blacking out the badges, HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stillfly199, Oct 18, 2009.
  1. Oct 18, 2009 at 3:16 PM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I am in town getting the stuff to do the bhlm and to black out my badges, what kind of double sided tape do I need? I can't do a good search on this phone, sorry I know its probably been covered a million times, thanks in advance
  2. Oct 18, 2009 at 3:17 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Dont worry about it. Look for the double sided 3M interior exterior mounting tape
  3. Oct 18, 2009 at 3:18 PM
    DanGer
    This is what I used[​IMG]
  4. Oct 18, 2009 at 3:19 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    So super strong exterior mounting tape?
  5. Oct 18, 2009 at 3:22 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Also, they didn't have any adhesion promoter, do I need it? I got the bonging to plastic pant.
  6. Oct 18, 2009 at 3:44 PM
    DanGer
    The super strong wasn't ideal but it was all i could find. I also could not find any adhesion promoter so I went on and did it without it. Its a little soon to tell if it mattered or not, but so far so good (almost a year)
  7. Oct 18, 2009 at 3:49 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I'm just going to try it without, 3 places didn't have it and they had no clue what it was, screw it, thanks a lot
  8. Oct 18, 2009 at 5:04 PM
    DanGer
    Same story here. I checked lowes and Kmart since they are adjacent. Then home depot and walmart. No one had even heard of it
  9. Oct 18, 2009 at 5:18 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I got all the paint to do sliders, BHLM, and the emblems, but the weather is turning south, so I think I am gonna have to wait a week to do this. Did you rough up the emblems at all before you painted?
  10. Oct 18, 2009 at 5:20 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    I found adhesion promoter at Pep Boys. Try an auto parts store!
  11. Oct 18, 2009 at 5:22 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I used 3m decal and emblem adhesive, you can find it at any auto parts store.
  12. Oct 18, 2009 at 5:32 PM
    DanGer
    I hit them with some fine sandpaper, not sure what grit. I spent about 5 mins on each then whiped them down with rubbing alcohol. Then put about 5 coats on them.
    I did this during the down time on my WhiteHLM
  13. Oct 18, 2009 at 5:43 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Did you use silicone to do the WHLM? What did you set your lights on in the oven?
  14. Oct 18, 2009 at 5:45 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I think I am just gonna rough them up with sand paper, I might try to find some adhesion promoter tomorrow though, thanks
    I got the same tape dgerm was talking about, what is the emblem adhesive?
  15. Oct 18, 2009 at 8:07 PM
    DanGer
    I actually tried out the 3m Emblem adhesive first (if we are talking about the tubed glue) and that shit sucked. It got all over everything, didnt set well and ate threw threw the krylon fusion.
    I set my oven at 250 i believe, for 8 minutes. It didnt do shit so i put it in for another 15 and they came right apart. Mine did not seal up well so when i redid it i at 250 for about 20 minutes, it still did not come apart but another few minutes softened it up.
    I put a bead of clear silicone window sealant all along the headlight, put it back in the oven then pushed it all together and it worked flawlessly
  16. Oct 18, 2009 at 8:44 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ok, so I have never taken apart a headlight, I'm sure I will figure it out when I go to do it, when you put the headlight in the oven is the bulb stilll in it? Then when you put it back in the oven you put the silicone on, put it together lightly and put it in, then when you pull it out you smash it together tight? Not sure if what I wrote makes sense, but it did to me lol.
  17. Oct 20, 2009 at 1:33 PM
    DanGer
    Haha I understand. No you remove all of the plastic/rubber grommets from the back of the headlight. Then you remove the main bulb, as well as the 3 screws holding back of the headlight to the front.
    After you bake them and open them up, you will have two screws in there holding the part you want to paint to the headlight. Remove those to get that piece loose. For these I sanded all the chrome I could off and cleaned with alcohol.
    I put the silicone on it only the second time around, and only the passengers side since it was the only one fogging. I put it on, left them separate, baked them, them smashed it together when I took them out.
  18. Oct 20, 2009 at 2:41 PM
    SCCAKen
    SCCAKen Well-Known Member
    Ken
    Atlanta, GA
    09 Access Cab V6 Auto TRD Off Road
    Weathertech floor liners, MacNeil dark window deflectors, debadged, dedecaled.
  19. Oct 20, 2009 at 2:43 PM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    I used that as well and haven't had any problems.
  20. Oct 20, 2009 at 5:33 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Me too. great stuff.
