Blower motor power relay shorting out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jgomes99, May 29, 2017.
  1. May 29, 2017 at 5:50 PM
    Jgomes99
    Jgomes99 [OP] New Member
    Justin
    07 Tacoma PreTunner
    6" Fabtech lift K&N cold air intake 33" treadwright Claws
    Hi y'all. Wanting to know if anyone else has experienced this issue. The power relay going into my blower motor is shorting out. Melted, black, etc. I just switched out the resistor and now my AC system won't turn on at all. I used to have to finagle the connector to get a good enough connection for the motor to turn on and push air. Now absolutely nothing. Dealership is saying it's in the main harness of the truck and I'm not believing so due to no shortage showing on the wires. Any help would be greatly appreciated, thank you.
  2. May 30, 2017 at 1:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    PzTank likes this.
  3. May 30, 2017 at 3:30 PM
    Jgomes99
    Justin
    07 Tacoma PreTunner
    The pigtail connector is what I need. Where are those part numbers from and where could I order that?
  4. Jun 7, 2017 at 1:02 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Those are the Toyota Part Numbers. Dealer, Ebay or any other vendor that carries Toyota OEM Parts.
  5. Jun 7, 2017 at 7:45 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
