Blistein 5100 Questions
Discussion in 'Suspension' started by Southernsurfer, Apr 16, 2009.
  1. Apr 16, 2009 at 4:22 PM
    Southernsurfer
    Southernsurfer [OP] Well-Known Member
    FL
    2007 DC LB 4X4 TRD Sport
    Bilstein 5100 Rears & Fronts @ 1.75 / TSB 4 Leaf Pak / TRD FJ SE Anthracite wheels w/ BFG AT KO's 265/75/16 / Satoshi Grille w/Hella 500's / Blacked Out headlights / OEM LED Tail lights / 15% Llumar Tint De-Badged / OEM Front Skid Plate / Vinyl/Leather arm-rest mod / Weather Tech mats / TRD seat covers / Tacoma LB Bed mat / Door sill protectors / OEM Class IV Hitch / JL 500/1 w/2 JL 10" Subs / JL Audio Frnt & Rear speakers / Alpine IVA-W505 w/Bypass
    My plan........ to install 5100's on all four corners of my 4X4 DC LB and have the TSB leaf pack done.
    I'm looking to set the front to 2.5 and I've purchased the ToyTec TSB AAL for an additional 1.5" in the rear. Along with the ToyTec diff drop
    I'm going to be installing a set of FJ TRD 16"s and I'd like to know if I should wrap them in 265/75's or 285/75's
    If I choose the latter will I have UCA issues if so I'd rather stay with the 265's
  2. Apr 16, 2009 at 4:33 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I have yet to hear that you have to put a spacer to level it out.
  3. Apr 16, 2009 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Some people have done this if the truck leans more than 1/2".
  4. Apr 16, 2009 at 4:47 PM
    Southernsurfer
    FL
    I've never noticed a lean on my truck, That's what had me curious about said spacer
  5. Apr 16, 2009 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If its stock, you shouldnt have any lean. Aftermarket springs need an slight preload on the driver side to account for the extra weight.
  6. Apr 16, 2009 at 11:25 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Toytec sells a 1/4" spacer for the drivers side, but like Chris said, people use it with aftermarket springs.
    When you change your shocks to the 5100's mark the springs left and right. Don't swap sides.
  7. Apr 17, 2009 at 12:57 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    When I installed my AAL's in the rear a few weeks ago I measured the height from fender to ground on all 4 corners of my truck..... turned out it leaned 1/4" to the passenger side. That was with a full tank of gas too.
  8. Apr 18, 2009 at 3:49 PM
    Southernsurfer
    FL
    ^^ was that with stock TRD coils or Aftermarket. I'm staying with the stock TRD coils.
    OP updated as I've re thought my plan :D
