Blacking Out Headlights, How to
Discussion in 'Lighting' started by spencer_hong, Jul 31, 2007.
  1. Mar 23, 2016 at 7:41 AM
    #741
    black_cukui
    black_cukui Well-Known Member
    Patrick
    Riverside, ca
    2010 T4R SR5
    I need to do this to mines already. SMH... looks so much better!!!
    cstcyr[QUOTED] likes this.
  2. Mar 23, 2016 at 7:57 AM
    #742
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Do it! :spy:
  3. Mar 23, 2016 at 7:59 AM
    #743
    black_cukui
    Patrick
    Riverside, ca
    2010 T4R SR5
    Ive read some say not to use any additional sealer when closing them back up. This accurate? the left over residue should be good to reseal? this is what I am worried about.
  4. Mar 23, 2016 at 8:01 AM
    #744
    Rippin101
    Jax Beach, FL
    2014 TRD Sport 4x4
    I just used the leftover residue, mine had a ton...
    black_cukui[QUOTED] likes this.
  5. Mar 23, 2016 at 8:04 AM
    #745
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    Are you talking about the OEM seal that originally sealed the headlight, INSTEAD of adding sealer like the GE Window Sealant?
  6. Mar 23, 2016 at 8:06 AM
    #746
    black_cukui
    Patrick
    Riverside, ca
    2010 T4R SR5
    That's what I was referring to.
  7. Mar 23, 2016 at 8:19 AM
    #747
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    Reading the 1st post it doesn't sound like additional sealer is necessary. But I guess if your not seeing any issues after you added additional sealant than its not a big deal.
  8. Mar 23, 2016 at 8:31 AM
    #748
    Rippin101
    Jax Beach, FL
    2014 TRD Sport 4x4
    Correct.
    AKSig88[QUOTED] likes this.
  9. Apr 4, 2016 at 7:39 AM
    #749
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    Definitely worth doing.....Krylon Fusion Satin Black FTW! I also didn't use extra adhesive, hopefully it will hold up, but I do have GE sealant on stand-by just in case.
  10. Apr 4, 2016 at 8:41 AM
    #750
    black_cukui
    Patrick
    Riverside, ca
    2010 T4R SR5
    ^^:thumbsup:
    AKSig88 likes this.
  11. Apr 4, 2016 at 3:41 PM
    #751
    Rippin101
    Jax Beach, FL
    2014 TRD Sport 4x4
    Nice work :thumbsup:
  12. Apr 4, 2016 at 3:50 PM
    #752
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    Thanks, best mod thus far!
  13. Apr 4, 2016 at 7:36 PM
    #753
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    I've been reading this and it's a cool mod. As a paint/ body man I can tell you the main purpose for sanding the chrome is toscuff the surface to promote adhesion of the paint. Spencer has done a great job here of giving detailed instructions. You will benefit the most from scuffing the surface with the sand paper, wipe it clean with a little alchohol or I'd use a little thinner or prep solvent, then spray the surface with a light dusting of acid etchng primer, and paint with your desired color. You should be able to find aersol cans of etching primer in any respectable auto parts stores that carry sutobodu suplies. It promotes adhesion and should help all your hard wsork last longer.
    Snowtrooper17 likes this.
  14. Apr 4, 2016 at 7:43 PM
    #754
    black_cukui
    Patrick
    Riverside, ca
    2010 T4R SR5
    What grit sandpaper? Gonna try and tackle this soon.
  15. Apr 4, 2016 at 7:46 PM
    #755
    Rippin101
    Jax Beach, FL
    2014 TRD Sport 4x4
    One of my favorites as well! ;)
  16. Apr 4, 2016 at 8:43 PM
    #756
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    600 like spencer said is fine nothing special really I'd just go with 400 grt or finer
  17. Apr 5, 2016 at 9:43 PM
    #757
    TacoShopper
    TacoShopper Member
    2005 double cab
    plasti dipped rims. 10 in. Sub and kenwood stereo
    How did you black out the headlights???
  18. Apr 6, 2016 at 6:02 AM
    #758
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    TacoShopper[QUOTED] likes this.
  19. Apr 6, 2016 at 6:51 AM
    #759
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    So you haven't read this thread? Haha
    scottalot likes this.
  20. Apr 6, 2016 at 9:28 AM
    #760
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    How long is this process from start to finish?
