Blower Fan for AC doesn't work on High setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TacoTrD, Dec 15, 2019.
  1. May 27, 2020 at 9:48 PM
    Muddinfun
    Muddinfun Well-Known Member
    Yep, that’s it. Here’s the part numbers for the connector housing and pigtail.
    M61guru, Jimmyh and VYPER like this.
  2. Jun 1, 2020 at 9:45 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    So im guessing you just cut the burnt part of the wire and splice in the new pigtail?
    wilcam47 likes this.
  3. Jun 28, 2020 at 7:27 PM
    Brendan Lagather
    Brendan Lagather New Member
    2011 Toyota Tacoma
    My 2011 Tacoma just got the same problem. I remember a strange smell, but did not notice the high speed fan not working. I checked the Heater Relay and Fuse. Both were OK. To no ones' surprise, my switch looks exactly like yours. Are the part names as Muddinfun described them or does Toyota use different names. Where I live in Hawaii, we only have the dealership, Napa, and Autozone...No salvage yards at all. Also, any suggestions for used parts online?
    Best regards,
    Brendan
  4. Jun 28, 2020 at 8:46 PM
    Muddinfun
    Welcome to TW. Order the parts shown in post #21 above, from the Toyota dealer and buy a used climate control off ebay. Make sure you get the correct year range. Somewhere in the middle on the 2nd gen run, they changed things. I don’t know what year they changed. If you get it wrong, the temp control will be backwards. After you get all the parts, transfer the unburned terminals to the new housing. Then cut off the burned terminal and solder on the new pigtail.
    Jimmyh likes this.
  5. Jul 12, 2020 at 4:51 PM
    VYPER
    VYPER Well-Known Member
    Alex
    2010 Silver Tacoma TRD
    Sooo.... I know what to do to fix the high setting. But the AC unit doesn't work at all now. I wiggled the wires around on the bottom where the sensor plugs in and it turns on but when I turn the AC off again, it doesn't turn back on. I tightened all the bolts under the dash, same problem. I pull out that plug just a tad and it turns back on. Somehow the plug isn't inserting correctly? Any advice would be greatly appreciated
  6. Jul 14, 2020 at 8:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    M61guru likes this.
  7. Jun 20, 2025 at 3:01 PM
    VYPER
    Alex
    So what should one do if they buy a new ac unit and its the wrong one. How can someone reverse hot to be cold and cold to be hot.. Since it's now reversed. Asking for a friend...
  8. Jul 19, 2025 at 10:09 AM
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    Any chance there’s a video of popping that whole piece out of the dash and switching this?
