Block Heater Install on a 2.7ci
Discussion in '4 Cylinder' started by brohloff, Sep 12, 2008.
  1. Sep 12, 2008 at 9:04 PM
    brohloff
    brohloff [OP] '18 DCSB 4x4 Sport Cement
    MN
    '18 DCSB 4x4 AT Cement
    Have an '07 4x4 Access Cab 2.7/5spd. Bought a OEM (Toyota/Canada) for it and just now getting around to doing the install.
    Is this a difficult install? Which freeze plug location does it go in? How accessible is the freeze plug? Any words of wisdom before I crawl under and start draining antifreeze?
    Thanks in advance for any info from someone who's done the install........ bob...
  2. Sep 17, 2008 at 4:51 PM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I was in ND and MT and always liked the stick on heat pads for the bottom of the oil pan. I never liked block heaters. Keep the oil warm. Block heaters only heat on side of the motor and cook your coolant. Get a cold front for half the radiator and a stick on pad heater and you will be fine. Also if the pad goes bad its like 2 minutes to replace it.
  3. Oct 15, 2008 at 7:24 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    I want more info on the heat pad if that is cool? It gets pretty cold on sum of those northern mornigs!
  4. Oct 29, 2008 at 1:46 PM
    foxxtrot
    foxxtrot Member
  5. Oct 29, 2008 at 1:53 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    how much are they?
  6. Oct 29, 2008 at 2:21 PM
    foxxtrot
    foxxtrot Member
    check the link and it is by size. I am thinking about getting one as well.
  7. Oct 31, 2008 at 4:41 PM
    Toynbyu
    Toynbyu Active Member
    I like the plug-in dip-stick. you don't need much heat and this seems to work just fine.
  8. Apr 21, 2009 at 6:02 PM
    Patrick
    Patrick Well-Known Member
    hey im in fairbanks i have all three hooked up, oil pan,battery blanket,block heater. It got to -60 last winter. My 4 cyl was starting up nicer then some of friends v8. I had the dealership install they gave me a good deal since it was a new truck just under two hundred for all three hooked up.
  9. Apr 21, 2009 at 7:00 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Red Flag warrior are ya?
  10. Apr 22, 2009 at 6:47 PM
    Patrick
    no im backshop I use to be at barksdale though. How do u like it there ?
  11. Apr 22, 2009 at 6:56 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Been here since 2000. We actually like it here...central to the whole country and out of the snow! I'll retire here in a couple years when the wife graduates pharmacy school (ULM).
    What backshop? I'm a weapons dude.
  12. Apr 22, 2009 at 6:58 PM
    Patrick
    Machine and Welding Shop, Metals Tecnology
    I was there from from 05-08 I liked it, def had a good time it was time to move on. I bought my truck from Yokem over in the auto mall.
  13. Apr 22, 2009 at 8:24 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    I hear ya...I'm late in my career, so I am much more content to finish out here. I used to like to move every 4 years or so and see different places (which we did). Enjoy the frozen tundra up there and keep that happy light nearby.:D
    Wish I had a contact here in the fab shop...got a few ideas to run by someone willing to do some "projects". I used to when I got here, but he PCS'd. I've always noticed dudes there with some pretty heavily modded trucks/cars.
  14. Dec 13, 2013 at 9:45 AM
    biker105nn
    biker105nn Active Member
    omaha
    09 tacoma
    1.) 2012 touch screen Panasonic stereo. 2.) Plasti-dip steelies
    These pad heaters are an awesome idea, does the size matter any suggestions? I have a 2wd 4banger in Nebraska, it will drop to -10 at night in the winter.
  15. Dec 13, 2013 at 10:23 AM
    biker105nn
    omaha
    09 tacoma
  16. Dec 14, 2013 at 4:31 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  17. Dec 14, 2013 at 9:19 PM
    vtmactech
    vtmactech Well-Known Member
    KS
    '11 Reg Cab 4cyl 4x4 MGM
    Anyone have a pic of the heating pad installed and how the cable was routed? Thanks.
  18. Dec 14, 2013 at 9:24 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  19. Dec 14, 2013 at 11:58 PM
    george3
    New Jersey
    I don't have a pic but I just ran it up to the grill and cable tied it here and there then I tuck the plug out of sight behind the grill when not in use.
