Blacking Out Headlights, How to
Discussion in 'Lighting' started by spencer_hong, Jul 31, 2007.
  1. Aug 16, 2007 at 8:11 PM
    Soul
    Soul Well-Known Member
    07 PreRunner SR5 Black
    Is the grit sand paper on Amazon by any chance? If so can you link it? we don't have any kragen's store and I call most of the store in Idaho and they don't know what grit sand paper are o_O.
    I'm planning on purchasing the spray paint and grit on amazon :].
    You know any local store with Krylon paint? Or amazon is the only hope?
    double checking is this the same product you use? (paint)
    http://www.amazon.com/exec/obidos/t...7203?_encoding=UTF8&m=A1T0VEFK4F7RX4&v=glance
    http://www.amazon.com/Inch-Hook-San...0006M2SK2/ref=pd_sim_hi_1/002-7865606-2667203 (sandpaper) or http://www.amazon.com/Magnate-V616G...667203?ie=UTF8&s=hi&qid=1187320870&sr=1-(sand paper)
  2. Aug 16, 2007 at 8:24 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    The sandpaper you are linking is for a dual action air sander, and while that would work, you are paying extra for the round shape and adhesive backing and you don't need it.
    Here is basic 600 grit sandpaper on Amazon http://www.amazon.com/Wet-Dry-Ultra-Fine-Sandpaper/dp/B0000AXT76/ref=pd_bbs_sr_10/103-3824458-3923859?ie=UTF8&s=toys-and-games&qid=1187320779&sr=8-10
    Though please take what I say here with a grain of salt as I lack the stones to stick my headlights in the oven and then pry them apart, but I suspect that you'd be fine using 000 steel wool in place of the 600 grit paper.
    While you might need amazon or a good automotive store or automotive paint supply house to find 600 grit paper, both the krylon fusion and 000 steel wool would be available at your local Lowes or Home depot.
  3. Aug 16, 2007 at 8:37 PM
    Soul
    I'll check out home depot & Lowes tomorrow! I gave up hope on both of them cause I search for it on their sites and couldn't find any results.
    Krylon has black in gloss and non gloss. It's the same thing comparing it to lcd monitors right? Glossy = shiny
  4. Aug 16, 2007 at 8:42 PM
    maverick491
    South Jersey
    Yes, glossy is shiny, but you best wait for confirmation from someone who has done this as to which one you want to use. I would thing the gloss, but like I said I have not done this so I really don't know for sure.
  5. Aug 16, 2007 at 8:59 PM
    Soul
    I'm reading multi forums and instruction on this.
    "2. Baking the headlights.
    Make sure you take off all the little plastic and rubber pieces on the back of the headlights along with three small hex screws and take out the main headlight. Pre-heat your oven to 200 degrees F. I know the oven part sounds sketchy, but as long as you do everything right it'll work out perfectly. Stick the headlights in one at a time for 8 minutes. When you pull them out let them cool for a very short time then start pulling the lens away from the plastic backing. The sticky stuff between the plastic and lens is really strong, and trust me it might get frustrating (it definitely did for me) but remember, take your time. A flat-head might be useful he to help pry the two apart."
    Baking it for 8 minutes 1 at a time with set to 200*F with in the 8 minutes? or preheat till then put in and the oven off?
    5. Putting the headlight back together.
    Put the lens w/ the frame back into the plastic holding of the headlight. Stick it back in the over (preheated at 200 degrees F) for about 5 minutes. When you take it out, immediately push it back together and get the silcone to stick as much as possible. The headlight should have a sturdy hold and not seem like its going to fall apart. It should be completely glued back togther. I reccomend using electrical tape to seal all around the lens, just so no moisture gets in (i had this issue). Put the headlight and grille back in, and enjoy!
    stick both of them in for 5 minutes? or one at a time?
  6. Aug 17, 2007 at 7:34 AM
    Soul
    Spencer any tips on getting the lens away from the plastic? It's a hard as hell. I put it in the oven twice at 8 minutes.. and i just barely got a cm. I'm giving it a break... I'll try another attempt when i wake up.
    http://www.customtacos.com/tech/index.php?article=222 I'ma give preheat 305 and then off a try
  7. Aug 17, 2007 at 10:10 PM
    Soul
    Yeah 305 is the saver for me :]
  8. Aug 23, 2007 at 8:00 PM
    toycoma671
    toycoma671 Well-Known Member
    Jacksonville, FL
    2007 Prerunner,Sbed, Indigo Ink,TRD
    Blacked out headlights & tail lights,Eye lids, and stainless steel billet grill, Debadged, 10" RockfordSubs, 6x9 Polk speakers, 6 1/2 speakers, JVC CD Player, Vent Visors, Nerf Bars, 20% Tint front, 15% bk Pop-lock, Tonneau Bed cover, Rockford punch amps, OEM Tacoma Bed mat, Toycoma Sport Brakes
    Hey man that's beautiful!! I swear all this great info I'm gonna do this to mine..thanks again by the way nice truck!!
