Blackstone Oil Report - 4.0L Penn Plat. 5w-30
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MX81, Jan 24, 2011.
  1. Jan 24, 2011 at 6:38 AM
    MX81
    MX81 [OP] Well-Known Member
    Dallas
    2014 TRD Offroad PreRunner
  2. Jan 24, 2011 at 6:41 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    now we know who u are and where you live :cool:
  3. Jan 24, 2011 at 6:53 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Nice Report. What type of oil and air filter are you using and the mileage on the Tacoma?
    Higher than normal copper may be because the mileage is low and the engine is still breaking in. Usually Blackstone will reference that in the initial paragraph.
  4. Jan 24, 2011 at 6:53 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Should smudge out PII like address, phone, name.
    Are you going to run it for an extended drain? It looks like the analysis says to check back in 6000miles but they didn't to a TBN analysis.
  5. Jan 24, 2011 at 6:55 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    The oil has 5K on it but the unit (vehicle) has 32k on it. Hardly break in.
  6. Jan 24, 2011 at 7:00 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I just relooked at the report. Yup 32K s all broken in. I would not worry about the high copper unless it shows an even wider gap at the next sample.
    I have my oil samples taken all the time. I also have a GM 3800 engine which traditionally have high copper readings.
    The silicon being low and no water or antifreeze in the oil are major pluses.
  7. Jan 24, 2011 at 7:14 AM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Very intersting, how would I go about getting my oil analized?? What is the cost?
  8. Jan 24, 2011 at 7:21 AM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
  9. Jan 24, 2011 at 9:06 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    I just went to that link and requested a sample kit. I'm going to send in mine when I hit the 30K mark. My OCI is 10K miles. I want to see if I should back that down or if I'm fine to leave it there.
  10. Jan 24, 2011 at 11:23 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I would be interested in the results. I was never to go over 7.5K and feel comfortable with the results in a GM 3800 engine or over 5K with a GM 4.3L engine.
    This is my 1st Tacoma in a very long time and it would be nice to know that 10K is doable.
  11. Jan 24, 2011 at 11:50 AM
    kramer2k
    Jacksonville, FL
    I'll tuck this post away in my mental file cabinet. It'll be a few more months before I reach 10K on this oil. But I'll be sure to reference this post and let you know the results when I do receive them.
    When I had my 2004 Maxima I also used the 10K OCI and never seemed to have any problems with the oil. Granted, that wasn't a scientific observation. It's just that my oil always looked great at the time of oil changes. I was able to go through 4 separate 10K OCIs on that car.
    For reference, I use M1 5W-30 full synthetic and a high capacity M1 filter.
  12. Jan 24, 2011 at 12:10 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I really think 10K oci's are safe with most synthetic oils, but even petroleum oils but with less margin. The real limiter is the TBN...total base number. It's a measure of how much buffer the additive package has to deal with corrosives that accumulate.
    Many modern synthetics are designed for extended drain and have a very heavy dose of additives that provide a healthy TBN...if you use one of those oils you're probably very safe for 10k, and 15k or more with UOA's like OP did.
    Mobil1 Extended drain and Penn Platinum are two of them that are widely available.
    More and more OEM's are increasing drain intervals under warranty too...Toyota has starting with 2010 Camry's I noticed.
  13. Jan 24, 2011 at 1:20 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    Do you have the tow pack on your truck? If so I think your slightly elevated copper is due to the auxilliary water-to-oil cooler leaching copper into the oil. It will likely trend down for 50-60k miles before flattening out. If you had a bearing issue that copper would generally be accompanied by traces of both lead and tin. Good report!
  14. Jan 24, 2011 at 1:30 PM
    MX81
    Dallas
    Thanks...yes it does have the Tow Package. I regret not doing the TBN analysis, I will do that on my next one.
  15. Jan 24, 2011 at 1:47 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    TY
    I have been using Red Line 5W-30 with a K&N filter changing every 5K miles. I am coming up on 20K and would like to extend the oil drain a little.
  16. Jun 20, 2011 at 2:18 PM
    kramer2k
    Jacksonville, FL
    As promised, I have returned to post the results from my Blackstone Labs Oil Analysis report.
    I put ~8,500 on the analyzed in this report. My plan was to go to 10,000 miles, but I got curious (anxious) and wanted to see how it was doing. Needless to say, I'll be going to 10,000 in the future since all appears to be in order with the engine according to the report.
    http://dl.dropbox.com/u/14170507/Tacoma Oil Analysis (Redacted Copy).jpg
  17. Jun 20, 2011 at 8:28 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    How much did this run you if you don't mind sharing? I know lots of my fellow M Car forum members do this but you are the 1st Toyota owner I've seen do it.
  18. Jun 21, 2011 at 6:16 AM
    kramer2k
    Jacksonville, FL
    It is free to request the oil analysis kit and $25 when you send it back in for the analysis. You can also pay an an optional $10 additional if you'd like the TBN analysis to determine the amount of additives remaining in the oil.
    Go here to request your free kit.
    http://www.blackstone-labs.com/free-test-kits.php
    It appears my public Dropbox link in the previous post when dead. I'll remove the embedded IMG tags and merely link it to the JPEG of the report.
    I'll also be getting a report done on my Corvette oil when the time arrives. I want to go to 10K OCI on that oil too. For reference, the analysis was done on Mobil1 5W-30 oil, not the Penn Plat. 5W-30 referenced in the thread title.
  19. Jun 21, 2011 at 3:23 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Very good report. Some engines spit copper more than others. GM 5.3 are known for this also. I would do a TBN and stretch that OCI longer. I own a 97 GMC with a 5.7 and run 8K OCI or 1 year whichever comes first.
  20. Jun 21, 2011 at 3:32 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Thanks for the clarification. I was wondering...
