008 at 8:00 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    Those are tapered seat "bulge nuts" with usually a reduced head size; should take a 19MM vs a 21MM socket, and is standard 60º taper.
    EDIT: (to anybody/everybody) Anytime you change wheels/lugnuts, make sure you have proper tools for the new setup, 3:30 AM in the rain on the side of an interstate is not the time to find out you can't remove tire/wheel assy.
  6. Jul 14, 2008 at 8:05 PM
    The_Hodge
    SC
    those had the same size head as the stockers on my truck. i used the same deep socket for em
  7. Jul 14, 2008 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think my Dr. told me I had these? :eek:
  8. Jul 14, 2008 at 8:22 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    Get some standard size nuts, without the bulge; after that mabey you can have a large tool too:D
  9. Jul 14, 2008 at 8:27 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    They do make them in the large hex, but are usually hard to find; most 1/2" and 12mm will drop down to the 3/4" - 19mm hex size, I guess to make it fit more applications.
  10. Jul 15, 2008 at 6:44 PM
    ronin16
    SF Bay Area,CA
    Thanks for all the replies !!!
  11. Jul 15, 2008 at 7:11 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I have those lugs on my rims the fit really nice definately need a thin wall socket for those.
