Blower motor issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dr. Hook, Sep 11, 2020.
  1. Oct 14, 2020 at 5:33 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Now the light blinks but it’s not making the squeal :notsure: WTF
  2. Oct 14, 2020 at 5:39 AM
    lynyrd3
    Bill
    Weird .......... maybe it only does it after the truck is warmed up and going down the road
  3. Oct 14, 2020 at 5:43 AM
    lynyrd3
    Bill
    Feels like the AC is working . Hard to tell it’s cold outside . Turned the heat on and AC button blinks until I push it then it goes off . But no noise like it has been ,heat is working . . I’m going to take it for a ride and see what happens . Thanks
  4. Oct 14, 2020 at 5:46 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Let us know, Open the hood and look at the clutch on the compressor when it is running. It should turn on and off in a cycle.
  5. Oct 14, 2020 at 5:54 AM
    lynyrd3
    Bill
    Just went down the road . Heat works . No squeal now . AC squeals . Looked under hood while it was squealing and it actually sounds like it’s coming from driver side of engine ?
  6. Oct 14, 2020 at 6:00 AM
    lynyrd3
    Bill
    Trying to post a 12 second video of the noise but it’s not working :annoyed:
  7. Oct 14, 2020 at 6:01 AM
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    My blower has made noise since I got it. I learn to just zone it out. Still works, just has a little chirping noise.
  8. Oct 14, 2020 at 6:02 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    What is the AC Compressor clutch doing? Is it spinning in the center?
  9. Oct 14, 2020 at 6:03 AM
    lynyrd3
    Bill
    What is the pulley below the alternator? Must be part of AC system??? Passenger side is what looks like AC to me ? Mechanically challenged o_O
  10. Oct 14, 2020 at 6:04 AM
    lynyrd3
    Bill
    Power steering on the passenger side my bad
  11. Oct 14, 2020 at 6:06 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is where the compressor is located...
    Look at the center of the pulley. With the AC on it should be turning with the belt and outer pulley.
    lynyrd3[QUOTED] likes this.
  12. Oct 14, 2020 at 6:06 AM
    lynyrd3
    Bill
    Ok I got it . Nope ,center not spinning :oops:
  13. Oct 14, 2020 at 6:08 AM
    lynyrd3
    Bill
    Guess I need a compressor. I read somewhere you should also replace condenser and dryer if replacing the compressor. What are your thoughts on that . ?
  14. Oct 14, 2020 at 6:11 AM
    lynyrd3
    Bill
    Also any recommendations other than OEM ? Thanks for your help !
  15. Oct 14, 2020 at 6:12 AM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes definitely.
    Replace the Compressor, Condenser / Dryer (are together as one unit), the inline filter going to the expansion valve and everything has to be flushed clean or replaced if the compressor is blown.
  16. Oct 14, 2020 at 6:24 AM
    #36
    lynyrd3
    Bill
    Ok ,thanks again for your help ! I appreciate it !
  17. Oct 14, 2020 at 11:43 AM
    #37
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    it might be the easiest project i've ever worked on. easy easy.
  18. Oct 14, 2020 at 2:24 PM
    #38
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    You could try just replacing the clutch, in case it’s frozen (though they usually bust ‘busted’ - spinning - and they usually go soon before the compressor goes). For like $20 it’s worth a shot though.
    lynyrd3 likes this.
  19. Oct 14, 2020 at 2:33 PM
    #39
    lynyrd3
    Bill
    AC compressor unfortunately. Blower motor is fine :oops:
  20. Oct 14, 2020 at 2:48 PM
    #40
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
