block lift question???
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeff6001, Nov 2, 2009.
  1. Nov 2, 2009 at 8:56 AM
    jeff6001
    jeff6001 [OP] Well-Known Member
    San Antonio, TX
    99 trd prerunner
    So my rear block lift came in and i was going to install it this weekend but realized that their's a wire that goes across the axle. I assume that it is the e-brake line, but my blocks are 2" and if i install them then the line will hit my leaf springs. Any solutions to this fix????
  2. Nov 2, 2009 at 9:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    There should be an aftermarket relocation bracket to move the cable.
  3. Nov 2, 2009 at 9:16 AM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    What about where it connects to the drum in the rear??? Has anybody else had this problem???
  4. Nov 2, 2009 at 10:42 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Just let it drag. or you need to get brackets to move the cable up. but is still going to rub..
