Blower and aAC quit
Discussion in '1st Gen. Tacomas (1995-2004)' started by hondamaint, May 25, 2010.
  1. May 25, 2010 at 7:18 PM
    hondamaint
    hondamaint [OP] New Member
    Alabama
    97 4 cylinder short bed 2wd
    Got in my little truck this morning and the blower motor would not come on in any postiion and the AC compressor would not come on,the blue light on the button would not light up either. Checked the fuses and all were good.Any ideas.
    1997 Tacoma 4 cylinder with 216,000miles
  2. May 25, 2010 at 8:18 PM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    my dryer wasnt working and they replaced my hose and o ring... now its all good
  3. May 25, 2010 at 8:40 PM
    hondamaint
    Alabama
    It is an elec. issue I am sure. The AC sealed system is fine.
  4. May 26, 2010 at 5:26 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Did you check *ALL* the fuses involved in the HVAC system? ....
    10A Gauge
    40A Heater
    10A A.C.
    80A Alt
    A blown heater relay would also explain it.
  5. May 26, 2010 at 2:04 PM
    hondamaint
    Alabama
    I at first checked the heater and AC fuses and all were good. I found a 10amp fuse that goes to the lights on the panel located in the inside fuse box that had blown.This fixed the issue. I had unplugged my trailer earlier in the day and had the headlights on so I guess the spike blew the fuse.
    Hope this helps someone else out.
    Blower and AC compressor quit, check 10 amp inst. light fuse inside fuse box.
  6. May 26, 2010 at 4:23 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Yep - that's the 10A Gauge fuse.
    Glad that's all it was ...
