Blower motor question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pavlovsdog, Dec 17, 2014.
  1. Dec 17, 2014 at 11:10 AM
    Pavlovsdog
    Pavlovsdog [OP] Active Member
    Tampa, FL
    07 PreRunner 2WD
    So I had the blower motor "chirping" for a couple of months, but honestly it didn't bother me too much. Today the blower motor died. I unplugged it...plugged it back in...gave it a good whack, and it works for now. I can tell it will continue to die, though.
    ...so since this is such an issue with the OEM Tacoma blower motor, does anyone have a suggestion for an after market blower that doesn't repeat the same issues?
    Thanks
  2. Dec 17, 2014 at 11:46 AM
    Pavlovsdog
    Tampa, FL
    07 PreRunner 2WD
    ...for instance Rock Auto has a range of prices, but I'm not really sure if one is better than another
  3. Feb 8, 2015 at 10:41 AM
    MikeinFresno
    MikeinFresno Active Member
    I have the same problem with my old truck. Replaced the motor a few months ago with aftermarket one...worked for a while and now is stopping again...hitting it sometimes makes it work for a day or several before it quits again...still trying to figure it out...wonder if the balancing screws are the answer??
  4. Feb 8, 2015 at 10:49 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Since yours is an '07, I am betting that the blower is the old style one. The newer TSB version is better. No chirps for me since I installed it a few years ago. The P/N should be #87103-04043.
  5. Feb 8, 2015 at 10:49 AM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Toyota has an updated blower motor. Part number ends in -043, I believe. I put one in at least a year ago and haven't heard a peep.
  6. Feb 8, 2015 at 10:50 AM
    TACK
    Nevada
    Haha, he beat me to it.
  7. Feb 8, 2015 at 10:52 AM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    i had the chirp and went to toyota 2 years ago and had it replaced, it i recall it was a delphi and i havent had a chirp since.
  8. Feb 8, 2015 at 5:18 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    This.
    Same here
  9. Feb 8, 2015 at 7:35 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    The new one has bearings. Toyota finally got smart and spent an extra nickel. The old one has oil impregnated bushings. So the new one really is an improvement.
    The best price I found was at ToyotaOnlineParts.com. $99, plus $16 shipping.
  10. Feb 8, 2015 at 7:43 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    Amazon has for $118 and with prime you get 2day shipping plus if there was ever a problem they take everything back.
