Bleeding brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jolly Onion, Dec 19, 2016.
  1. Dec 19, 2016 at 7:57 PM
    Jolly Onion
    Jolly Onion [OP] Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    Merry Christmas and Happy New Year to everyone.
    1) We all know Toyota recommends DOT 3, and many agree that DOT 4 is fine to use as it has a higher boiling point. Is this 100% true? I do not want to damage seals etc.
    2) I would like to use a different color brake fluid as well. What do you use?
    3) Has anyone used a syringe for bleeding brakes? Seems like a clean, one man way of doing the job with no air bubble issues.
    https://www.amazon.com/VvW-Plastic-...coding=UTF8&psc=1&refRID=2MP2Q79T46NANEMMFBW6
    Also a nice tool to have for taking out excess oil, trans fluid etc.
    Have a good one Gentlemen.
    Alex
  2. Dec 19, 2016 at 10:22 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I've mixed them and subsatuted Dot 4 for dot 3. They're foward compatible. You can't put dot 3 inn a dot 4 system.
  3. Dec 20, 2016 at 10:01 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
  4. Dec 20, 2016 at 4:37 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
  5. Dec 20, 2016 at 5:08 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Carefull with dot 4. It will withstand higher heat, the down side is it will also attract moisture. Your not on a race track pushing hard on your parts, no need for #4.
  6. Dec 21, 2016 at 9:28 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Thanks for the info
    What brand DOT 3 do you recommend that is a different color than the factory color. I want to see the new fluid coming out and the color will help my old eyes see it better.
  7. Dec 21, 2016 at 9:38 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    All brake fluid will pull moisture from the air if left open in the bottle or master cylinder cap left off for extended periods. Why not go the easy route and get a piece of tubing that fits over the bleeder then put that into a bottle partially filled with brake fluid. One man job!
    Sicyota04 likes this.
  8. Dec 21, 2016 at 9:48 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Can't say that i've ever seen brake fluid purposely colored. It's clear with a slight haze of blue or turning brown form moisture.
  9. Dec 21, 2016 at 12:55 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Thanks Gents for the replies
    What DOT 3 brand do you prefer?
    mechanicjon likes this.
