Blinker Help.
Discussion in 'Technical Chat' started by TuckGraham, Jul 8, 2014.
  1. Jul 8, 2014 at 4:21 PM
    TuckGraham
    TuckGraham [OP] Keep it straight
    Tuck Graham
    Colorado
    SR5 TRD Tacoma
    Overland
    Everytime I turn on my truck, my blinker click sound starts to go without the blinker even being on. It happens before and after i turn on my blinker, and will keep going at a steady pace. I have checked to see if its the bulb, but they seem fine. Does anyone know if you can either turn off the sound or a way to fix it?
    Thanks
  2. Jul 10, 2014 at 5:28 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just Lurking in the Darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    BHLM with amber LED "eyebrow" strips and Angry Red Eyes, Black Depo Tail lights, Knight Rider Hood Scoop Mod, Amber Grill Backlighting, Amber Lamin-X Fog light film, Fog Lights Anytime Mod, Black T-Rex Grill Inserts, Red interior LED lighting, Go Rhino 5" Oval Nerf Bars, Modified side mirror turn signals, Drill-less license plate relocation bracket. OEM Bed mat. Weather Tech floor mats.
    When you hear the clicking, do any of the turn signals on the outside of the truck actually light up?
    Do the turn signals work normally when you activate them?
    Could it be that your hazard light button is pushed in?
    -just asking.
  3. Jul 10, 2014 at 5:32 PM
    TuckGraham
    Tuck Graham
    Colorado
    SR5 TRD Tacoma
    Overland
    1. No they do not light up, just the sound.
    2. Yes, no problems.
    3. Nope checked that first.
    And the clicking is very fast, like the light is out, but i replaced them and they are fine.
  4. Jul 10, 2014 at 5:39 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Sounds pretty strange. Its like the flasher relay is being told to flash and is sensing a bad bulb at the same time.
    You could try replacing the flasher relay and see where that gets you.
    Just out of curiosity, what year is your truck and do you have daytime running lights that use the same bulbs as the front turn signals?
    Oh. I just saw you have a 1999 and bed lights. Did you happen to splice the bed lights into the trailer wiring by any chance?
  5. Jul 10, 2014 at 5:49 PM
    TuckGraham
    Tuck Graham
    Colorado
    SR5 TRD Tacoma
    Overland
    Um, No i have just recieved them and have not wired them up yet. and they are individual so a blinker and a running light. where is the relay located at, i have not checked that yet?
  6. Jul 10, 2014 at 6:05 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    I'm not sure exactly where the blinker relay is located on the '99, but it's under the dash. You can probably follow the sound to the source.
    Its still strange that it would be clicking by itself when you turn the ignition on[I'm assuming] It would seem that something is telling it to activate, but it would also seem that it would be lighting up something at the same time.
    Here's a thought... The turn signal lever not only activates the relay, but also selects which signal to flash. maybe the switch in the lever that controls the relay is bad and is activating the relay all the time when neither blinker is selected. This would explain the fast flash speed of the relay when no turn signals are selected.
  7. Jul 10, 2014 at 6:14 PM
    TuckGraham
    Tuck Graham
    Colorado
    SR5 TRD Tacoma
    Overland
    I will take a look at it all this weekend. Do you happen to know if its possible to just turn the sound off or disable it at all?
  8. Jul 10, 2014 at 6:21 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    The only way I can think of would be to pull out the relay or disconnect the turn signal lever/switch from the wiring in the steering column. Either way would also disable your turn signals.
    You also might see if there is a fuse for the turn signals, but this may disable other things as well.
    I have seen some cheap foam earplugs at Lowes and Home Depot. :rolleyes:
