Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Jan 5, 2010 at 12:09 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    I forgot to update. The next morning when I go into my truck, I actually cant hear the motor at all, unless the radio is off, from the driver seat. And that's with the glovebox out of the way. I haven't installed the glovebox yet, bc I was going to go back and grease the other bearing.
    I hear a slight flutter when I have the radio off. But if I have the radio on, even with volume level at 8. Can't hear it. :cool:
  2. Jan 17, 2010 at 6:19 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Might have to give this a shot. Has anyone else tried this with success?
  3. Jan 17, 2010 at 9:56 PM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    I might try this if adjusting the screws doesn't work. The squeak has been driving me crazy.
  4. Jan 18, 2010 at 3:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Just a note...
    Brass 'impregnated' bushings will be dry when they're cold. The oils come out when it heats up.
  5. Jan 21, 2010 at 8:39 AM
    14U2NV
    14U2NV Active Member
    Socttsdale
    '12 SR5 4x4
    I ended up damaging the motor trying to pull cage off. I had to break down and buy a replacement motor at NAPA.
  6. Jan 21, 2010 at 6:29 PM
    turboser
    turboser Member
    New York
    white v6 6spd 4x4
    all stock for now
    there is actually a tsb on this... i had mine replaced under extended toyota warranty...
  7. Jan 21, 2010 at 6:45 PM
    HARDSHELLTACO
    HARDSHELLTACO HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
  8. Jan 25, 2010 at 8:20 AM
    AK27
    AK27 Well-Known Member
    thank you ballon78!
    i just did this this morning and it worked perfectly!!! no more crickets!!! :woot:
  9. Jan 25, 2010 at 4:52 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    Hey, my crickets are gone too!!!!!!!!!!!! Now I guess I can't pretend not to hear my wife because of those crazy crickets!!! Took 13 minutes, start to finish.
  10. Jan 25, 2010 at 4:57 PM
    AK27
    took me a lil longer. my fan fins were on really tight. i ended up cracking the thing :eek:
  11. Feb 2, 2010 at 9:55 PM
    WATacoRider
    TRD Sport 4x4
    :rant:Welp, my crickets came back after 1 month.
    So I just removed the blower again. This time, I was able to remove the fin assembly. My truck was trying to pry it slightly with 2 big screw drivers. Then insert a thick strap between the fins and out the other side so I have something to pull up on. Then I placed the outer black plastic on my feet and pull up on my strap. It eventually popped off...
    This time, I greased the top bearing also. I was able to clean up my fin housing.
    Hopefully this time, it lasts longer than a month.
    PS, I was thinking, you know those 2 pieces that are held in place by the 2 springs. Well the foot or whatever you want to call it make contact with the coil assembly.
    I wonder if that contact makes noise too....
  12. Feb 9, 2010 at 8:38 PM
    kylek250
    kylek250 Well-Known Member
    Austin tx
    06 Prerunner debadged Black on Silver
    pioneer stereo, nittos, buckshot rims, debadged, rhino lined skid plate, 2in lift kit, aux bed lights, painted emblem, tinted windows, k&n
    ya i pulled mine apart. cleaned everything. it cured the evil chirp, but left me with a little tick. i even tried the screw adjustment with no luck. Any thoughts?
  13. Mar 10, 2010 at 2:58 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    Worked good for me I took every thing apart and cleaned as per the write up. I used white lithium grease on both the top and bottom bearings and reassembled every thing. Now I can't here the motor at all, well not unless my ear is on the motor. Good job on this wirte up and every one that helped. Its amazing that us average joes can fix a problem that Toyota can not figure out. Hopefully this fix lasts a long time if not I will try to use a thicker grease on the next go around.
  14. Mar 10, 2010 at 3:00 PM
    WATacoRider
    TRD Sport 4x4
    2nd update. After tearing it down completely and greasing that top bearing also, it's been over 1 month and still silent.
    :cool:
  15. Mar 14, 2010 at 2:20 PM
    #35
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Going to attempt this fix. Is the blower that black unit on the left with the 3 5.5mm screws? It has one power connection going to it.
  16. Jul 12, 2010 at 11:39 PM
    #36
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    Can anyone tell me how to get to the blower motor? I just bought an 07 Tacoma Double Cab TRD Off Road and it has the annoying chirping on the fan low through med high settings. I was excited to see there is a fix, but I have no idea how to get to the blower motor to fix it.
    The chirping is driving me nut and I have only had the truck in my posession for less than six hours and 125 miles. please help! :eek:
  17. Jul 13, 2010 at 5:19 AM
    #37
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The pics in this thread might help http://www.tacomaworld.com/forum/2nd-gen-tacomas/63959-anyone-else-have-squeaks-c-blower-assembly-2.html#post1287613
    It's located under the dash on the passenger side. Three 10mm (?) bolts hold it in. Check out the pictures in the above thread and you should see the same shape under your dash.
    You also should check your cabin air filter (located behind the glove box) to see if it needs to be changed. Some of the 05 trucks came with the slot for the cabin filter, but without a cabin filter installed. If the previous owner or dealership didn't put a new one in there, it could probably use it. Who knows, maybe they just took the dirty one out and didn't replace it. Anyways, the blower motor typically chirps in the cold weather so maybe you have some debris in there.
  18. Aug 24, 2010 at 10:27 PM
    #38
    DevL
    DevL Well-Known Member
    Does the TSB have a new part or do they put the same defective part back in?
  19. Sep 21, 2010 at 12:27 PM
    #39
    Krusey1011
    Krusey1011 Well-Known Member
    Kyle
    Washington
    This info helped alot when I got to this part. I just put two pieces of tie down string under each side of the fins and put the black plastic at my feet and started wiggling. Thanks alot this would have frustrated me if not for your input.
    I tried balancing the fan the other day with success but it only lasted a day and the tick was back. I'm trying this fix now even though I have more of a tick than a chirp.
    Thanks for sharing your inputs and thanks to the OP for the post.:D
  20. Sep 21, 2010 at 2:05 PM
    #40
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Just did this. Couldn't believe how much crap was inside the motor. Runs a lot cleaner now!
