Blend door actuator and heater control valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Megacolor, Jan 6, 2018.
  1. Jan 6, 2018 at 6:40 PM
    Megacolor
    Megacolor [OP] Well-Known Member
    Tony
    Hello, maybe someone can help. Do anyone know where the blend door actuator and heater control valve are located on a 2015 Tacoma?
  2. Jan 7, 2018 at 8:01 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The blend door does all the work between hot and cold. There is no heater control valve, the heater core gets flow all the time. The blend door controls the hot to cold air ratio. Everything is controlled by servo motors. See picture below. The blend door is called the Air Mix Control.
    Jeffs68, FastEddy59 and Megacolor[OP] like this.
  3. Jan 7, 2018 at 9:24 AM
    Megacolor
    Tony
    Thanks for this info...good stuff here...helped out a lot! Anyone know the part number for the "air mix control servomotor"? I google it and can't seem to find the part number.
  4. Jan 7, 2018 at 5:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  5. Jan 8, 2018 at 6:57 AM
    Megacolor
    Tony
    thanks!
  6. Jun 13, 2021 at 7:23 PM
    TomDickandHarry
    TomDickandHarry Available
    Dick
    2007 sr5
    Has some pretty sweet seat covers
    Thank you.
  7. Jun 13, 2021 at 7:46 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