  9. Aug 23, 2007 at 8:38 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i did 350...oh well...lol
  10. Sep 18, 2007 at 10:02 PM
    Sixgunsam
    Sixgunsam Member
    Gulfcoast of FLA
    07 Silver Taco Access cab 4x2 4cyl 5spd manual
    Class III Hitch...so far
    Hey y'all!! Just a suggestion. Instead of putting the headlight/lens assembly in an oven for the 2nd time, how about this. Clean out the groove the headlight lens goes into and wipe down with alcohol to clean out any oils. Then run a bead of silicone sealant around the seal. You could use aquarium sealant if you never figure on taking it apart again, or just use the regular silicone clear sealant you can find at Lowes/Home Depot/Wally World. No worries about water or moisture getting in after that.
  11. Oct 6, 2007 at 3:22 AM
    Silver_Jim
    Silver_Jim Well-Known Member
    Maryland
    2019 Toyota Tacoma DCOR
    Brant
    I have a Silver Taco and I'd love to see a pic of your mod on this? It does look really good with a black taco, but I didnt think it would be "all that" with a silver. Then again, my wife always picks the color of paint for the house... :eek:
    Dhannah likes this.
  12. Oct 6, 2007 at 3:35 AM
    maverick491
    South Jersey
    Brant's truck from the photo gallery
  13. Oct 6, 2007 at 3:43 AM
    Silver_Jim
    Maryland
  14. Oct 6, 2007 at 3:44 AM
    Silver_Jim
    Maryland
    Yea that looks pretty good... Gives the front end some definition and personality... :)
  15. Oct 14, 2007 at 6:18 PM
    #35
    sunruner19
    sunruner19 Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
    [​IMG]Found this on ebay today:
    For $169.00 per pair, you can get the headlamps blacked out already. All you have to do is remove your stock headlamps and replace with these.
    This is for people who do not wish to go thru 4 or 5 hours of work, or whose wives or mothers wont dare let them near the oven. I mean, you could get bitched out for 4 or 5 hours too, so this is really the easy way out.
    On EBAY TWO ITEM NUMBERS
    150170391757
    120172931164
    I have included 2 items just incase one auction has ended. These are BUY IT NOW auctions.
    #35
    PackCon likes this.
  16. Nov 6, 2007 at 5:14 PM
    #36
    avanasch
    avanasch Active Member
    Great work on the headlights! They look awesome.
    Question. If I can't get all of the chrome out of the corners and crevices will the paint still and here and look good? I will spend a couple more hours sanding if that is what I have to do to make it look good, but if the paint adheres they why waste my time.
    thanks for any helps
  17. Nov 6, 2007 at 9:21 PM
    #37
    The_Hodge
    SC
    i didnt sand any...i just sprayed the krylon fusion on it...since its supposed to bond to plastic and all. i've been running mine for a few months and havent had any probs at all.
  18. Nov 6, 2007 at 9:41 PM
    #38
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    i sanded mine quickly, trying to get as much off as i could but i only spent 5 minutes on each one. i used the same krylon fusion paint and it came out great
  19. Nov 6, 2007 at 10:15 PM
    #39
    spencer_hong
    spencer_hong [OP] Well-Known Member
    Palos Verdes, SoCal
    BlackedOut 07 DC
    K&N Air Charger CAI 63 Series, Flowmaster Delta 50 Series Muffler, Helo Maxx6 Black Wheels 17'', Blacked out headlights, blacked out tail lights, interior neon,, Luminics H4 Pure Blue headlight bulbs, Luminics H10 Pure Blue Fog Light bulbs, 10% tint all around, blacked out emblems, Pioneer In-Dash DVD
    yeah sanding isnt THAT important, its a good idea though to give the paint a little more grip on the surface. and always go with the krylon
  20. Nov 6, 2007 at 10:15 PM
    #40
    spencer_hong
    Palos Verdes, SoCal
    BlackedOut 07 DC
    if anyone personally needs help with the headlights or anything else, im always available on aim at spencerrr13
