Blown acc fuse
Discussion in 'Towing' started by chkntaco, Dec 20, 2010.
  1. Dec 20, 2010 at 12:35 PM
    chkntaco
    chkntaco [OP] Member
    The towing accessory fuse that you use for trailer lights keeps blowing and I can't understand why.
    It works fine for trailer lights but I just recently made a connector for my winch and it keeps blowing. The winch doesn't pul that much voltage. Its just a small 2000lb capacity that I use to pull my CRX onto my already super low trailer. The fuse is a 30amp Any ideas before I burn up the wires?
  2. Dec 20, 2010 at 12:40 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Are you pulling the juice for the winch straight from the battery or through the circuit?
  3. Dec 20, 2010 at 12:42 PM
    98tacoma27
    Ben
    Not Beech Creek
    ^^This^^
    I'd run that winch directly from the battery. Otherwise you are trying to pull 30 amps through a 14 gauge wire (maybe even 18 gauge).
  4. Dec 20, 2010 at 2:00 PM
    chkntaco
    I hooked up the winch wiring to a connector that plugs into the trailer light outlet. So, yes through the circuit. That way i wouldn't have to run wires all the way to the front of the truck.
    I used to run wires all the way up front and everything worked fine. Just trying to save time and not have to lug around a bunch of wires. Seemed like a good idea at the time but I didn't realize the wiring was freakin' 18g.
  5. Dec 20, 2010 at 3:52 PM
    macgyver
    Brad
    Canton, GA
    Yeah that small gauge wire isn't meant to handle the amperage that winch is pulling. Luckily the fuses are doing their job keeping the wiring from melting.
  6. Dec 22, 2010 at 7:05 PM
    chkntaco
    So is running wires straight to the battery pretty much my only option? Is that how the "off road" guys do it?
    I don't take my truck out in the mud so I haven't had any other use for a winch
  7. Dec 22, 2010 at 7:17 PM
    Tacoma2011
    Tacoma2011 Toyoma
    Sahuarita
    2011 Prerunner SR5 LB
    One of the 7 wires is a 30 amp, 10 ga wire for charging the trailer battery. Move your winch connection to that pin. Look in the manual for the pinout.
  8. Dec 23, 2010 at 7:12 AM
    chkntaco
    I'm at work at don't have access to the manual right now but I did go out and look at the wiring. All are 18g except the white (ground) one and it may be 10g but it looks kinda small. Not much bigger than 16g.
    I was thinking possibly mounting one of these and running 10g or larger straight from the batt.
    http://www.etrailer.com/p-PK12707.html
